Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 08-20-2006, 02:20 PM   #121
Nevermind..
Quote:
Originally Posted by DFRMAX02SE
Need some help from all the experts out there...My rear suspension is bottoming out. I bought my 02 Max in Feb. of this year, it didn't take long to realize that the stock suspension was not up to par with my driving style. IT bottomed out over bumps and the body roll was almost dangerous. So I installed a RSB abd FSTB along with some Tokico Blues. This firmed things up, however the rear suspension stilled bottomed out. I read a TSB from Nissan on the problem and it stated to replace the rear springs. So instead of replacing just the rear springs with stockers I went with a set of H & Rs. Installed them yesterday, and have noticed that the problem is worses. Don't get me wrong the cars handling has been greatly improved and ride is, in my opinion better than stock, this problem is just annoying. Also I am afraid I will blow a strut. Any help/advise would be greatly appreciated. Thanks.
I found a thread which talks about trimming bump stops. Even though the H&R instructions do not say to cut them, it seems that this will probably take care of my issue. I will probably take the car apart next weekend and trim at least the rear 1" for starters. For now I took out the spare tire and my golf clubs to alleviate some weight.
DFRMAX02SE is offline   Reply With Quote
Old 08-28-2006, 10:54 PM   #122
ok quick question to lazy to search this thread for it, but is the stock camber in the rear of a 5.5 gen have alot of negative camber? or has my car had something done to it?i just bought it a month ago and ever since people have been asking me about my negative rear camber...
felon is offline   Reply With Quote
Old 08-29-2006, 07:34 AM   #123
Driving is the next best thing
DrKlop's Avatar
Send a message via AIM to DrKlop
Quote:
According to FSM it can be anything between -0.25 to 1.75. So if negative camber is noticeable when the car is parked on a street I'm afraid something is wrong.
__________________
2000 SE 5-speed
BC coilovers | BlehmCo LTB | Progress RSB | ES bushings | OTTO FSTB | Toyo Proxes 4 | GAB2
Hawk HPS | Brembo blanks | Cattman muffler | BlehmCo grounding | AutoVation pedals
DrKlop is offline   Reply With Quote
Old 08-30-2006, 06:00 PM   #124
Shocks/Struts
I was wondering if i could install Tokico Illumina shocks with the stock springs and if this is or isnt advisable by all of you who know a lot more about suspension than i do. THe only reason i ask is because i cant afford to spend more than about 450$ but i still want stiffer suspension. I cant lower it much because of a driveway issue. If you have any suggestions on other set-ups please tell me.
IloveVQ is offline   Reply With Quote
Old 08-31-2006, 02:56 PM   #125
DrKlop's Avatar
Quote:
Ya, you can install Illuminas with stock springs, but from my experience OEM shocks match stock springs pretty well so I just don't think it worth the price of illuminas.
I wouldn't worry much about steep driveways. If you are not ganna go drop it by more than 2" you will be just fine.
If you can't spend more than $450, get RSB, stage 2 LTB, and ES sway bar bushings. It'll be the most affective handling upgrade for the money.
__________________
2000 SE 5-speed
Old 08-31-2006, 09:44 PM   #126
Thanks for the info.
__________________
Berk intake<=>Custom Borla Axel Back<=>Axxtion 2 Piece STS<=>Custom Blow-By Catch Can<=>Custom 12 Point Hyper-grounding Kit<=>Eibachs<=>Illumina's 4F5R<=>FSTB<=>Custom Front Lip<=>Passport x50 Blue<=>Viper Alarm
Quote:
He's a tard and recently,as he claims "Lost control of a mad drift" (ran into a poll) his car now sits at the junkyard.
Old 09-05-2006, 12:11 PM   #127
Quote:
well its not like wow it looks like aftermarket camber settings all around but for some reason to me it looks a lil bit more then usual idk maybe its just me..... and another quick question ...does anyone run tokico illuminas and tein s-techs at the track?
__________________
-Andrew
Team ZKdesigns
03'SE-K&N and a damn fast sticker....
Old 09-05-2006, 04:09 PM   #128
DrKlop's Avatar
take it to an alignment shop and you'll find out for sure whether it's normal or not.
I believe Maxima96SE autocrossed his Maxima when he had s-tech with AGX. But I don't think anyone here runs s-techs on a road course though...
IMO, they drop the car too much and leave you with a limited suspension travel.
__________________
2000 SE 5-speed
Old 09-17-2006, 02:08 PM   #129
Thank you for the research.
genovet is offline   Reply With Quote
Old 09-18-2006, 01:25 PM   #130
I'm looking at ground control coilovers because i need to be able to adjust the ride height, but i want to lower my max. I was wondering if you can lower about an inch to an inch and a half on stock shocks or if i need to get a full coilover system. If anyone could estimate how long the stock shocks would last that would be awesome. Thanks
Old 09-18-2006, 05:19 PM   #131
DrKlop's Avatar
It depends on the spring rates and roads you will be driving on...
Personally, I would never use stock shocks with aftermarket springs. They are just too soft to control anything stiffer than OEM.
__________________
2000 SE 5-speed
Old 09-19-2006, 01:52 PM   #132
Thanks for the input. What type/brand of coilover kit or spring/shock combo would you recommend? They need to have adjustable ride height.
BTW are coilovers hard to install? they look tricky from the instructions i found. About how long does it take?
Old 09-19-2006, 06:46 PM   #133
DrKlop's Avatar
Well, I can't really recommend you a good system, each kit has its pros and cons...
If you are mechanically inclined, have time to work on your car and always modify or adjust something there's nothing better than k-sports. They have camber plates, independent height adjustment and spring preload adjustment; all of that for something like $800. Shocks are also valved exceptionally well for both comfort and performance. The drawback is that they require frequent maintenance - cleaning, retightening, shocks can blow rather quickly if the car is driven on bumpy roads & in cold weather.
If you want maximum on track performance go with JIC magic A2. The drawbacks are price, "very firm" ride and short shock life expectancy.
Boss Chen and TEIN SS offer decent performance (better than any conventional spring/shock combo for our cars) and RELATIVELY good ride. TEIN SS dwarbacks: price (usually over $1100) and no independent height adjustment. (height can be adjusted, but not independently from the spring perch) Boss Chens drawbacks: the only thing that I have discovered so far is that the shocks are not IDEALLY matched with the springs. It's not that they are way off, but you do notice that from time to time.
There are also Progress coilovers, but the only thing that I know about them is that the shocks are not adjustable.
Ground Control sleeve coilovers - IMO performance gains do not worth the price & pain in the a55 to install.
Check the links on the first page to learn about the differences between the springs and the shocks.
It is not hard to install true coilovers, though sleeve coilovers could be indeed tricky as you have to somehow secure sleeve on the shock absorber.
Old 09-19-2006, 07:14 PM   #134
sciff5's Avatar
Send a message via AIM to sciff5
Hey did you get your Boss Chens yet?
__________________
2002 Infiniti I35 Sport Package
Progress RSB, Otto FSTB, Michellin Pilot Sports A/S, Eibach Springs, Illumina Shocks, Fx35 Brakes Rotors/Calipers, Custom SFCs
1989 Mazda Rx7 GTU
Ls1/T56 Powered, Nitrous Assisted
My Car Domain Page
http://www.cardomain.com/ride/2340299
sciff5 is offline   Reply With Quote
Old 09-19-2006, 07:18 PM   #135
DrKlop's Avatar
Quote:
yea, over a month ago... lol
__________________
2000 SE 5-speed
Old 09-19-2006, 07:22 PM   #136
sciff5's Avatar
No review thread? Or did I miss it? I've been spending a lot of time researching Ls1/ Rx7 stuff and buying parts to build my other car.
__________________
1989 Mazda Rx7 GTU
My Car Domain Page
Old 09-19-2006, 07:34 PM   #137
DrKlop's Avatar
yea... you right no review thread yet...
I do not want to post a review YET because there are a couple of small thing I an not happy about, and I'm not 100% sure whether they relate to Boss Chens.
But I will eventually post it.
__________________
2000 SE 5-speed
Old 09-20-2006, 01:34 PM   #138
Thanks. there is a set of d2 coilovers that i saw. Do you know anything about those? I can't do the k sports because i drive on bumpy roads and in cold weather both.
Old 09-20-2006, 04:16 PM   #139
DrKlop's Avatar
Don't know much about d2. But I do know that they are made by the same company as k-sports and that they are very simiar in design. (first they had d2, after that they came up with k-sports) I also know that the built quality is far not the best.
BTW, not to disappoint you, but if you want to buy coilovers (any coilovers) you should be prepared to replace your shock much sooner than you would with conventional springs/shocks. It does NOT mean that they will necessarily blow, but you should be prepared for that. As far as I know TEIN and Boss Chen shocks have the longest life expectancy. (Boss Chens did not prove themselves yet, but long service intervals was one of the main objectives when they were being designed)
__________________
2000 SE 5-speed
Old 09-21-2006, 01:31 PM   #140
Do you mean i would need to be prepared to buy new shocks to replace the ones that come in the coilover kit? About how long do they tipically last?
Old 09-21-2006, 10:18 PM   #141
DrKlop's Avatar
well, yeah... there's much more stress put on the shocks, and even though shocks for coilovers are stronger than your OEM shocks, they still tend to start leaking earlier. There's also a higher possibility of blowing them out in one shot on a speed bump or railroad tracks.
I can't tell you how long they typically last... They will definitely not last as long as the shocks made for regular springs, but if you are careful you should be able to get a few years out of them. As far as I know, most people get at least a year out of their shocks. [for coilovers]
__________________
2000 SE 5-speed
Old 09-24-2006, 09:50 AM   #142
OK. Thanks. One more guestion. I am looking at the tokico illuminas and the progress springs for the spring and summer. Do you need to do any cutting on the shock or have to use a spring compressor or what do you do to install the spring on the shock?
Old 09-24-2006, 12:14 PM   #143
DrKlop's Avatar
You need to use spring compressor. No cutting is necessary except for the bump stops. Although you do not have to cut the bumpstop, it's recommended because your suspension travel becomes very limited if you do not cut them.
Here's a complete howto: http://www.innerbean.com/housecor/strut_install.html
__________________
2000 SE 5-speed
Old 09-25-2006, 06:40 PM   #144
Would i need a spring compressor and still need to cut bumpstops if i went with the H&R springs and illuminas? also what type of camber kit or camber plates or alignment kit would i need or would you recomend with the H&R's? Thanks
Old 09-26-2006, 01:47 PM   #145
Driving is the next best thing</
