Fixed vias, on boosted = huge difference.
Old 11-11-2005, 08:09 AM
jeremykedel's Avatar
Guy i fixed my vias 2 times before I boosted with the jb weld fix but kept breaking.So, I boosted my car and it would hesitate and not runn so hot, still strong as hell but wouldnt feel to strong top end.So I thought well what would happen if I actually welded it, and so this past week I did it with a tig welder.Man it is so much stronger than ever before and what a difference it makes on this boosted car.It honestly feels like 30 to 40 horse difference.It is a serious kick in the pants.Now when i start boosting in second gear it starts spinning before it only did that in first, it would spin when going into second, but now it does it even if i am already in second and boost it up.The welding seemed to havew held up great so far and i think it is a permanent fix.So if you have the means weld it, it will last longer.
jeremykedel is offline
Old 11-11-2005, 09:35 AM
IMBOUTTOBUSTSOMEGHOSTS
sloppymax's Avatar
i was on the dyno about a week ago with my repaired vias. the parts SR20DEN fixed it with worked great but i could not figure out the clock/position of the valve. first dyno was flat after 5k and i only had an hour so i just pulled the power valve out again. difference was over a 30whp gain and i am n/a and auto. did you happen to record the position of the power valve or did you just tig the cup with the power valve in and put it back together?
sloppymax is offline
Old 11-11-2005, 10:29 AM
Puerto Rico-Maxima Lover
Lontar1's Avatar
So you took the valve out? or you just adjusted it. Do you still have in there?
Lontar1 is offline
Old 11-11-2005, 10:38 AM
sloppymax's Avatar
i removed the power valve completely. torque feel a little peak but averaged higher through the band since torque is a function of horsepower. i pulled 194hp after removing it and the fuel pump would not hold pressure above 6k. my fpr dropped close to .5bar above 6k so with a healthy fuel pump i think it would be closer to 200.
Old 11-11-2005, 11:23 AM
ChromeSE5's Avatar
The welding would be a great option. When I came up with the JB weld fix, I knew it wasn't going to be permanent but fortuantely mine has held up for over a year now.
ChromeSE5 is offline
Old 11-11-2005, 11:35 AM
Sports Button FTW
meccanoble's Avatar
omg, does anyone see any flaws with welding? Dam this might be our solution after all!
meccanoble is offline
Old 11-11-2005, 11:56 AM
OOmaxSE's Avatar
sorry for the noob question but what exactly is a "tig welder"?
OOmaxSE is offline
Old 11-11-2005, 12:05 PM
Stephen Max's Avatar
TIG stands for "tungsten inert gas". A tungsten electrode is used that is shielded with argon or helium gas during the welding process to prevent oxidation of the weld bead and slag buildup. TIG welding produces probably the prettiest looking welds when done right.
Stephen Max is offline
Old 11-11-2005, 12:42 PM
Lontar1's Avatar
I might remove mine and see how it feels... let me asked you again.. you removed the beige rod inside the intake.... that goes inside the cup.....
Lontar1 is offline
Old 11-11-2005, 12:54 PM
sloppymax's Avatar
yeah, might the light you were looking at it under but mine was yellow. of course it has stains but looks to be originally yellow. you have to remove it from the front of the motor(pulley side) from that access port but there is a spring that must be taken out of the vias box side as well.
Old 11-11-2005, 01:03 PM
The tig did it i was worried about the bearing and what not and melting it but had no problems. http://2000turbomax.piczo.com
Old 11-16-2005, 07:31 AM
zoner's Avatar
Hey, mind telling me how you welded the cup back in? I'm assuming you took the the shaft the cup is attached to out of the valve assembly? I started to tear mine apart, but couldn't get the shaft out. Any pointers? Thanks
zoner is offline
Old 12-14-2005, 04:01 PM
i took the end off the tig welder and ran the wire out a little far and held the cup in place with a pai of pliers.then tacked it, then i cut the spring a little to make way for the weld.Been over a month so far no probs yet.
Old 12-15-2005, 12:00 PM
zoner's Avatar
Thanks!
zoner is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
MichMaxFan
09-30-2015 09:18 AM
King_Ten_Ahead
09-27-2015 02:24 PM
Quick Reply: Fixed vias, on boosted = huge difference.
