Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 10-19-2007, 08:19 AM   #281
(insert witty one liner)
Iceman420's Avatar
Quote:
Originally Posted by lannal554 View Post
okay so i have some s-techs/illuminas and haven't istalled them yet. I was wondering how much on average it cost to have a shop install them for me?
Expect to pay around $100.00 - $150.00 a corner.
Iceman420 is offline   Reply With Quote
Old 11-10-2007, 05:18 PM   #282
Can somebody, who tried them booth, tell me the difference between:
TOKICO ILLUMINA SHOCKS (beside level settings possibility) and
KYB 4 GR-2 STRUTS SHOCKS
(what level settings on TOKICO gives feeling of KYB).
What would one suggest for comfort ride in first place?
Thanks!
milek is offline   Reply With Quote
Old 11-18-2007, 07:26 AM   #283
How to raise the rear end?
'02 SE. I recently put on Illuminas and H+R's and find the ride very nice. Before doing the replacement, I was experiencing "bottoming out" with only two people in the car, rear end only. The springs and shocks have stopped this, but with the drop and the extra stereo stuff in the truck, I think I have now blown two struts in the rear. One replaced 1 week ago and a new spot discovered in the driveway this past week. What I would like to do is find another rear spring set for the car. Does anyone know of a taller spring from a different car, a different spring that can handle another 2 hundred pounds, or both. I knew of a guy that put a V8 into an RX7 and used, I think, Thunderbird springs in the front end to support the extra weight. Same diameter, could handle the weight, not sure about the height of the spring. Factory springs from Nissan are two soft so I do not think using the factory spring is an option. I am not sure I want to mess with coilovers. I am thinking it will only handle the same weight as the coils. Maybe using coilovers with springs if that is even possible or maybe way too stiff. Does anyone have any knowledge on this?
just bob is offline   Reply With Quote
Old 12-14-2007, 01:26 PM   #284
Quote:
why don't you just get a different size rear tire?
__________________
AlpineGt66 is offline   Reply With Quote
Old 12-17-2007, 12:43 AM   #285
20S LOWERED
[ quote=HotRod66;4928044]I am running 20's on my 2002 SE Max and I am looking to do some supension work on it. Do anyone know if I will have any problems with scubbing if I lower it.[/quote]
what up man i am on 20s also i am going go with the eibach/illuminas i heard they are a real good set up. but i am just going to lower the front because the rear is already close to the back tire and the front has a lot fender space.plus it will look uneven.
__________________
20 INCH CHROME //BERK INTAKE//FRONT CLEAR CORNERS //AVIC-N3//FOSGATE P3//ALPINE MONO 650 RMS//SIRIUS SATELLITE RADIO//INTERIOR DOOR LEDS //TOCKICO ILLUMINAS F3/R4//H&R SPRINGS//TUSANMI CAPACITOR 1.2F// PIAA WHITE LIGHTS LICENSE PLATE......
http://www.cardomain.com/ride/2336457
LEAVE A COMMENT
playboi21617 is offline   Reply With Quote
Old 12-26-2007, 07:39 AM   #286
Quote:
I do not like that option. New wheels and tires will be another $800. There should be some springs out there that would allow for the increased weight, saving me some money.
Old 12-31-2007, 12:00 AM   #287
andy2248's Avatar
Send a message via AIM to andy2248
Well did alot of research around the forums and other places and could not find the answer I was looking for. Two weeks ago I had my rear struts replaced. Presently I hear a clunking sound when i hit bumps and creeking sound on my rear passenger side. I have read that the clunking could be coming from the control arm. I am getting tired if hearing this sound when i hit bumps. The sound is even worse when some on is sitting in the back seat on the passenger side. Any more input would be appreciated.
__________________
2000 GXE Dark Grey Totaled
2000 SE Sterling Mist
andy2248 is offline   Reply With Quote
Old 12-31-2007, 03:14 AM   #288
has anyone tried the megan racing springs on their car? how do they ride, sit, stability that kind of thing
__________________
2003 Nissan Maxima SE
Injen CAI/SRI-custom test pipe-custom 2.5 exhaust with cherry bomb turbo muffler-eibach pro kit springs-auto meter air fuel guage-apc volt meter -custom automatic shift boot-custom ebrake boot-alpine deck-front strut bar-2001 GLE rear lights-custom red high beams-custom rear red blinkers-JDM yellow fog lights-smoked out bumper lenses
impact'sa33 is offline   Reply With Quote
Old 12-31-2007, 04:10 PM   #289
Driving is the next best thing
DrKlop's Avatar
Send a message via AIM to DrKlop
Quote:
Do you have a RSB? I had a similar problem a while ago, it turned out to be the RSB bracket hitting the rear subframe.
Also, check if the springs are sitting correctly in the struts, and make sure that all those nuts are nice and tight.
BTW, since the clunking started after the struts were replaced, why not have the shop do the troubleshooting?
__________________
2000 SE 5-speed
BC coilovers | BlehmCo LTB | Progress RSB | ES bushings | OTTO FSTB | Toyo Proxes 4 | GAB2
Hawk HPS | Brembo blanks | Cattman muffler | BlehmCo grounding | AutoVation pedals
DrKlop is offline   Reply With Quote
Old 01-02-2008, 01:39 PM   #290
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
Anyone try mixing springs? I'm looking at S-Techs front and Progress rear. What are your thoughts? Good and bad welcomed.
__________________
Moar pics of Evo5's ---> http://forums.maxima.org/tires-wheels/557747-old-school-new-look-rare-evo5s.html
In One's Own Tune, Balance Is Found In The "Area Under The Curve".....
Deckdout2 is offline   Reply With Quote
Old 01-02-2008, 01:55 PM   #291
Play with my balls
Deckdout2's Avatar
Quote:
Confirmed the answer I was looking for, but more thoughts are welcomed.
Old 01-02-2008, 02:54 PM   #292
Send a message via AIM to babyboyws6
i was wondering the same
__________________
Bown down biatch
he's my second alarm
babyboyws6 is offline   Reply With Quote
Old 01-06-2008, 08:41 AM   #293
i was hooked on coilovers for a while but realize that they arent the best choice when it comes to daily driving in NY. I think any suspension with both FSB and RSB will improve dramtically. Since im a new york driver i think im going with the progress, the cold weather up here is enough to make our cars feel like the school bus's of 15 years ago if i ran coilovers during winter time.
also s-tech you tend to run into more long run issues since the drop is so stressful.
if i only lived in florida and were rich i would run airride suspension on a play maxima... **sigh.... dreams.... dreams...**
__________________
Bown down biatch
Old 01-27-2008, 10:28 PM   #294
Send a message via AIM to rroderiques77 Send a message via Yahoo to rroderiques77
H&R on Illuminas
Today, I just installed new H&Rs on Illuminas with the setting at 3F and 3R. The ride is absolutely awesome! Great handling and response. What an upgrade from the stock suspension. In order to save some money I did the work myself. It took about 5 hours. First time doing struts. The rears were a ..tch. Had to figure out the spring compressor. Anyway, happy with everything.
rroderiques77 is offline   Reply With Quote
Old 01-28-2008, 08:17 AM   #295
Just ordered new H&R's today.
Now all I have to decide is, keep the Illuminas, or go back to OEM SE Struts?!?!?
Decisions - decisions!!!
Anybody other than Housecor running H&R's with OEM struts?? He seems to like it alot. I'm interested in a more plush ride than my current progress/illumina setup.
gr
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 01-28-2008, 08:19 AM   #296
Owns a Maxima
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Tune the Illuminas down to around 2-3 and they'll be fine with H&Rs. You can even go to 1, but depending on how the spring rate of the H&R matches with the damping setting at 1, it may be bouncy.
Puppetmaster is offline   Reply With Quote
Old 01-28-2008, 08:28 AM   #297
YOu again PM?!?! j/k
I'm just torn because while I loves me some Illuminas, I'm really ready to go back to a smoother ride.
Honestly - I know the illumas would be great, but I don't want to have to tear the susp. apart again, and wish for something smoother. My OEM's only have 15k on them.....so I figure they're still fresh.
As of now - I'm leaning towards putting the OEM's back on, and selling the illuminas and progress springs. Only 45k miles on both! (end: shameless plug)
gr
__________________
Old 02-05-2008, 12:40 AM   #298
SHIFT_In2D
Jess's Avatar
Send a message via AIM to Jess
Haha you can just send them my way then. Been looking for a set.
Went from H&R to a combination of coilovers and H&R. Stiff ride, a little noisy but good control. I'll probrably be making the switch back to H&R soon.
__________________
***Named X5-452***
Birthday: 03/11/03 (Purchase Date)
2003 Maxima GLE - Gray Luster
AMD - Atlanta Maxima Drivers
| Smoked Lights | Cleared Signal | 19" A34 Nismo/Falken 452 | BC Racing Coilovers | H&R TRAK 15mm | Ichiba 5mm |
| Stillen Classic Lip | Stillen FSTB | Injen | NWP IM Spacers | Cattman Y-Pipe | Custom 2.5" & Flowsound Exhaust | Magnaflow Tips |
| 28% Tint | 20th Ann. Pedals + Door Sills | Super White Bulbs | KV3 Eyelids |
Jess is offline   Reply With Quote
Old 02-05-2008, 07:00 PM   #299
i just bought my illumimas with H&Rs going to get them installed soon and i cant wait.
__________________
LEAVE A COMMENT
Old 02-06-2008, 12:08 PM   #300
Has anyone installed S-techs on stock struts and survived? I live in Miami and the roads are pretty smooth for the most part but i dont wanna waste my time installing them if im just gonna have to replace the struts after a week lol
Also, most people say htech are too soft in the front. Progress springs seem to have the same spring rate...are they soft as well?
ShIft_uR FacE is offline   Reply With Quote
Old 02-19-2008, 10:36 AM   #301
WhoDatBuuL's Avatar
Send a message via AIM to WhoDatBuuL
Yo i was about to purchased http://www.autocarparts.com/part/262/530/.but i heard Illumina has a REAL stiff handling is that true???
__________________
Team All Out Nissan : M&P
Shift_ Hard Or Go Home
http://www.teamalloutnissan.com
WhoDatBuuL is offline   Reply With Quote
Old 02-19-2008, 10:49 AM   #302
essential1's Avatar
Quote:
Only if you want them to be. Illuminas are adjustable. Start with 3F/3R. Drive around. If it's too harsh for you, Dial lower. Too soft, dial higher.
essential1 is offline   Reply With Quote
Old 02-19-2008, 05:37 PM   #303
WhoDatBuuL's Avatar
aight thanx
__________________
Old 02-20-2008, 12:14 AM   #304
Send a message via AIM to SLPMAXDuP
Struts N Springs
How much of a difference would lowering springs make without shocks, or vice versa, and which should be the first investment?
SLPMAXDuP is offline   Reply With Quote
Old 02-20-2008, 08:58 AM   #305
Iceman420's Avatar
Quote:
Save up and do them at the same time. Otherwise you are paying to have the work done twice.
Old 02-20-2008, 09:07 AM   #306
Send a message via AIM to '02_EMILBUS
get coilovers! Full adjustability!
'02_EMILBUS is offline   Reply With Quote
Old 02-20-2008, 11:08 AM   #307
SHIFT_In2D
