Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-03-2006, 10:12 PM   #1
Hoooper
300zx BBK questions
so ive been looking at the 300zx brake upgrade writeups and i still have a few questions.
1) why does the kit matt93se offers look so much different than the kit the jeff92se offers?
2) are cobra rotors really just rotors from a cobra mustang?
3) are cobra rotors the exact same besides the diameter(ie: is the spacing over the hub, between the actual rotor and where the wheel sits the same?)
4) i checked on my friends 300zx and i only need a 10mm spacer to fit. will it be the same if i use the cobra rotors or 6th gen rotors?
5) if i use the same wheels all year should i go for it? i found the calipers for 100 for all four.
Old 01-03-2006, 10:19 PM   #2
The Original CF Maxima
Flava_24/7's Avatar
Matts kit uses 2004 rotors
Jeffs kit uses Cobra rotors. The Cobra rotors are a bit larger.
Yes, they are.
No, you need the ring inserts to fill the gap around the hub.
That depends on your wheel design. When using the BBK's the relocation bracket moves the caliper out m ore. If you wheels spokes go out the same distance from the center to the outer then yes. If the spoke design flares inwoard then no. It all depends on the wheels.
Sure, even if you had to step down, its not to hard to go back to stock if you had to.
__________________
Chumps try to imitate but can never duplicate
377hp 338tq
Flava_24/7 is offline   Reply With Quote
Old 01-03-2006, 10:31 PM   #3
Hoooper
adding more
6) where do i find cobra rotors (what year cobras?) with the ring inserts or just the ring inserts?
Old 01-04-2006, 02:46 PM   #4
Hoooper
no answers?
Old 01-04-2006, 02:56 PM   #5
I'm needing a caw
Jeff92se's Avatar
Cobra rotors can be found anywhere OEM or aftermarket rotors can be purchased. I recommend Automax in the Group Deal forum.
Not only will you need the rings to center the rotor, you will also need the brackets that relocate the 300z caliper outward to accomodate the larger 13" rotor.
I sell both for $90 shipped. You will also need a few extra bolts/nuts in the same strength grade as the rest of the brake hardware. Along with new brake lines. Matt93se sells what you need for a good price
Jeff92se is offline   Reply With Quote
Old 01-04-2006, 04:26 PM   #6
can you get the nuts and bolts that you will need at a local autozone or something???
joeyd is offline   Reply With Quote
Old 01-04-2006, 04:27 PM   #7
I'm needing a caw
Jeff92se's Avatar
I highly recommend a local fastener shop so you can get metrics and hardware that has the proper grade. (strength)
Quote:
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Old 01-20-2006, 11:44 AM   #8
adding more
I got my cobra's for my 4th Gen from these guys:
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Don't be fooled by the price these things are awesome and a bargain! Had them on for over 6months no problems and quiet.
I'm wondering if it's worth it to change the BBK kit over to my 02 5th Gen?
MAXRB8 is offline   Reply With Quote
Old 01-20-2006, 01:13 PM   #9
Thinks he is fast
maxspeedse02's Avatar
Send a message via AIM to maxspeedse02
Will the cobra rotors fit on the stock 02 17" wheels? If not how about 6th gen 18's?
I really would like to do this mod, our stock brakes suck
__________________
2002 SE 6-speed HLSD: WM STS, ES poly shifter bushings, PR CAI w/ K&N, SSIM, Hotshot headers, Warpspeed MS cat, Cattman Cat-back, ES Motor Mounts, TS L-Spec, Emanage Blue, Cleared out turn signals, Black headlight housing, Umnitza DDEs, Progress RSB, Powerslots/Hawk HPS, Fidanza aluminum flywheel, Exedy Stage 1 clutch, 06 G35 Sedan seats.
maxspeedse02 is offline   Reply With Quote
Old 01-20-2006, 01:16 PM   #10
I'm needing a caw
Jeff92se's Avatar
Rotors? Yes. Rotors with 300z calipers? Not a chance in living hell. Both those wheels don't feature the correct offset or design to clear this bbk
__________________
Sold Jan 14, 2006'
Mod list:
Old 01-22-2006, 01:16 AM   #11
Thinks he is fast
That's what I figured. What other options do I have to upgrade my brakes with 5.5 gen 17's or 6th gen 18's (What I plan on getting in the near future). 6th gen brakes? ? Better rotors and pads? My rotors are warped and I've heard how had the stock brakes suck, So when I get around to fixing them I would like to upgrade. Could I upgrade to Z32 calipers with a smaller rotor without having clearance issues with the wheels I listed above?
__________________
Old 01-22-2006, 01:22 AM   #12
I never narc'd on nobody.
Akumachan's Avatar
Send a message via AIM to Akumachan
You should pick up a set of 350Z/G35 wheels, those will clear, but it doesnt really matter what size rotor you use, 300zx calipers are really wide so it takes a lot of clearance to fit them.
Akumachan is offline   Reply With Quote
Old 01-23-2006, 10:31 PM   #13
Thinks he is fast
The Z and G wheels are staggered though aren't they? I like being able to rotate my tires. I think staggered wheels on a FWD gay is kinda worhtless. I dunno what other options I would have though
__________________
Old 01-23-2006, 10:50 PM   #14
Hoooper
uhhh, get 4 front from a z or g, then they wont be staggered.
Old 06-23-2009, 08:03 AM   #15
hey jeff
i need those hub rings for the 13" cobra rotors for my 5th gen asap
BULLET10 is offline   Reply With Quote
Old 06-23-2009, 09:30 AM   #16
Auto Tech Performance
rroderiques77's Avatar
Send a message via AIM to rroderiques77 Send a message via Yahoo to rroderiques77
Quote:
If you get the Cobra rotors that have the stud holes drilled to Maxima specs, then you wont need the rings.
__________________
94 F22B2 CD6 G77M 5MT- daily bucket
Will be one day modded
02 A33B KT3 6MT
241whp/227wtq
ET...14.480
Interested in owning/operating an automotive repair franchise?
P/M me for details.
rroderiques77 is offline   Reply With Quote
Old 06-25-2009, 12:25 AM   #17
I'm needing a caw
Jeff92se's Avatar
What he said
__________________
Sold Jan 14, 2006'
Mod list:
Old 07-17-2009, 04:35 PM   #18
Send a message via AIM to Majestic Ken Send a message via Yahoo to Majestic Ken
I have the G35 18's w/ 300zx calipers on some smaller than stock 5.5 gen rotors. I just bought some 6th gen rotors from the zone Will i need a bracket or no?
__________________
You just bumped into the wrong max
Majestic Ken is offline   Reply With Quote
Old 07-17-2009, 09:16 PM   #19
Toolie
knight_yyz's Avatar
it isn't 100% necessary to buy brackets for the brakes to fit. They bolt up to the stock position, but you will need to machine the rotors to a smaller diameter. I know someone who has done this and it works fine. Personally I would only do this with some wheels as the rotor diameter is smaller than stock and looks odd if the wheels are too big or too much space between the spokes. But the added braking power seems to be worth it.
__________________
6MT | 06HLSD | I/H/E & FC | Stillen FSTB & RSB | Eibach Pro Kit | Illuminas | Watkins STS | UDP | NWP Spacers | Greddy Blue | ES Bushings
253.50 fwhp
249.75 lb/ft tq
14.3 @ 101mph (street tires, bad wheel bearing and a few spun tranny bearings)
knight_yyz is offline   Reply With Quote
Old 07-17-2009, 10:41 PM   #20
in finding calipers... could i just go out and buy the remanufactured 300ZX TT calipers from any parts store?
__________________
2001 Nissan Maxima 20th Anniversary Edition w/ only 65k on it (11/8/09)
Suspension-
Eibach Springs on Illuminas set to 4F/4R
Stage 2 LTB Installed!
Now I need a RSB
Audio-
JLAudio 12W7 in a 2.3cuF (same box, ghetto sealed)
JLAudio 500/1 @ 85hz
Rainbow SLC 255 Comps
Alpine V12 MRV-F407 @ 75hz
Optima Bluetop D35 (1/2 Grounding Kit done)
FlipCpt45 is offline   Reply With Quote
Old 07-17-2009, 11:18 PM   #21
Quote:
yes , but they are going to charge you a "core charge "for not having the old ones.
__________________
|Eibach Springs | FSTB |G35 C Rims|Stillen Classic lip|01 SE Tails|Oil Catch Can|Custom Air Intake |Blehmco Ground Kit| Cleared Headlights | 6k H3 Fogs| Cleared Sidemarkers |5% Tint (all around) | 300ZX BBK| 6 Gen Rotors|Hawk HPS pads | Optima Red Top | Custom leather |I35 Door panels| B & M Trans cooler|Protection Clifford G5 With Beretta Px4|
FS: Door panels
danger300z is offline   Reply With Quote
Old 07-18-2009, 12:15 AM   #22
eh.... i think i could get them for about 40 a piece.. (friend) then the core is like 50.. so 90 each caliper... thats not too bad eh?
__________________
Suspension-
Now I need a RSB
Audio-
Old 07-18-2009, 08:40 AM   #23
we tried it out last night and it didnt work so i'll have to get one anyway i see.
__________________
Old 07-18-2009, 09:25 AM   #24
another option is 1st and 2nd gen q45 calipers
MR.Large is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
