2000 Maxima Woofer
Old 12-21-2017, 12:48 PM
jrskerrett's Avatar
2000 Maxima Woofer
My woofer has stopped working. The rest of the audio works fine, so amp is OK. Hot wire fuse to the speaker is OK. Can't find the G305 ground that is on the right c pillar. Where is the right c pillar?
jrskerrett is offline
Old 12-21-2017, 11:42 PM
DennisMik's Avatar
The C pillar is between the rear door and the back windshield.
A common cause for the woofer to stop working is the relay in the amplifier box is subject to cold solder connections that break free from the printed circuit board.
Here is a couple of threads for you to read. If you want more, SEARCH for bose woofer relay or bose woofer cut out.
https://maxima.org/forums/5th-genera...-once-all.html
https://maxima.org/forums/5th-genera...00-maxima.html
DennisMik is offline
euclid
248
02-17-2024 08:31 AM
Teddie18
131
11-06-2023 02:12 PM
District
12-26-2011 02:35 PM
a33
10-06-2001 05:04 PM
Quick Reply: 2000 Maxima Woofer
