Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-04-2001, 05:23 AM   #1
lymby
Has anyone had any problems with the little motor that assists the CD entering the player. It gets stuch but I can hear the motor running on it.
Just throwing this out there, maybe someone has had the same prob.
thanks
Old 06-04-2001, 07:33 AM   #2
thanks
No, I haven't, but jump on getting it to the dealer, who should happily charge Nissan for a warranty repair to replace the unit. It just shouldn't get stuck.
__________________
Midnight Blue 2K2 I-35, replacing my (totalled) 2K1 GLE, has the K&N drop-in, Stillen FSTB, Stillen RSB, and that great Zaino shiny finish!
umpopa is offline   Reply With Quote
Old 06-04-2001, 08:07 AM   #3
Quote:
ha!!! Happily?? watch!! once you get there, it will work flawlessly for them!!! Then, they i will proceed to try and convince you that you are simply imagining it, or WORSE, that it is YOUR fault.. let us know.
-Tom Z.
tomz17 is offline   Reply With Quote
Old 06-04-2001, 08:26 AM   #4
Send a message via AIM to mbcp_tdogg
Quote:
-Tom Z.
mbcp_tdogg is offline   Reply With Quote
Old 06-04-2001, 09:37 AM   #5
Send a message via AIM to jashick
thanks
I had a problem where upon attempting CD insertion, that motor would continue spinning but would not allow the CD to be inserted... and had to wait a few minutes for the motor to turn off. Well, I found that it only happens with burned CD's... I'm guessing it has to do with the tolerance in thickness of CDR's.
Do you have any problems with original CD's?
jashick is offline   Reply With Quote
Old 06-04-2001, 09:46 AM   #6
CD Skipped
I had my Bose unit replaced a while back because my CD kept skipping (even while the max was motionless).
tdogg: looks like we have our wish (Lakers/Sixers). Hopefully, we can provide a little comp then SA did. Hopefully.
92drexel is offline   Reply With Quote
Old 06-04-2001, 10:24 AM   #7
Hmm... i play exclusively burned cd's.. and am sure that i have used several different cdr media.... (no probs so far)
What brand caused you problems??
-Tom Z.
Old 06-04-2001, 11:16 AM   #8
Send a message via Yahoo to nisMAXse
I had a problem with an original CD. It inserted/played fine, but when I tried ejecting it...it got stuck and I could see the edge of the CD wanting to come out. I eventually got it out. No other CD's have done that since! Go figure.
__________________
~~mp
2001 Merlot SE, 5spd
nisMAXse is offline   Reply With Quote
Old 06-04-2001, 12:08 PM   #9
Re: CD Skipped
Old 06-04-2001, 12:43 PM   #10
Generic silver top blue bottom, generic white pressed top blue bottom, some generic gold, Some Maxells... some Imations...Thing is that it also depends how it the CD was burned.
If I just do a close CD, every CD player I use has a tough time finding tracks and skips around a lot. If I do the close with disc at once option, it seems to play fine in most instances. Haven't had a problem yet with the TDK's from costco...
Also, if there's other activity on the scsi bus during the burn, the CDR usually ends up as a frisbee.
Old 06-04-2001, 01:24 PM   #11
I too run all different types of CDRs and have no problems yet
ed571 is offline   Reply With Quote
Old 06-04-2001, 06:13 PM   #12
i havent motor problems but i did have one huge prob...the whole stereo went dead as in the cd would play and when i tried to skip to another track it would just keep playing and when i pushed the AM/FM button i would show the station but the CD kept on playing...it went away when i turned off the car and pushed the eject button..guess it got possessed or something
kryptonite is offline   Reply With Quote
Old 06-04-2001, 09:54 PM   #13
Hmm... i still use an ole IDE burner, and have no probs. whatsoever.. While burning a cd, my computer happily allows me to photoshop, surf the web, watch a movie, or frag some friends in counter-strike... No burn proof!!! if that isn't a testament to the usefulness of multi-processor systems, I dunno what is!!!
-Tom Z.
PS.. ALWAYS ALWAYS ALWAYS leave 2 second gaps on your cd's... my stock radio skips around like mad trying to find tracks if I do anything less than 2 seconds btw. tracks... Oh, and why wouldn't you close an audio cd automatically??? (unless you were planning to add some additional tracks at a later date).
Old 06-04-2001, 10:13 PM   #14
-Tom Z.
Thanks for the word of advice... but if I don't do the disc at once option (no 2 second gap), then it skips like there's no tomorrow. Point is that there are many variables that will lead to a frisbee and that it's not always the bose HU that is the problem. Burned one CD that plays fine in the car, but skips like mad in a new home cd player... and vice versa.
Old 06-04-2001, 10:19 PM   #15
Oh, I believe you... I have always lef the DOA on (saw no reason to turn it off). However, I was just specifically pointing out that my stock radio couldn't handle anything less than 2 second gaps (wheras other cd players I have don't have a prob. with 1 second gaps). Perhaps this might help someone from burning a coaster...
-Tom Z.
Old 06-04-2001, 10:39 PM   #16
lymby
ok heres the deal
i tried some cd-r and it worked fine. then i tried some of my other discs and they worked fine. it was that cd only. go figure. it still doesn't go all the way in. what is up with that. it feels like the motor is laboring to get it in. i think maybe it is slipping on the surface of the cd. it is brand new never been touched so i think the surface was too slippery or somthin.
one thing i have found weird is occasionally i will listen to a cd. if you have a 2001 the controls are on the steering wheel. when i changed the track with the steering controls the cd player just turns off. this only happens once in while and it has happened with several discs. not only burned ones.
whatever, if it works most of the time i'm not going to bother complaining to nissan.
out
Old 06-04-2001, 10:54 PM   #17
CD-RWs?
anyone's BOSE system play CD-RWs burned with audio?
i was surprised to find out that CD-RWs play on mine
MajesticBlueNTO is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
