Rim Question...19's
Rim Question...19's
hey guys...im not getting to many hits in the tires and wheels forum so i was wondering if you guys could help me out...im planning on ordering 19" Axis Hiro's for my car pretty soon but i dont really know much about wheels...im not going for a staggered setup i am just going to get 4 19x8.5...these will fit fine right? i was thinking about going with a 235/35/19 tire..but i dont want to have any rubbing...also if you guys have any opinions on tires to fit these i would appreciate any info...im planning on lowering the car on progress and illuminas soon too so i hope that wont be a big problem...sorry for all the questions just trying to find out some info before i drop some big money...thanks aloy guys
doug
doug
first is the width of the tire in MM. the second is the profile, which is derived from the width of the tire (first number). The profile (2nd number) is a percentage of the width. HOWEVER, for some reason, on multiple occasions, I've seen tires of the same size with different sidewall sizes, AND i've seen a 215/50/17 look taller than 225/50/17 (our stock size). so i guess the type of tire and manufacturing has to do with that too, but in general those numbers are standard.
Thanks for the advice guys but I have another question. I'm buying 20x8.5 rims with a 35 offset, tirerack recommends a 245/30/20 tire which I think is a problem. I was thinking about buying the tires off the 300 SRT8 which has Goodyear F1's that are 245/45/20 in the front and 255/45/20 in the rears. I want the thickest(height) tread possible to avoid the bent rim syndrome, if I get these tires will I rub the wheels?
I've been running that tire size and my car lowered on Maxspeeds for over 1.5 yrs and it hasn't rubbed one time. I'm now on Tokico Blues w/Maxspeeds and it hasn't rubbed since installed.
The 19's will fit fine on your car...a ton of ppl on here have 19's. I would go with tein s-tech springs...makes the car looks like its sitting right... i think i had 245 35 19's on the front...can't quite remember
I was riding on 19' Axis Crux with 245x35x19 with Tein S tech it doesn't rub unless I cut the wheels all the way, not many pple will know that cuz u can't see the inside of ur fender but when I took the wheels out to get my brakes done u could def tell that it rubbs......other than that 19's like the best way to go.....also u gotta be extra careful on driving if u don't want ur wheels end up like this from running over curb......I had to choose to run over curb or my other option was to hit the Bus......
sorry fo the terrible pix......hope this will help u becareful driving after u get the wheels......but nice choice on the wheel......dang......sorry again for long a$$ post.
Any advice?
[edit]
not, NO chance. With some modification, it could work, but not stock/no rubbing.
[/edit]
Originally Posted by xtantmaxima
no chance. Those cars can fit 22's. Our cars can fit 20's. Some might say that doesn't matter but it does. The overall diameter of the Daimler-Chrysler RWD platform is about 1.5" larger than the pre 6th Gen Maxima.
[edit]
[/edit]
[edit]
[/edit]
I'm sitting on GR2's/maxspeeds. I plan to get 15mm spacers as well.
Hey guys, i just bought a 2001 Maxima SE a week ago, and my friend told me about this site/forum. Its really cool, anyways, by reading all your posts 19's are perfect for the max?? I was thinkin about getting 20's but i guess they will rub... if i am wrong anywhere please correct me, thanks. One more thing, i was lookin around the forums and the only Lip kits i have seen are like the Stillen one and one more, are there any more lip kits for the 5th generation max. Thanks again guys.
Originally Posted by NmexMAX
STFU Post in the appropriate forum .. and 20s wont rub if you use the correct size tire
There are more lip kits, but why don't you put a Y-pipe first. ..
Depends on the tire width .. Visit the wheel/tire forum, there's some useful information in there, or www.tirerack.com, and read the section "Tire Tech" .. it helped me .. Iw as in a bad mood, didn't realize it was your first post...
IMO 20's are on Maximas.
Originally Posted by BIGBZ
245/45 are just a little too tall, they will most likely rub when turning, i have 245/35, and they fit perfect, my car isn't lowered though, also i am running a 20x9 wheel, but that probably doesn't make a diffence.
That's almost 2" taller than stock .. Probably not ...
do the math
All in mm (metric)
245 x 0.4 x 2 = 196
20 x 25.4 = 508
Convert to inches
508 + 196 = 704/25.4 = 27.72" stock is 25.86"
www.tirerack.com for further information, as I stated above
do the math
All in mm (metric)
245 x 0.4 x 2 = 196
20 x 25.4 = 508
Convert to inches
Originally Posted by NJDevil210
good deal...thanks for the help guys...will i have to worry about like offsets or anything ( which i know nothing about ) and any recommendations on tires you might be running?
doug
doug
I have a 2002 SE dropped on H-techs(~1.5") & Tokico Illuminas running 245/35/19's(40mm offset) wrapped in Falken Azenis ST-115's and I have no rubbing issues at all. Only thing is I wish I chose a lower offset to fill in the fenders more.
The lower the number offset of the rim, the more the rim will stick out towards the fender. And the higher the offset number, the more the rim will seat inwards. As long as you stay within that tire size and stay above ~32mm offset, you will be fine.
0m3nc0w
09-11-2015 05:21 PM
