parking light bulb removal
Old 05-04-2005, 02:56 PM
xxdean057xx's Avatar
im sure this has been talked about before but i cant find it anywhere, a lot of the links in the stickies are not even there anymore.
well i tried to change the freakin bulb but i couldnt remove the socket because of its location in such tight quarters........any links?????
xxdean057xx is offline
Old 05-04-2005, 04:17 PM
anyone??????
Old 05-04-2005, 04:31 PM
skierxx5556's Avatar
i had trouble removing mine to get the one on the passenger side i took the tube for the washer fluid off and that made it easier and on the drivers side i had to loosen the bolts on the battery and move it to the side a little... you have to do a little pulling too but they do come out pretty easy...
skierxx5556 is offline
Old 05-04-2005, 11:46 PM
DJ2Max's Avatar
hrmmm... i just reached in there and gave it a twist.... i feel small.
DJ2Max is offline
Old 05-05-2005, 12:11 AM
bigsherv's Avatar
i had trouble getting mine back on, but eventually it got back on.
bigsherv is offline
Old 05-05-2005, 08:37 AM
XGaSpAcHo
remove the headlight.
Old 05-05-2005, 08:41 AM
nyautostyle's Avatar
remove the headlight? you should be able to reach it, ive replaced mine with blue bulbs before, but you need someone with skinny fingers to get to it. take your time too, ive dropped the bulbs in the engine bay before and it sucks haha
nyautostyle is offline
Old 05-05-2005, 08:45 AM
TheBigDu's Avatar
Yeah, Nissan really could have left a little more room behind there. The weird angle also doesn't help.
Anyway, if you just squeeze your hand in there and ignore the pain of the sharp metal digging into your skin, you should be able to change it. It's definitely a b*tch, but it's doable. If you really can't fit your hand in there or find somebody else who can, then move the battery temporarily or something. The passenger side should be a little easier.
TheBigDu is offline
Old 05-05-2005, 08:46 AM
XGaSpAcHo
sorry, i was thinking of the turn signal light. i forgot which one was on top for a second. but in any case, removing your headlight would work. you don't need to pull it out all the way just a little bit to give yourself more room to work in.
Old 05-05-2005, 08:48 AM
TheBigDu's Avatar
It might be easier for those of you without DataDots. But not for me...
TheBigDu is offline
Old 05-05-2005, 08:50 AM
XGaSpAcHo
you should still be able to pull it out a few inches. i know this because some ahole tried to steal my lights once but failed.
Old 05-05-2005, 09:15 AM
is invisible
CoolMax's Avatar
Yeah, it's a ***** to get in but I was able to, but the light output doesn't seem level.
CoolMax is offline
Old 05-09-2005, 06:50 PM
lol, thanks a lot for all your help but my friends and myself tried to diconnect the bulbs but still got more pain then luck so i took it to a local nissan dealer and they changed it FOR 90.00!!!!!! i know the dealer is a rip off but i got lucky and didnt have to pay, my weanie friend bet me he could change the bulbs............... i won
Sport
07-03-2017 05:40 PM
iflexsteel
09-15-2015 03:37 AM
KristyKarina
08-23-2015 09:53 AM
MikesChevelle
08-06-2015 11:36 AM
Quick Reply: parking light bulb removal
