ECU reset a sick joke?
okay i spent about a half hour following the instructions in the faq on how to reset the ecu. is this someones idea of a joke? never once did the cel flash or anything resembling what should happen, happen. isnt there an easier way? i know in other cars you can yank certain fuses or relays. anything?
jim
jim
Works for me. I still never get it on the first try. Practice, you will get it. BTW, I share your feeling of the seqeunce being a joke. Why can't it be something simple like, up-up-down-down-left-right-left-right-b-a-b-a-select-start. I may be dating myself here.
jim
jim
jim
Reset the clock in the instrument cluster and hold the button before you shut the car down...then use it to time the procedure. I can do it in my sleep
Contra = best game evAr
after installing my intake the SES light came on, took it Autozone to reset and it came back on again then I try the reset code, took a while got frustrated a couple times but it did work, 4 months later no SES light....
jim
jim
Yeah, I had the same battle a few weeks ago.. I finally got fed up and just took my car to autozone, where he hooked up the little laptop, walked over to my gas tank, tightened the gas cap, and said "fixed!"
on a side note, im not getting any codes or anything, i was thinking a reset was in order after putting on an intake and exhaust. but the car learns on its own anyways right?
my idle is weird......sometimes its faster than 1000rpm, sometimes its right where it should be. usually when i start it after its been sitting for a whlie, it idles fast.....once it runs for a lil bit, its back to normal. is this the MAF?
jim
jim
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
220k+ A32
09-22-2015 03:08 PM
