02-03 Bose 6CD changer Audio cutout fix!!
Old 03-01-2008, 09:12 AM
  #121
L.M.L.
not a real fix ((.... i did this about a month ago, drove happy for a while, and just few days back, doing hard left turn with braking, guess what, NO left side again!!! hoover dam!!!
  #122
Prophecy99's Avatar
Originally Posted by croser2
Just bumping because I just did this and it fixed my problem. Worked great. Yeah, a few extra screws not shown, but no soildering and I only removed 2 springs and isolators. Easy peasy
can you enlighten us a little more on how u didnt soilder anything? im interested as I could handle all of the above except the soildering(atm) and...im only skeptical if that "fix" will last long..as that would be my largest priority?
Prophecy99 is offline
Old 03-01-2008, 09:16 AM
  #123
Prophecy99's Avatar
do you mean the fix in general or...the non soilder?
yeah....i can relate...you tend to want to repeat the motion to get it back......
Old 03-01-2008, 11:53 AM
  #124
jasonmax's Avatar
when you doing the board in the CD player. there are 2 screws down the bottom, and you just unscrew them.
I pulled out the ribbon once, and I worked for 2 months.
When I did it for the second time, I put 3 layers of Scotch tape on the back of the ribbon where it goes into the socket for more presure, problem solved.
jasonmax is offline
Old 03-02-2008, 10:24 AM
  #125
macnolias's Avatar
Can someone answer as to how to take the head unit out of the dash to begin with?
Just tug on the ac unit from the top and it should come out? Then there should be a couple of bolts at the top of the bose to take it out? Correct?
macnolias is offline
Old 03-02-2008, 03:46 PM
  #126
chak5050's Avatar
On my 2000 the sounds cuts out too, was wondering if the Headunit in my Bose radio without changer contains the ribbon that causes this, if so I might give this a try.
chak5050 is offline
Old 03-03-2008, 01:47 PM
  #127
Maxgig's Avatar
There is a new ribbon you can buy that costs about $7 dollars instead of re-using the old one or putting scotch tape on it and hoping that it works.
Maxgig is offline
Old 03-03-2008, 05:13 PM
  #128
jasonmax's Avatar
it actually works, and works very well.
is there a new ribbon?
jasonmax is offline
Old 03-13-2008, 02:17 AM
  #129
MIK3's Avatar
Well, I just went through the tutorial pdf that was posted, and 4 1/2 hours later, no skipping! I'm very excited and don't really care that it's not a complete permanent fix as I plan to upgrade audio within a year or two. I now see why the cheapest to fix this is like 180 bucks. Very tedious, but worth it in the end. I can now listen to CD's again. Thanks again for the write up, helped a ton.
MIK3 is offline
Old 03-13-2008, 12:51 PM
  #130
Maxgig's Avatar
Definitely take your time because you will have screws everywhere if you're not careful. I printed out 2 copies of the instructions and laid my screws on that page in the order I took them out. This helped me big time when I was putting it back together. All in all it was about 4 or 5 hours.
Maxgig is offline
Old 03-13-2008, 06:59 PM
  #131
I am everywhere
SO Speed's Avatar
Thanks for all the info, it was helpful. however in the end i just decided to replace it with a clarion in dash pop up DVD player. I'm lovin it.
SO Speed is offline
Old 03-28-2008, 06:38 AM
  #132
sansanich's Avatar
My Bose Player is unable to play CDs. When I put the CD in, it makes noises like it is trying to read it, but eventually ejects it with an "Error" message. I tried multiple CDs, in the past, entering quality CDs would fix the problem; however, now none of the CDs work. I noticed, it started happening when the weather got cold. Did anyone expereince such an issue? If yes, what can be done to resolve it? Thanks for your help!
sansanich is offline
Old 03-30-2008, 01:46 PM
  #133
Maxgig's Avatar
Sansanich,
I think your CD changer is shot. That happened to a friend of mines player so he just bought a new radio. You can replace it with something aftermarket, buy a used one off EBAY or from someone here, or send it in to get it fixed, (not cheap).
You will have to swap out the CD changer portion in order to fix the problem; it's not hard just a lot of small screws to keep track of. Good luck whatever route you go with.
Maxgig is offline
Old 09-01-2008, 08:42 AM
  #134
Apollos2's Avatar
These links are broken....... are there new ones posted up? I've refered people to this thread often, since it's such a common problem. It was a great write up and the pics that Chris.S posted were awesome, full of step by step detail. Any chance we can get those back and sticky it?
Originally Posted by Chris.s
Here is a way to fix your Audio from cutting in and out (or if you have none at all). The solution is most likely not permanent but it should buy you at least a year or 2.
Lots of pictures and a step by step walkthrough can be found here
http://www.yourasic.com/Maxima_02-03...dio_repair.pdf
e-mail any questions.
Regards
Chris
Originally Posted by zagzig
I'll leave this up for a couple days.
http://home.comcast.net/~drwutwo/Max...dio_repair.pdf
Apollos2 is offline
Old 09-01-2008, 03:20 PM
  #135
phatmax95's Avatar
Try this:
EDIT: Check post #142 below...
phatmax95 is offline
Old 09-02-2008, 09:07 AM
  #136
Apollos2's Avatar
Originally Posted by phatmax95
Thats the one!! Thanks!
Apollos2 is offline
Old 09-09-2008, 08:49 AM
  #137
hehehh's Avatar
thanks +1
hehehh is offline
Old 09-30-2008, 08:36 AM
  #138
ikalinin's Avatar
thank you +2!!!
ikalinin is offline
Old 12-31-2008, 06:58 PM
  #139
Dutchymtl's Avatar
I'm experiencing CD Player problems also.
Poor quality playback, hitting top of player (dashboard) helps a little sometimes but left speaker has practically no sound most of the time.
Tried the link to mediafire but folder is currently" empty again. Please help.
Any other link to this document ??
Thanks.
Dutchymtl is offline
Old 01-02-2009, 10:33 AM
  #140
KingFreako's Avatar
I have this problem with an aftermarket HU (Pioneer DEH6000). Does anyone know why that might be? I have a 2002 Maxima SE, and I replaced the Bose CD headunit a couple months ago.
KingFreako is offline
Old 01-02-2009, 01:07 PM
  #141
ZXTwnT300's Avatar
I am gonna attempt this I guess. I am usually really good with stereo stuff but this one is a little intimidating for some reason!!
ZXTwnT300 is offline
Old 01-02-2009, 03:18 PM
  #142
phatmax95's Avatar
I re-upped the document for you guys:
http://www.mediafire.com/?ygtdjmoxm3k
Old 01-03-2009, 05:09 AM
  #143
Derrick2k2SE's Avatar
It's really not as hard as it looks. The instructions are very well layed out. Just be sure you have somewhere to put all the different tiny screws. I keep an old egg carton for jobs like this.
I would recomend replacing the cable instead of reusing it. I tried reusing it and the problem came back. It was a lot better but would still fade out. I just did it again using a new cable and it's been perfect. The cable was only a few dollars shiped. Well worth it considering the time it takes to do this.
Derrick2k2SE is offline
Old 01-03-2009, 12:19 PM
  #144
overbo0st2k4's Avatar
Where would you recommend buying a replacement ribbon for this job?
I plan on doing this tomorrow (if i can buy the ribbon locally)
Thanks a bunch!
overbo0st2k4 is offline
Old 01-04-2009, 06:27 AM
  #145
There was a link it the supplier somewhere in this thread but a lit of the links are dead. I don't remember where I got the ribbon now.
Old 04-18-2009, 11:49 AM
  #146
mnm0101's Avatar
Need Help With CD Audio Problem
Hi!
I tried finding the solution to my problem but wasn't lucky.
I have 02 Nissan Maxima GLE with std. Bose stereo system. The problem is that the audio track play intermittently, like they will play for a few seconds and then stop/break. It happens on all CD's. My FM radio works fine though. Is this a simple lens cleaning issue or something else. I have never had to deal with something like this before so I am not really sure what to do!
Thanks in advance!
Mak
mnm0101 is offline
Old 04-18-2009, 09:43 PM
  #147
jamiforums's Avatar
I found a solution, a relatively easy way to add a direct line input to our Bose stock head unit without sacrificing any existing functionality by using the tape deck inputs of the internal amplifier. Please reply if you're interested.
jamiforums is offline
Old 04-19-2009, 01:21 PM
  #148
macnolias's Avatar
I'm interested and than some... you going to make a writeup on it?
Old 04-20-2009, 12:16 AM
  #149
jamiforums's Avatar
I'm not going to write up anything since I don't have time. I'll post some pics tomorrow. It's very easy to do. And the sound quality is even better than CD.
Old 04-20-2009, 12:00 PM
  #150
macnolias's Avatar
So by using the tape deck input you're talking about being able to use an 02-03 bose head unit and using the tape input to be whatever you have hooked up the input.... Hopefully I understood correctly?
Old 04-20-2009, 10:29 PM
  #151
jamiforums's Avatar
Old 04-21-2009, 03:22 PM
  #152
asta4's Avatar
Great job! Could you explain which wires are which in the first picture?
asta4 is offline
Old 04-22-2009, 07:39 AM
  #153
macnolias's Avatar
the new way works!!!!!!!!!
Old 06-14-2009, 06:29 PM
  #154
TallTom's Avatar
Can someone please rehost the PDF for me? None of the links work.
TallTom is offline
Old 06-15-2009, 09:06 AM
  #155
str8max's Avatar
Whats the new way?
str8max is offline
Old 06-17-2009, 01:05 PM
  #156
6SPD03Max's Avatar
Try this link http://www.shiftice.com/Maxima_02-03...dio_repair.pdf
6SPD03Max is offline
Old 06-17-2009, 03:28 PM
  #157
TallTom's Avatar
Originally Posted by 6SPD03Max
thank you!
TallTom is offline
Old 06-19-2009, 09:18 AM
  #158
nzelinsky's Avatar
Can you repost the pdf?? I have this problem and would like to try the fix but I cant get the file...
NEVERMIND IT WORKS...
nzelinsky is offline
Old 06-20-2009, 07:45 AM
  #159
Prophecy99's Avatar
I havent gotten around to doing this. I kinda got used to it over time.. as it is just cds anyway. I am thankful these things have the tapes though!
Note: I have noticed during long trips.... the electrons build up enough at the broken connections to find a way to bridge the gap and actually create a full connection! and 30mins into a trip and the cutouts are eliminated. I had tested it a few times now.
Old 08-28-2009, 01:31 AM
  #160
coldfear13's Avatar
^^Interesting, I had similar results, of playing for a while with the side being cut off, and then it would turn on by it self, but only until I hit the next bump on the road, worked only for a few seconds.
Trying to order the ribbon cable from Pac Parts: IBBON CABLE, 45P (J101 TO J1) Part Number: 039195701
The price of the cable is $4.88 and the shipping is $11.50 lol (shipping sucks!)
Going to be doing this fix as soon as the new ribbon cable arrives, will definitely post feed back (so far everyone has positive responses, which is great). Really hope I wont have to solder anything, although it doesn't seem difficult.
Just one question: How hard was it to removing the HU from the center console and a few steps after that? Any special tools needed? (except for a wide range of small Philips drivers)
Thanks to everything in this thread, you guys are awesome!
coldfear13 is offline
Quick Reply: 02-03 Bose 6CD changer Audio cutout fix!!
