how does air get in the oscai?
the tube just hangs about 1-2 inches above the splash guard, with no bends... im wondering how air gets in there at all, wouldn't the air that goes in through the grill actually exit through the oscai tube, limiting air instead of increasing it ? or did i f up the oscai ?
(yes i searched but it seems like all there was, was the 'straw example' in which there didn't seem to be a consensus)
thanks
thanks
thanks
thanks
The fact that the OSCAI produces a performance gain is attibutable to the fact that the stock air intake isn't capable of supplying as much air as the engine can ingest at WOT.
Originally posted by DooBall
whats the typical hp gain with the OSCAI?
Originally posted by UMD_MaxSE
the real gains of this setup are seen when the car is moving, so it's tough to get an accurate estimate from a dyno....but i Don't know if anyone has dyno'd it.... people's 1/4 miles times have gone down with it though from what I have heard.
thanks
thanks
in order to prevent stuff going in, I made a cover with mesh wire (grill). hope in wont reduce air flow.
Originally posted by mdeal
I thought it has been stated 1/4 times have been improved with the OSCAI? You are saying the times have gone down.
Originally posted by psing23
OSCAI's RULE!!! except that as soon as Hogan finishes his Intakes i will have one of those... they just sound sooo much meaner...
I know that several 5th Gen Maxima owners use underhood intakes successfully and I suspect that I could probably reistall an underhood intake now that my detonation problem has seemingly been corrected. But there's no doubt that our high-compression engines are finicky when it comes to ingesting hot air. If you don't believe me, check out:
http://forums.maxima.org/showthread.php?threadid=41879
tarun900
19
12-20-2021 06:57 PM
