brakes cleaned..
you are wasting your money if someone is charging you to clean your brakes. if you have an issue like warped rotors, low brake pads or used up brake fluid then save your money for that. cutting rotors typically costs the same as the parts for replacement.
You don't need to lube you caliper slides unless they are sticking. The only way they start to stick is if the rubber boots protecting the slide pins are ripped or torn.
If you want to de-glaze your pads something as simple as sandpaper can be used to remove pad material and apply a rough surface to the rotors. It's not as effective as turning the rotors but it's a h*ll of a lot cheaper.
FAQ/How Tos are at the top of the forum:
http://forums.maxima.org/showthread....38#post3092338
As far as cleaning/greasing. I used brake parts cleaner to get the dust off the calipers and brake grease on the back of the pads/shims.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
