Project EC.....Something new for the org
Old 12-02-2005, 08:33 PM
Play with my balls
Deckdout2's Avatar
Some of you might have known that our engine covers retain a little bit of heat. At least that's what I've heard. That's one thing I wanted to take care of. From the pics below, by taking it off and leaving it as a barebone engine it looks quite unappealing, if I might add. I've always wanted to keep my engine cover, but had to brainstorm ways to exhaust most of the heat while keeping it looking nice and tidy. Went through a few ideas, and then came up with this little creation. Somewhat along the lines of looks with a functional attitude.
Pretty tedious work drawing, measuring, cutting, sanding, recutting, resanding, priming, painting, and GBAUER Waxing it! Took me a little over a week and a half to come up with the idea, design, and now almost finished with it. A few hours here and there after work. All I have left to do is wait for my new $25 emblem to come in from the stealership and mold mesh behind it for a clean look. I'll update this thread with the finished product soon.
Enjoy!
Designing and cutting was one of the hardest parts.
Starting to come together.
Deckdout2 is offline
Old 12-02-2005, 08:34 PM
Play with my balls
Deckdout2's Avatar
Not too clean looking. I have however degreased and cleaned up the engine since these pics.
Still looks alot better even though the engine was dirty.
It'll look 100x better with the mesh back there. You can see how it's not a clean look through the openings.
Here's the rest.
Old 12-02-2005, 08:58 PM
kobalt's Avatar
I like it! Very original - it most certainly differentiates your engine bay from the others. What paint did you use?
kobalt is offline
Old 12-02-2005, 09:00 PM
Puppetmaster's Avatar
I like it.... very creative...
Btw, is that a GAB with a paper filter?
Puppetmaster is offline
Old 12-02-2005, 09:09 PM
Suspension Yoda
djfrestyl's Avatar
I also like. Very original.
Shoulda made a template or something to sell/give to other orgers who want this also.
djfrestyl is offline
Old 12-02-2005, 09:12 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
looks pretty cool....
Lontar1 is offline
† ErV †
i don't dig it. perhaps fewer cuts would have been better.
Old 12-02-2005, 09:14 PM
Play with my balls
Deckdout2's Avatar
Preciate it. I used High Temp paint to withstand the venting heat. I'm sure I'm going to have to replace my emblem once again in the future cause when I first took it off, the chrome on it was melted and deformed. I've heard of a few issues from others, but not everyone.
Old 12-02-2005, 09:15 PM
Play with my balls
Deckdout2's Avatar
OEM baby!.....I'm going to probably do away with the whole airbox anyways and go to what Matt and Haydn are using.
Old 12-02-2005, 09:19 PM
Play with my balls
Deckdout2's Avatar
Each opening had a template create because of the sizes of each opening. I still have the templates and considered doing this for the org if there was enough interest. I would probably make it custom for each member if they'd like a different design or however they want it to look, with any color paint scheme.
Old 12-02-2005, 09:23 PM
Play with my balls
Deckdout2's Avatar
Yeah it's still kind of in it's raw state right now. It will probably be more to your liking when it's completed. I wanted to use as much room as efficiently as possible, With the flemsiness of the lesser material, a bigger opening and fewer cuts would have weighed the center down and caused bowing in some areas. Well see if I can get it to look any better when I'm done.
Old 12-02-2005, 09:33 PM
Suspension Yoda
djfrestyl's Avatar
Cool. looking forward to seeing more designs.
Time for 3.5 swap
Old 12-02-2005, 09:57 PM
makdaddy386's Avatar
Awesome project man...defintely like the orginality factor. Almost makes me want to look into getting an engine cover myself. Very nice work. Color scheme = :
makdaddy386 is offline
Old 12-03-2005, 02:09 AM
Doctorate in Detailing
Bluesbrekr's Avatar
Great idea. I removed my cover quite a while ago because of the possible heat issue. The 3.5 is not a pretty sight without it. I may attempt something similar. I'm very interested to see the pics after the screens are installed.
Bluesbrekr is offline
Old 12-03-2005, 07:28 AM
+Cru OG
NisMoN00B's Avatar
I like the design, most likely I'd want one when I see the final pictures with the mesh screens. It'd probably rival GBAUER's waxed engine cover.
NisMoN00B is offline
Old 12-03-2005, 07:34 AM
upstatemax's Avatar
I have my old K&N panel filter still from my GAB (switched to berk) if you want it... Just PM me and we can work it out...
upstatemax is offline
Old 12-03-2005, 12:31 PM
Conecarver
BEJAY1's Avatar
I like it too! Kinda tasteful and not ricey. Nice work.
BEJAY1 is offline
Old 12-03-2005, 03:01 PM
VQ Wizard
SR20DEN's Avatar
I know where I can get these laser cut.
And I think it needs some sort of mesh behind it.
SR20DEN is offline
Old 12-03-2005, 03:27 PM
GBAUER's Avatar
I like the thought, but I think it definitly needs the mesh. Oh, and I've found Mcguire's does the best job for the wax.
Honestly, I've never found the heat to be a problem. If anything, the cover might actually keep the block warmer after the engine is turned off in the winter. My cover has been painted for over a year now with regular car paint and I haven't had a problem with peeling. Oh, and a year in my car is worth about four in any other. 50k miles a year.
GBAUER is offline
Old 12-03-2005, 03:28 PM
Igor911's Avatar
Two thumbs up!
Excellent job/idea.
Igor911 is offline
Old 12-03-2005, 03:33 PM
frankd121's Avatar
thats really cool, i like it
frankd121 is offline
Old 12-03-2005, 03:38 PM
GBAUER's Avatar
when you get the cover to shine like this, call me!
GBAUER is offline
Old 12-03-2005, 04:07 PM
HotshotVQ35's Avatar
what did it cost to paint the cover?
HotshotVQ35 is offline
Old 12-03-2005, 04:34 PM
retired moderator
irish44j's Avatar
looks good..
GBAUER's engine cover just got
irish44j is offline
Old 12-03-2005, 05:40 PM
ColdSHO's Avatar
maybe adding soem mesh in the holes would look nice. its got a nice look tho, very futuristic looking or some thing, im thinkin of doing somethign like this to my ae cover. thanks, like i needed more projects!
ColdSHO is offline
Old 12-03-2005, 10:56 PM
FASSTER's Avatar
Awesome job,I deff. like it. Let me know when/how I can get one of them.
FASSTER is offline
Old 12-03-2005, 11:37 PM
Igor911's Avatar
it only shines because you have clear coat on it
Igor911 is offline
Old 12-03-2005, 11:47 PM
Go BUCKS!!!
SEmy2K2go's Avatar
Very unique. Looks nice.
SEmy2K2go is offline
Old 12-04-2005, 05:06 AM
NJ Devils Fan's Avatar
Great job, looks awesome. I was thinking about painted mine like a black and white checkered design. Nice job bro!
NJ Devils Fan is offline
Old 12-04-2005, 06:07 AM
GBAUER's Avatar
I don't remember. That was back when I was making so much money I threw it away. I think it was around $100 or so, but it was wrapped in with replacing my front bumper and painting my grill.
GBAUER is offline
Old 12-05-2005, 09:33 AM
Play with my balls
Deckdout2's Avatar
Thanks I might take you up on that. I'm waiting to see how soon I can do my new intake conversion first. I'll let you know if I need it.
Play with my balls
Deckdout2's Avatar
I'll be in touch.
Old 12-05-2005, 09:36 AM
Play with my balls
Deckdout2's Avatar
Vented EC> Painted Only EC
Old 12-05-2005, 09:37 AM
Play with my balls
Deckdout2's Avatar
no FI, no care
Old 12-05-2005, 09:38 AM
Play with my balls
Deckdout2's Avatar
My fiance's AE EC will be my next attempt when this one is completed.
Old 12-05-2005, 09:39 AM
Play with my balls
Deckdout2's Avatar
As soon as the mesh and emblem comes in, this will be complete. You are encouraged to inquire at anytime you are ready.
Old 12-05-2005, 09:41 AM
Play with my balls
Deckdout2's Avatar
I can create a wavey checked ventilation design for you and carry out the finished product. Let me know if you're interested.
Old 12-05-2005, 10:26 AM
AcerX's Avatar
Wow, that does look good. The vents will help some with heat dissipation but you do know that paint itself helps hold in heat? That is why most serious drag or racing applicated vehicles do not have painted engines. But serious props on the craftsmanship though.
AcerX is offline
Old 12-05-2005, 11:37 AM
Woody's Avatar
hmmmm
Why ? heat is not an issue with a engine cover. All they do is clean up the bay alittle.
Woody is offline
Old 12-05-2005, 12:08 PM
chr0nos's Avatar
the fire blanket/heat wrap that's attached to underside of our hoods is what keeps most of the heat in the engine bay. i congratulate you on great clean work, and effort, but head dissipation is not going to change much from what it was originally. i think its going to look very cool with the mesh behind ec, but functionality wise, it's not that useful.
chr0nos is offline
Quick Reply: Project EC.....Something new for the org
