People with auto trannys...
Old 12-14-2005, 02:34 PM
LA02MAX's Avatar
ya'll might wanna try this!! So my mom's 2k maxima now has 208k miles on it and her automatic transmission was slipping pretty bad on the 1-2 shift....well my grandfather recommended this stuff to me called B-12 Chemtool (in the same bottle as seafoam; found at your local auto parts store)....it's basically just like seafoam...well i poured a bottle of that stuff in my mom's transmission and drove it for a half hour...then i got home and did a full fluid flush and when i went out for a drive again, the slip was GONE! This has been going on for well over a year and probably 50k miles and it disappeared just like that! apparantly there was quite a bit of build-up inside the transmission and this stuff got it out just like that! If ya'll are having the same problem, i HIGHLY recommend doing this...it's extremely inexpensive, fast, and easy to do and it makes a world of difference.
LA02MAX is offline
Old 12-14-2005, 02:42 PM
Need A Light?
steven88's Avatar
wow...I've seen the b12 chemtool at all the automotive stores...didn't know it was that effective...nice find! since you said it's the same as seafoam, theres a type of seafoam called Seafoam Trans Tune...might be worth checking it out..
steven88 is offline
Old 12-14-2005, 02:44 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
There is one for Seafoam too... and if the normal Seafoam works like magic.. then It might work fine too
Lontar1 is offline
Old 12-14-2005, 03:05 PM
LA02MAX's Avatar
yeah, it sounds like they all do the same thing...and they're all around the same price, but MAN did this stuff make a difference....
LA02MAX is offline
Old 12-14-2005, 03:09 PM
fishpony's Avatar
r u sure the tranny flush wasnt the reason the transmission stopped slipping? regardless i think im gonna pick some of this stuff up when i flush my tranny.
fishpony is offline
Old 12-14-2005, 03:10 PM
LA02MAX's Avatar
well her transmission was flushed around 12k miles ago, so i don't think that would do the trick, would it?
LA02MAX is offline
Old 12-14-2005, 03:17 PM
kcowden's Avatar
Very interesting... I just did a total tranny flush and added in the Lucas Oil stop slip stuff. I seems to work and the shifts are a little sharper. I'll have to check this stuff out. Thanks for the info...
kcowden is offline
Old 12-14-2005, 03:23 PM
Need A Light?
steven88's Avatar
speaking of auto trannies...my mom's 05 toyota camry with only 5k miles automagic seems to lag like hell in the 1-2 shift...this only happens if you really get on the gas pedal...I'd say anything below 50% throttle, the tranny shifts fine from 1-2...but above that, the 1-2 shift lags...it doesn't necessarily slip...it just lags like hell...i wonder if I should switch her over to synthetic ATF and the seafoam flush?
steven88 is offline
Old 12-14-2005, 03:44 PM
GimmeTorq's Avatar
Hmm... B-12 Chemtool is a pretty strong solvent (toluene, acetone)... I don't know, man... I would be scared of dumping that stuff in a tranny... Nice it worked for you though.
GimmeTorq is offline
Old 12-14-2005, 04:24 PM
Lontar1's Avatar
my wife drives an 05 Camry and it is the same thing.... so you are Ok with it
Lontar1 is offline
Old 12-14-2005, 04:39 PM
No More Maxipad
lowincash's Avatar
is the camry a v6? i've read that the v6 transmission have a slight lags on the camry and highlander. i also felt this when i test drove a camry v6 before i got the maxima. that was one reason i didn't get the camry because of the lagging feeling and handles like poo poo =/
lowincash is offline
Old 12-14-2005, 07:28 PM
Mauja He Mauja
ZIPPIN's Avatar
Wow...She drives a lot
ZIPPIN is offline
Old 12-14-2005, 08:04 PM
huso1988's Avatar
All that sounds good, and i think i will do it too.
How many miles did your mom have when her tranny started sliping from 1st to 2nd gear.
THANKS
shift_confidence
huso1988 is offline
Old 12-14-2005, 08:49 PM
kobalt's Avatar
Good stuff, Im at close to 141k and will pick up a bottle when I change my fluid
kobalt is offline
Old 12-14-2005, 09:10 PM
MaximaPolak's Avatar
Maybe the flush helped the most.
MaximaPolak is offline
Old 12-14-2005, 09:35 PM
Got Penguin?
TPenguin's Avatar
Hey guys will this work if I have a shop "flush" my auto tranny? I know that they "recycle" the fluid but i was wonderin I needed to do this myself....
TPenguin is offline
Old 12-14-2005, 10:25 PM
machplane's Avatar
B-12 Chemtool is what people use to clean carburetors that's been fouled up by carbon buildup, that stuff is pretty strong as GimmeTorq brought up. It might eat away some of the seals in the tranny, so I would be careful about using it.
The best thing to do for keeping the tranny from slipping IMO is to be dilegent about checking your tranny fluid and change it out when it starts going bad.
machplane is offline
Old 12-14-2005, 10:26 PM
Need A Light?
steven88's Avatar
No it's a 4 cylinder model...I wonder if theres a TSB for it...I needa check
steven88 is offline
Old 12-14-2005, 10:34 PM
dot dot dot ...
NmexMAX's Avatar
I take out the VB and clean it when i do a flush... this would help my A32.....
But I guess now, as Americans, we can just sit back and pour a bottle in and be lazy ..
NmexMAX is offline
Old 12-15-2005, 04:24 AM
Mauja He Mauja
ZIPPIN's Avatar
I have heard horror stories from some people who just flushed the tranny and next thing it went out. I would be careful doing this if you have not changed/flushed the tranny for a long time...Some of that build-up, i have read, will sometimes help the tranny
ZIPPIN is offline
Old 12-15-2005, 05:56 AM
Colossus's Avatar
2k2 3.5L w/ 88k miles.
I put in AutoRX transmission cleaner. Drove for 1700 miles and then did a complete flush to Mobil1 synthetic transmission fluid. I don't notice smoother shifts or anything like that, but the car was shifting fine before I flushed it. I've always had luck with AutoRX products.
Colossus is offline
Old 12-15-2005, 06:30 AM
I Know Kwaliti
igzy's Avatar
Yes, I support this opinion. When I worked in a shop we had a few customers come back after the tranny flush and the tranny was bust. Though all of those were people that had never changed the fluid in 100K or more and then simply shocked the tranny with the flush...
With slipping and old trannies I had good experience with Lucas Oil tranny helper. It is about 1 qt and helps the shifting and reduces slipping. The thing is thick as a glue...
igzy is offline
Old 12-15-2005, 08:07 AM
NewLoveI30's Avatar
on that!
Your mom prolly doesn't want to hear this, but changing the ATF after 200k is a really bad idea unless you have been doing it at like 50k intervals.
ATF in its self is a pretty strong solvent and after that many miles it will flush out stuff that has been keeping seals and bands lubricated. I wouldn't flush my tranny after 100k (if its never been flushed before).
I've got $50 on the tranny starting to slip within 6 months
And the smoother shifts are undoubtedly a result of the new ATF and not the Chemtool or whatever.
NewLoveI30 is offline
Old 12-15-2005, 10:34 AM
LA02MAX's Avatar
Originally Posted by NewLoveI30
on that!
but if that were true, we would have noticed it before summer when we got her transmission flushed (for a crapload of money, of course, cuz we brought it in to the shop) but we didn't....
LA02MAX is offline
litch
123
01-04-2024 07:01 PM
BobTX10
10-07-2015 08:43 AM
Maximeltman
09-28-2015 07:19 PM
dshinn
09-26-2015 08:07 PM
Quick Reply: People with auto trannys...
