steering wheel shakes and turns when braking
Old 09-27-2005, 02:26 PM
roll4life's Avatar
so lately its getting worse and worse even when stopping from 40mph my steering wheel is starting to vibrate and the steering wheel just turns by itself..my allignment is way off but i dont know if thats whats causing the vibration
roll4life is offline
Old 09-27-2005, 02:29 PM
teddibear703
JdoubleOe703's Avatar
maybe warped rotors and bad alignment...
JdoubleOe703 is offline
Old 09-27-2005, 02:32 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
Warped rotors. Yay Nissan engineering.
Metal Maxima is offline
Old 09-27-2005, 02:43 PM
MaximaPolak's Avatar
Get an alligment and change the rotors.
With Irotor, I haven't had any vibration under the heaviest of breaking.
MaximaPolak is offline
Old 09-27-2005, 02:51 PM
krazysashka's Avatar
Have the same problem but my allignment is good. Should I change rotors as well? or is it something else?
krazysashka is offline
Old 09-27-2005, 04:07 PM
teddibear703
any shaking while braking is usually warped rotors....
Old 09-27-2005, 04:08 PM
teddibear703
I believe you can get them resurfaced so they are smooth once again, but the warped rotors are caused by hotspots so the resurfacing is a short term fix....
correct me if i'm wrong...
Old 09-27-2005, 05:06 PM
Puerto Rico-Maxima Lover
Lontar1's Avatar
if you have the $$$ just replace the rotors at the end you will have to replace them anyway.
Lontar1 is offline
Old 09-27-2005, 07:39 PM
roll4life's Avatar
hmm yea rotors are deffinetly on the list now, but do you guys think i can drive for a few more months untill i save up for them or is this risky?
Old 09-27-2005, 08:02 PM
Lontar1's Avatar
That is up to you. You won't have any problems, but if you complain about the vibration.. trust me it is going to get worse.......
Lontar1 is offline
Old 09-27-2005, 09:15 PM
roll4life's Avatar
i can deal with the vibration as long as my breaking doesn't suffer since winter is starting, i need good breaks..jeez this sucks
Old 09-27-2005, 09:19 PM
Go BUCKS!!!
SEmy2K2go's Avatar
It will get worse over time. As well as being annoying, it will become more of a safety issue. Try not to let it go on too long.
SEmy2K2go is offline
Old 09-27-2005, 09:42 PM
roll4life's Avatar
yea i will try to get new rotors as soon as possible..thanks everyone
Old 09-27-2005, 10:03 PM
DJ2Max's Avatar
do you have to replace all 4 rotors?
DJ2Max is offline
Old 09-27-2005, 10:30 PM
Go BUCKS!!!
SEmy2K2go's Avatar
Typically not. The majority of the warping issue is from the fronts. However, inspecting the rears and possibly changing the rear pads may be something to consider while doing the fronts.
Old 09-27-2005, 11:18 PM
RR5
RR5's Avatar
You could change them out yourself, its really not all that hard.
I'd recommend the Powerslot rotors and Hawk performance front brake pads.
I got those put on and now I have no steering wheel pulse/vibrations during braking.
For winter braking, I'd suggest driving around the block once or twice with your foot on the brake pedal just enough to cause the vehicle to slow and giving it gas to keep the car moving. This would heat the pads and rotors so when you need to jerk stop, everything's warm enough to get you stopped quickly. (anyone got more experience care to elaborate or clarify?)
RR5 is offline
Old 09-28-2005, 05:52 AM
Play with my balls
Deckdout2's Avatar
Side Note Question: I have this exact same issue. Especially under braking, but the vibration/pulsing also occurs when my car is moving with or without acceleration. Would this also be a warped rotor issue?
Deckdout2 is offline
Old 09-28-2005, 08:52 AM
AcerX's Avatar
You will definitely be able to tell when its about to get too dangerous when your ABS starts to really kick in under breaking that is not that heavy. It will scare the **** out of you. Took my car to get new brakes the next day.
AcerX is offline
Old 09-28-2005, 09:16 AM
Quoting myself
I paid $307 for all four rotors. They are zinced, Xdrillled, and slotted.
Old 09-28-2005, 03:59 PM
NizanDrivn's Avatar
Wheel balance off...maybe rotors are warped too....
NizanDrivn is offline
Old 09-28-2005, 05:07 PM
WildmanAL's Avatar
It only happens when braking so that completely eliminated anything having to do with wheel balance or alignment. If a brake line is kinked or restricted it will cause the steering wheel to turn when braking. You should pull the wheels off and inspect the lines for kinks and pads for wear. Worn out pads along with the warped rotors would cause what you are describing. A cheap solution to your problem is to find someone in town that will turn rotors. I have a place here in birmingham that if you bring in the rotors they will turn them for $6 and if your pads are above 4/32" just sand the surface of the pads down to get all that black glaze off and you should be good as gold.
WildmanAL is offline
Old 09-28-2005, 05:09 PM
Play with my balls
Deckdout2's Avatar
i have new rims and tires, but i'll get that checked also. hopefully it goes away after i put my new rotors on. thanks
Old 09-28-2005, 06:22 PM
jitmoney's Avatar
I have a similar issue with my 2k1 Maxima, but in my case the rotors were beginning to rust. My problem was the inner tie rod which i'm getting replaced tomorrow. I understand there is a TSB out on it but I have no idea how to get a detailed description of TSB's anyone know?
jitmoney is offline
trasmadean
02-01-2017 08:20 PM
vingodine
45
05-21-2016 12:46 PM
02nissmax
09-05-2015 01:50 PM
tnewbs
08-28-2015 10:15 AM
jhontelj
08-17-2015 04:07 AM
Quick Reply: steering wheel shakes and turns when braking
