Oil in one of my spark plug cavitys...
Old 08-19-2005, 12:14 PM
fornimage's Avatar
I was changing my spark plugs when I noticed that the ignition coil in the rear bank, driver side, had some greasy spots around it. Well, to my surprise, there was oil in the spark plug cavity(1/4 full I would guess judging from how much oil was on the socket and the plug). Did anyone else experience this happening to them? I am guessing that there is some sort of seal under the valve cover in the area of the spark plug? Thanks in advance.
fornimage is offline
Old 08-19-2005, 12:33 PM
zmax26's Avatar
Yup, valve cover gasket. You'll need new wires and plugs also.
zmax26 is offline
Old 08-19-2005, 04:10 PM
woosh's Avatar
I think this is a known problem. I've seen a nice thread here before with somehting like "fixed another problem with the .." but can't find it to help you out. According to the post the 4th gens suffer from it also.
woosh is offline
Old 08-19-2005, 07:34 PM
fornimage's Avatar
Man, this sucks. Now I have to reomve the intake plenum again!
New wires? You mean I actaully need to buy a new ignition coil?
Old 08-20-2005, 08:34 AM
BewstAdd1ct's Avatar
you MIGHT be able to clean it.
you might also be able to get just the boot separately. you can separate them, at least on the vq35...
BewstAdd1ct is offline
Old 09-05-2005, 04:11 PM
ABS
ABS's Avatar
Just discovered I have the same issue. This doesn't seem right. It must be caused by excessive pressure in the rear valve cover which is forcing the oil past the gasket in the cover. Did you ever figure out what was happening?
ABS is offline
Old 09-05-2005, 07:58 PM
JohnnyJet's Avatar
sounds like a nightmare is this a common condition? Im a newbie
JohnnyJet is offline
Old 09-05-2005, 08:10 PM
adriand's Avatar
I had the same problem when I changed my plugs. I cleaned as much of the oil out that I could and it seemed like the plug wire sealed the tip of the plug pretty good so no oil was on the tip when I pulled it out. Since it was to late for me to get new gaskets I put everything back and it seems fine except that it idles a little funny.
adriand is offline
meh, id say have a valve cover gasket on hand when you do spark plugs, lol...
Old 09-06-2005, 11:44 AM
okay's Avatar
could oil in one of the cavities cause the car not to start? one of my friends changed his spark plugs and found oil in one of the cavities and his car doesn't want to start at random times, could this be the problem? he can crank it and you can hear it trying to turn over but nothing will happen, ocassionally it'll start up but abruptly die if he doesn't hold the rpm's up
any ideas?
okay is offline
Old 09-06-2005, 11:56 AM
Do I get a tax break?
njmodi's Avatar
As already stated the problem is a faulty spark plug tube seal in the valve cover. The only way to fix it is to pull the valve cover and replace the seal. There are 3 seals, one for each plug, plus the main gasket for the valve cover. I imagine that if the problem is left uncorrected, you will eventually destroy the coil (expensive to replace) and plug.
njmodi is offline
Old 09-06-2005, 03:46 PM
ive seen it happen. not on a maxima, but the concept still applies
Old 09-06-2005, 03:58 PM
I Miss My Maxima
paralyse's Avatar
Okay: Bad MAF or cam/crank sensors, but my money's on the MAF.
NJmodi: I've been driving mine with leaking tube seals for >30k miles, the coils are fine.
paralyse is offline
Old 09-06-2005, 04:41 PM
njmodi's Avatar
That's good to know... since I have no idea when mine started leaking.. The last time I took the coils out was at 60k... now I'm at 120k and was doing the plugs again and thats when I noticed the oil on one of the coils... I've replaced the seal (last week)... so I'm keeping my fingers crossed!
njmodi is offline
Old 09-06-2005, 05:47 PM
super6's Avatar
wow mush be a biatch to change the rear valve cover gasket
super6 is offline
Old 09-06-2005, 06:11 PM
ABS
ABS's Avatar
It isn't hard to replace the valve cover gasket, but it is a PITA to actually get to the valve cover in the first place. My strong recommendation is that anyone doing a spark plug replacement on a 5.5 gen have a rear valve cover and replacement gasket available at that time. The individual cylinder seals do not appear to be servicable.
ABS is offline
Old 09-06-2005, 07:29 PM
njmodi's Avatar
I agree completely... the valve cover gasket and tube seals are easy... its pulling all the stuff above it off that makes the task tedious.
Really? That's interesting... On the 4th Gens, the valve cover has these seals that press into it from below (before you put the valve cover back on the heads)... you can see where mine has cracked.
njmodi is offline
Old 09-06-2005, 08:03 PM
ABS
ABS's Avatar
hmmm . . . now you've got me wondering about that = I'll call back David Burnett tomorrow and see what he says.
ABS is offline
Old 09-06-2005, 09:08 PM
njmodi's Avatar
Let us know what you find...
njmodi is offline
Old 09-07-2005, 03:20 PM
yes, and get a p/n if theyre available separately.
Old 09-07-2005, 03:29 PM
fornimage's Avatar
Really? I called the dealer a couple of weeks ago and he was able to give me a price for the parts I thought were available. Can someone confirm whether we have to buy an entire valve cover or separate parts are available? I guess I'll have to call another dealer to see what they say if no one else knows.
Old 09-07-2005, 03:36 PM
GBAUER's Avatar
If you have a 3.5, you need to replace the entire valve gasket. I had to do mine a while back for the same reason you guys have. And, yes, the intake manifold is a PITA!
GBAUER is offline
Old 09-07-2005, 03:54 PM
ABS
ABS's Avatar
Yes, I just confirmed with David B. that the entire unit needs to be replaced - the individual seals/rings are not available for the 3.5 on their own. Of note, the 2004 parts should fit the 2002 and 2003 engines without any problems but are much cheaper AND the valve cover comes with a new PCV valve included!
ABS is offline
Old 09-07-2005, 04:08 PM
will you please send me a USED o-ring from the tube.
PM me for an addy
...thx
Old 09-07-2005, 05:05 PM
njmodi's Avatar
PM me for an addy
...thx
Are you talking to me?
njmodi is offline
Old 09-07-2005, 05:31 PM
2002 Maxima SE's Avatar
Is the valve gasket now being stocked at my Nissan dealer a revised piece or will the new gasket blow out as well?
2002 Maxima SE is offline
Old 09-07-2005, 05:59 PM
fornimage's Avatar
Interesting. Thanks for that info.
Old 09-07-2005, 06:16 PM
eclane's Avatar
Do you have the part number and/or price? I replaced my sparkplugs a couple months ago, and I definitely had oil in the tubes.
eclane is offline
Old 09-07-2005, 08:05 PM
ABS
ABS's Avatar
I don't have the part number available but I should be getting my shipment tomorrow. I will try to post part numbers tomorrow night. If IIRC the cost for each valve cover was about $35-40 for the 2004 parts but more like $100 each for the 2002 parts. David also confirmed for me that the 2002 valve cover gasket will fit the 2004 valve cover . . .
ABS is offline
Old 09-08-2005, 02:55 PM
anyone who is willing to send me one
Old 09-08-2005, 02:56 PM
njmodi's Avatar
Just curious or...? Shoot me a PM with your address... and I'll see what I can do.... don't think it will make it in a standard envelope.. or will it?
njmodi is offline
Miket2006
03-01-2021 03:55 AM
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Oil in one of my spark plug cavitys...
