Speedometer problems help!
Old 07-15-2005, 07:27 PM
Curb Rash Repair 100 a wheel
Maxima112's Avatar
hey wassup guys, well these past two weeks my speedometer has not been working 100%....it gets stuck at around 60 and most of the time it doesnt go past that, and when i stop it stays at 60......anyone got a solution for this problem>??
on a side note: do the 01, 02,03 speedometers plug and play to an 00 maxima?? And one last question. if i where to just buy a new one regardless of year (given the newer years work on mine) where or how can i reprogram the miles to match mine? thanks in advance!
Maxima112 is offline
Old 07-15-2005, 07:48 PM
G4nismo's Avatar
do u have reverse glows?
G4nismo is offline
Old 07-16-2005, 09:46 PM
Maxima112's Avatar
nope, stock minus paradox rings..... any suggestions anyone?? BUMP
Old 07-16-2005, 09:51 PM
ghostdog4's Avatar
ANyone seen any oil problems. My 2002 used to eat a couple of quarts a week.
ghostdog4 is offline
Old 07-17-2005, 05:03 AM
jkayca's Avatar
Stop hijacking and create your own thread.
Onto Maxima112's problem. It sounds like the speed sensor is acting up. Do you see oddities with the odometer to?
jkayca is offline
Old 07-17-2005, 04:59 PM
Maxima112's Avatar
thanks! yeah man make your own thread...actually no, only the speedometer is acting up....everything else seems to be working fine.....do you or anyone know if i could take it apart and maybe oil it or something?? another thing that i noticed now...it doesnt go past 60 MPH......please help me! thanks
Old 07-17-2005, 08:06 PM
maseo77's Avatar
My speed sensors went bad, you should be throwing a code because our speed sensors are in the front wheels.
maseo77 is offline
Old 07-17-2005, 10:58 PM
scopium
if you pay close attention your rings have been misplaced..
same thing happened to me
take out your cluster.. and just fix the rings in place.. you should be fine..
Old 07-18-2005, 06:06 AM
jkayca's Avatar
Both the odometer and spedo feed off the the speed sensor. I would expect both instruments to go wonky if it was a problem with the sensor or the wiring. The speed sensor on my Shadow used to cut out once in a while. The spedo would stay stuck at the speed I was driving and my odometer would stop counting the miles
Since the odometer is working I would suspect the spedometer itself. You may have damaged or misaligned it as scopium suggests.
jkayca is offline
Old 07-18-2005, 09:19 AM
Maxima112's Avatar
well actually ive had teh rings for about three years now....the speedo is just acting up now... could the heat move the rings??? any other suggestions?? thanks guys for the reply. ill double check that today.
Old 07-18-2005, 09:24 AM
AcerX's Avatar
on a side note: do the 01, 02,03 speedometers plug and play to an 00 maxima?? And one last question. if i where to just buy a new one regardless of year (given the newer years work on mine) where or how can i reprogram the miles to match mine? thanks in advance![/QUOTE]
I am only certain that the 2001's are interchangable (because they are the same as an 01, not including the AE). Don't knpw about 5.5ers though.
AcerX is offline
Old 07-18-2005, 10:23 AM
scopium
the 00-01 are plug and play.. not the others..
also the cluster is a OUTPUT device ONLY it holds no memory of any kind. all that is stored in the ECU.
so whatever cluster you put into it.. it will show YOUR car mileage.
and Maxima112
just fix your rings.. and you will be set..
Old 07-18-2005, 12:34 PM
Maxima112's Avatar
and Maxima112
cool, sounds good ill try to today. thanks for the answers guys. if that doesnt work looks like im gonna be getting an 00-01 speedo. thanks again.
Old 07-18-2005, 08:14 PM
bsetiawan's Avatar
and Maxima112
I think you are wrong. The mileage is stored in the cluster itself, not the ECU.
bsetiawan is offline
Old 07-18-2005, 08:24 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
and Maxima112
Absolutley not. I know this first hand.
Metal Maxima is offline
Old 07-18-2005, 10:00 PM
Maxima112's Avatar
yeah i heard you have to reprogram it....but anyways, they are fixed !!! yay!!! i guess after parking it in Lancaster (105+ degrees) it melted some of the glue, hahah but its ok now. thanks again to the org. saved my self 60-100 bucks ( i was planning on buying a new cluster)
Old 07-18-2005, 10:02 PM
Another satisfied customer. Maybe it's time to...
Old 07-18-2005, 10:12 PM
Maxima112's Avatar
yea i think i will give me a few days, ive always wanted to, but the college budget comes into play, now that i have a job ill do it when i get my next pay check.
Old 08-20-2006, 02:03 PM
jif718's Avatar
Would a 2000 GXE take a speedo from 01 anniversary w\o Traction or only non anniversary
jif718 is offline
Old 10-20-2022, 01:50 PM
robsaun's Avatar
I know this post is over 15 years old. However, this is the only post I can find that describes my exact problem. My new to me 07 Maxima speedometer will ocassionally stick at 60 mph. I see someone mentioning the rings but im not sure what theyre referring to or how to fix it. Can someone please elborate. Also my fuel gauge on occasion will go all the way to full even though the fuel light and distance till empty display will stay accurate and working. Suggestions for a newbie and first time Maxima owner.
robsaun is offline
Old 01-04-2024, 07:55 PM
TheBus's Avatar
Speedometer
Hello Robsaun,
I have the exact same problems with my 07. Did you find a resolution?
TheBus is offline
Old 01-05-2024, 11:41 AM
CMax03's Avatar
The speedometer issue are definitely a Nissan issue throughout there entire lineup. I have a fuel gauge issue tested wiring and it's more than likely a print is failing so I'm about to add short small wires to bypass the printed circuit on the rear of the instrument cluster.
CMax03 is offline
hcarter1112
42
07-18-2022 03:35 PM
gavin68
09-18-2021 12:36 PM
HerpDerp1919
09-29-2015 02:02 PM
zmcneely13
09-26-2015 02:26 PM
Noela
09-26-2015 08:22 AM
Quick Reply: Speedometer problems help!
