6 Spd clutch pedal squeeking
Old 04-13-2005, 06:39 PM
mdloops's Avatar
I will keep it simple. When I press in the clutch pedal I hear a squeeking noise coming from my engine bay. Sounds like a spring that needs oil. I am not sure what the hell it could be. The car seems to be going into gears without a problem. Any suggestions?
Thanks,
Mark
mdloops is offline
Old 04-13-2005, 06:56 PM
dblrr900's Avatar
Mine JUST started doing the same thing. Argh! Two days ago it started. I have to work on it this weekend and see if I know what it is. Sounds like a squeeky bed.
dblrr900 is offline
Old 04-13-2005, 08:14 PM
Need A Light?
steven88's Avatar
you guys ain't the only one
haha but yeah I've had this car since 25k miles....now with 39k....it does that noise only when the car is cold....after driving around in the city....the noise goes away...
how many miles u got on yer stock clutch ya'll?
steven88 is offline
Old 04-13-2005, 08:25 PM
skierxx5556's Avatar
check this thread out i had sort of the same problem...
http://forums.maxima.org/showthread.php?t=394642
skierxx5556 is offline
Old 04-14-2005, 07:56 AM
silvermax2k2's Avatar
I have the same problem as well... i thought i was going crazy. lol
silvermax2k2 is offline
Old 04-14-2005, 11:01 AM
maseo77's Avatar
I got that same squeaky problem with the clutch pedal myself
maseo77 is offline
Old 04-14-2005, 11:25 AM
stevay's Avatar
Mine does too
stevay is offline
Old 04-14-2005, 11:48 AM
mdloops's Avatar
Wow. Did not expect this many responses. I guess it is a pretty big problem. The weird thing is everything seems fully functional.
mdloops is offline
Old 04-14-2005, 12:00 PM
yeah it does seem fine. But it is on my list of things for nissan to fix when i bring it in this spring.
Old 04-14-2005, 01:48 PM
screamindman's Avatar
This seems to happen everytime I'm at a drive thru for ice coffee or something. I don't usually hear it when I'm on the road because of traffic noise or my radio. It is so annoying. I'm trying to find something to cure it. I'm hoping one of the guru's can tell me where to spray some wd-40 because it seems like that's all it would take. Nothing seems to be wrong, but the noises sucks.
screamindman is offline
Old 04-14-2005, 02:36 PM
I miss the .org!
Triple8Sol's Avatar
What I went through to get it fixed: http://forums.maxima.org/showthread....ghlight=clutch
Triple8Sol is offline
Old 04-14-2005, 03:22 PM
DaBoxSE's Avatar
mine did the same thing for a long time, then went away after Nissan replaced my Transmission and clutch. I think it was the slave cylinder, maybe it needed to be lubed?
DaBoxSE is offline
Old 04-14-2005, 04:00 PM
mdloops's Avatar
Triple8Sol- The noise you were describing (clicking like a relay) is not what my car is doing. I think you had a different problem. This noise is in no way a clicking, but it is a squeeking. Sounds like an old rocking chair. Or like a hinge on a fence door that needs to be oiled. I agree it sounds like something just needs some WD40, but I am not sure what.
mdloops is offline
Old 04-14-2005, 06:56 PM
Isn't that a girl's name?
Morgan06's Avatar
anyone with the problem going to try the slave cylinder- or are yall waiting for a walkthru?
if that doesn't need to be greased, check the clutch cable bearing's shaft drive assembly reservoir.
Morgan06 is offline
Old 04-14-2005, 08:27 PM
nytrida's Avatar
I'm deffinetely trying this tomorrow when i get to work. Damn squeek. be gone with yourself!
nytrida is offline
Old 04-15-2005, 03:34 AM
DaBoxSE's Avatar
have someone listen for where the sound is coming from...It will probably be the slave cylinder.
DaBoxSE is offline
Old 04-21-2005, 04:42 PM
dblrr900's Avatar
OK. Tried the grease.... NoGo! Not sure where I am supposed to put it, but there is not a lot of options. Anyone else try this with success??
dblrr900 is offline
Old 04-21-2005, 05:22 PM
JUVIN's ride
2k2MerlotSE's Avatar
my guy at nissan took my intake out and lubricated something under the intake. Not sure exactly where or what, but it seems like the cable is in some type of housing and when the cable moves it makes the sqeak.
hope I make sense.
2k2MerlotSE is offline
Old 04-21-2005, 06:29 PM
mdloops's Avatar
hmmm. Maybe one of these days I will remove the intake and take a look
mdloops is offline
Old 04-21-2005, 06:37 PM
Loonee02SE's Avatar
New to the forum and I enjoy the read. I picked up my 02 Merlot SE w/ 6 speed & everything but navi a couple of weeks ago, great car and I love the interior. Only mod is the AE sills but I would like tinted windows. I wish the brake pedal was another 1/2" or so to the left, my big feet at 45 deg on the gas gets caught up on the brake pedal.
I also have the squeak with the clutch, generally can only hear when car is parked-engine off. What's this talk about cables, our max's have hydraulic clutches - that little bowl in the top right corner of the engine bay.
Need to have someone press the clutch while you listen, is it coming from inside or outside the tranny? I planned to look for it this weekend. I'll post my findings...
Cheers
Loonee02SE is offline
Old 04-22-2005, 08:52 AM
JUVIN's ride
Like I said I am not sure what he did, but the noise is coming form under the intake. What evers under there it is assosiated with the noise. If you would like I can call my mechanic and ask him.
Old 04-22-2005, 08:53 AM
JUVIN's ride
He said the pivot on the throw bearings is what the problem. He said something about where the arm is for the tranny.
hope that helps.
Old 04-30-2005, 07:31 AM
mdloops's Avatar
Did he say that it was something that could possibly be replaced under warranty? I have to think that this would be covered under the powertrain warranty
mdloops is offline
Old 04-30-2005, 04:43 PM
Igor911's Avatar
I used a painters mixing stick to get far in there. I used alot of grease. You NEED to get the throw out bearing. That is what is squeeking.
Igor911 is offline
Old 04-30-2005, 06:48 PM
mdloops's Avatar
is the throw out bearing a part that should go bad after only 58K miles. I am trying to find it in the parts catalog without much luck.
Edit: After searching I think I found it. It is called a "Clutch Release Bearing". I priced it out at $23. Is this about right igor? That is all I need to buy to make the stupid noise go away?
mdloops is offline
Old 04-30-2005, 06:58 PM
dblrr900's Avatar
My noise is now 80% gone. Not as bad as it was. After using the grease it started to fade. I imagine that I hit part of the spot and the heat is causing the grease to slowly work it's way in.
Igor was right, you just got to get some grease in there and work it out.
dblrr900 is offline
Old 04-30-2005, 08:49 PM
Autodude's Avatar
What a coincidence this subject came back up...My car which was doing the same thing at 27000 miles (which the dealer changed the throw out bearing which IS the problem.. No amount of lubing will fix this problem..NOW my car which has 54000 miles has been at the dealer for a week so far because when car is iding foot off clutch you can hear a whining sound like a bearing that is bad..First I thought it ws a belt pulley because it made the same sound on my 93.. But then I realized when I pressed on the clutch it went away...Come to find out its the main bearing in the transmission that went bad lucky me its covered under the powertrain 5/60 warantee..if not I was looking at 1300 bucks..mostly labor at 97$ per hour
Autodude is offline
Old 05-01-2005, 05:48 AM
dblrr900's Avatar
No, this sounds like a different issue. You have the howling clutch, not the squeeky pedal. The howling clutch sounds like a squirrel is stuck in your engine when you let off the clutch on acceleration or put it in, etc.
The issue that I am having and a couple others here have mentioned is that no mater what or where, when they depress the clutch there is a slight squeek that comes from the bell housing that sounds like an old rocking chair. I have had both, and even had my whole tranny replaced a couple years ago because of the dying squirrel. They are distinct and different.
dblrr900 is offline
Old 05-01-2005, 07:59 AM
mdloops's Avatar
+1
10chars
mdloops is offline
Old 05-01-2005, 08:41 AM
Igor911's Avatar
Yeah sorry, I forgot to mention you have to wait a day or 2 with some extra driving. It will work its way in
Igor911 is offline
ef9
10-04-2015 08:43 AM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
Quick Reply: 6 Spd clutch pedal squeeking
