Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-23-2005, 01:29 AM   #1
energy suspension bushings
Im putting e.s. bushings for my front sway and end links this weekend. I just needed to know if anyone knows what the size of the stock front sway bar on a 5.5gen or what universal e.s. bushings to use. Also on the end links i'm going to replace the endlink bushings with e.s. ones. has anyone done this yet and if so which ones did you use. I just thought i'd ask so i can just go to the store and buy them without having to match up sizes through trial and error. Anyones help would greatly be appreciated.
thank you
__________________
"happiness is not around the corner it is the corner"
k2max_driver is offline   Reply With Quote
Old 12-23-2005, 07:15 AM   #2
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
I thought the ES bushings were vehicle specific and not universal. From their site it looks as if they don't even make end link grommets for the 5.5:
http://www.suspension.com/nissancars.htm
Puppetmaster is offline   Reply With Quote
Old 12-23-2005, 06:37 PM   #3
they are universal plus that site is outdated like cattman.com i saw some at autozone
Old 12-23-2005, 06:40 PM   #4
retired moderator
irish44j's Avatar
I can tell you for a fact that the FSB bushings are NOT universal...they have a specific ridge on them to fit the clasp on the maxima....they are not, for example, the same shape as the ones for my wife's Mazda...
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 12-23-2005, 06:55 PM   #5
it's not that they are universal it's that they match up to the same size as our max's
Old 12-23-2005, 09:08 PM   #6
I would suggest go to spec like Irish said, SCO had carry of them and fast shipping, 00-03 SE 23mm, GXE & GLE 22mm
reMaxxxK is offline   Reply With Quote
Old 12-23-2005, 09:30 PM   #7
I've installed these recently, only ones so far besides the subframe bushings. I must say, for a car that doesn't have many suspension mods yet, these are GREAT. They definitely give the car a firmer "feel" when cornering, especially when doing crazy sh*t like swinging into a parking lot really fast
spirilis is offline   Reply With Quote
Old 12-24-2005, 08:34 AM   #8
Sprilis --
Where'd you buy yours?
I'd like to get some of these, and get 'em on asap -- I think mine are rattling, and it's pissing me off!!
Stockers cost about $8.50 ea. Hoping these will be cheaper or same price.
Thanks,
gr
*and if anyone has install instructs or pics, that'd be cool too!
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 12-24-2005, 09:23 AM   #9
Quote:
Originally Posted by ghostrider17
Sprilis --
Thanks,
gr
sportcompactonly.com has it, call Steve to hook u up for a discount, their list price are $20.xx. here is the write up:
http://polo.lxanyc.com/2002MaximaSE/.../FrontSwayBar/
Old 12-24-2005, 09:33 AM   #10
I got them from Cattman when they first came out. I think they're more expensive than the stockers, but not more than $20-30 I think for the set. However they are REALLY worth it.
They're pretty easy to install. You jack up the front, take off the front wheels, turn the steering wheel completely to the direction you're doing (that moves the inner tie-rod boot out of the way) and then unbolt the metal strap securing the swaybar to the subframe. It's easier if you then undo the other side before removing them. Once they're both unbolted, the sway bar can lift easily, and you can remove them.
Grease up the inside of the new bushings (use ALL the grease) and slide them on, the split part facing forward I think. There's a stop built into the swaybar to prevent you from pushing it too far inward. Make sure the part of the bushing that sticks out goes downward (it fits into a slot in the subframe I think). After they're both on, press it down and reinstall the mounting straps. The strap will sit a good centimeter or so up above the subframe so you'll have to squish it back down by tightening the bolts back and forth evenly until it's sitting level and you can torque them down. (I don't think I torqued mine, I just tightened it pretty firmly with a 1/2"-drive ratchet)
I think I noticed a mild amount of extra 'harshness' in bumps after the install but I've either become used to it, or it's gone away. Either way, the confident and "immediate" steering response (think the car has less side-to-side tilt/play when you make a steering manuever) you get out of these make it totally worth all the money and effort.
Old 12-24-2005, 09:41 AM   #11
2-Wheelin it...
Send a message via AIM to PoLo
i've had the Lower Control Arm and Rear Trailin Arm bushings just sitting here for the past year. i need to grow the cojones to do the job.
FSB replacement is a joke. i did it for someone a few months back. did the motor mount and FSB bushings in 2 hours. that included the trip to the machine shop to press the old motor mount bushings out.
as spirillis said, it's noticable when taking sharp turns. a combination of all the bushings would be extremely noticable when you're turning and you hit a small bump. under normal circumstances, your car would skip around a bit. in this case, they hold onto their path. good luck!
edit: suspension.com seems to have an up to date list with some good prices.
FSB: $21
6spd Shifter: $18
MotorMount: $80
Rear Trailing Arm: $67
Control Arm: $53
Subfram (aka C-Brace): $23
i'm sure you can get cattman to beat that. drop him a line.
__________________
Marco...PoLo!! - 2k2 6speed y Puro Colombiano.
Rollin: H&R Fronts/OEM Rears on Tokico's, 18" 2k5 Wheels ||Boom Boom: Alpine HU, Eclipse Amp, Diamond Subs/Amp/Comps, Rainbow Tweets, Stinger Wiring, Optima Yellow||Vroom Vroom: Injen CAI, Cattman Y, ES Bushings, HP STS
Best dB: 129dB...room for better.
PoLo is offline   Reply With Quote
Old 12-24-2005, 09:49 AM   #12
Cool. I need to do the LCA/RTA bushings too. I also need to do the motor mounts, although I'm almost ready with those (just too lazy to go in the garage and work on it after all the clutch work I did the other week).
I'd imagine the "solid" feel you get with the motor mounts is somewhat analogous to the "solid" feel you get with the FSB bushings--I recall before, when taking a quick turn, the car would move, but then soon after I'd feel a mild side-to-side "play" in the suspension which made fast turns feel somewhat sloppy. This eliminates that and makes the car follow its track without excess feedback.
Old 12-24-2005, 09:56 AM   #13
2-Wheelin it...
i'll be honest. i prolly never felt the real difference as i've been through 3-4 diff. suspension setups that i never got a feel for what the FSB/MM did. i do know that on takeoff's, the car would lag for a split millisecond and go. with the MM inserts, it seems to pick up immediately. the other good thing which not many have noticed is that the inserts are centered, where as the OEM are a bit lower, thus lowering the motor about 1/2". this is good for guys with FSTB's that bang the manifold. totally clears it.
so, how's about i drive to hanover and we do all the bushings in one day. think you can do the trailing arm (http://polo.lxanyc.com/2002MaximaSE/...ngArmBushings/)
Old 12-24-2005, 11:51 AM   #14
chr0nos's Avatar
nice, very nice. thanks to all for the links and how to, i will be doing this next week along with swaybar links. =)
chr0nos is offline   Reply With Quote
Old 12-24-2005, 01:32 PM   #15
Hanover is too far, otherwise I would joint to install those LCA bushing too and have some fun, also my new LTB from Matt.
Old 12-25-2005, 04:36 PM   #16
But why is teh Rum gone?
rbrown81's Avatar
Send a message via AIM to rbrown81
Bushings FTW!
Im doing mine as soon as I get back from Australia.
Polo, did not know you could get bushings for the crossbrace... is it worth getting these?
__________________
Catt Gen2 Headers/Res/B-Pipe | Franken Rear | Berk Intake/Apexi | 17" Timing | UR UDP | Watkins Short Shift | Generic Ground | ES Motor Mounts | H&R | Illuminas | ES Bushings |Otto FSTB | Progress RSB | Eagle F1 245/40/18 | OZ Ultraleggera 18x8 | Powerslots | HPS | Goodrich SS Brake Lines | Hella Supertones | Red Intake Cover | Clear sides | Maglite Mod
Soon : VAFC | Brakes | Intake Manifold
rbrown81 is offline   Reply With Quote
Old 12-25-2005, 05:07 PM   #17
2-Wheelin it...
Quote:
Originally Posted by rbrown81
Bushings FTW!
i really have no clue...i put everything together in 1 sitting, so i dont' know which affected which. plus, all my bushings were free, so i didn't care.
Old 01-09-2006, 04:30 PM   #18
which bushings would i notice a dramatic differences? i want to replace all my bushings on the car. im at 150,000km. does es suspension make the best bushings for our cars?
DUKEE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
