17 Degree timing adv. Question
Old 04-12-2005, 10:00 AM
VQ30GTR's Avatar
Ok, to those of you whom have had your timing advanced, where does the 17 Degrees come from? I ran the other day on the expressway with my Auterra and watched my timing. I ran anywhere from -7 Deg. (start- coast)up to 34 Degrees at WOT. If you advance to 17 Deg, does that mean you can hit say 45 Degrees Advance at WOT? Since the computer is always adjsuting it, I guess my question is what good is the advance?
Thanks.
VQ30GTR is offline
Old 04-12-2005, 10:31 AM
skeetch's Avatar
Thanks.
It has to do with advancing the base timing. Stock is (15 +/- 2 deg. BTDC) for 00+. So if you advance 2 deg BTDC that puts you at 17 deg base. Therefore, you will not see 45 deg WOT but 36 deg. 45 deg is way too advanced. I am not too familiar with the 3.0L and modding it yet so I don't know how you go about advancing the base timing. I am guessing this can only be done by programming/chipping the ECM or adding a piggy-back system. Can anyone enlighten me on this?
BTW how do you like the Auterra? Any dislikes with it?
skeetch is offline
Old 04-12-2005, 10:41 AM
Maximax2's Avatar
Advanced timing can be done by the dealer, or other shop with an Consult II scan tool (correction per post below). I know it's up to 17 degrees on a 2k2/2k3, think it's up to 20 degrees on a 2k-2k1?
I can personally report that the torque and HP increase has done bad things for my tire life...
Maximax2 is offline
Old 04-12-2005, 10:46 AM
skeetch's Avatar
I figured as much since the system is distributorless. Wouldn't you see more benifits if the EGR system is removed. When I turbo my other car I removed the EGR (had to cause I installed headers) and advanced my base timing 2 deg as well.
BTW I saw a Consult II on ebay a while back and those suckers are quite expensive!
skeetch is offline
Old 04-12-2005, 10:53 AM
GreenSeMax's Avatar
i believe 2k-2k1 don't have a conventional egr valve, I think the lobe separation and overlap on the cam specs allow enough reversion to run cleanly........
GreenSeMax is offline
Old 04-12-2005, 11:03 AM
Z
NYPD-Arnold's Avatar
Originally Posted by Maximax2
Advanced timing can be done by the dealer, or other shop with an OBDC II scan tool.
No it can't. There's only one tool that can do it, and it's the Consult II.
NYPD-Arnold is offline
Old 04-12-2005, 11:04 AM
lex3015's Avatar
Advanced timing can be done by the dealer, or other shop with an OBDC II scan tool. I know it's up to 17 degrees on a 2k2/2k3, think it's up to 20 degrees on a 2k-2k1?
how big are the gains from doing this?? i know my mechanic would do such a reprogram for free but i dont know too much about it.
lex3015 is offline
Old 04-12-2005, 11:10 AM
dot dot dot ...
NmexMAX's Avatar
^^^ Only using a consult II.
It's the base ignition, so 15*BTDC is stock. I'm dynoing this on an automatic this weekend. Butt dyno is pretty noticeable, but that doesn't say ANYTHING at all, one thing tht was noticeable was the engine sound has changed.
Basically spark advances to 17* before top dead center, and allows for more complete combustion when high grade fuel is burned.
NmexMAX is offline
Old 04-12-2005, 11:12 AM
Z
For every degree, you gain roughly 5hp to the wheels. 2-degrees = 10WHP. It's the best mod you could possibly do to your car. And it's free...I remember feeling the difference as soon as I went back on the highway. I typically floor my car when merging onto highways, so when I floored my car going around 30...I got this insane surge of power that I've never felt before.
To this day I like to feel the advance timing go into work. Best mod ever.
Old 04-12-2005, 11:14 AM
GreenSeMax's Avatar
Did the dealer do it for you? or do you know someone with a Consult II?
Old 04-12-2005, 11:23 AM
dot dot dot ...
NmexMAX's Avatar
For every degree, you gain roughly 5hp to the wheels. 2-degrees = 10WHP. It's the best mod you could possibly do to your car.To this day I like to feel the advance timing go into work. Best mod ever.
I feel like NYPD does, and I'm not the type to write home about any mod until I see gains, but this one is by far one of my favorites, along with the headers, well, those are my only 2 mods next to my GABBut I do predict this will add some area under the curve when I dyno this Saturday. The engine sound is different as well. Keep in mind NYPD is a 3.0 and I'm a 3.5L, so it's beneficial on both spectrums.
NmexMAX is offline
Old 04-12-2005, 11:27 AM
joebangaa's Avatar
if only dealerships around here weren't so b!tchy. anyone in socal done this let me know, as far as i know dealerships pretend like they dont even know what youre talking about when you mention it!
joebangaa is offline
Old 04-12-2005, 11:42 AM
dot dot dot ...
NmexMAX's Avatar
Talk to the service manager, I live in a pretty rural area, so I had my doubts about the delaerships around, and both places I checked would do it, only one does it regularly though, the otehr one I had to explain in a little detail, but as far as finding one, I figure in your area shouldn't be too hard. Or just buy a consult II, probably be worth it in the long run.
NmexMAX is offline
Old 04-12-2005, 11:44 AM
whazzzzuup's Avatar
How much did it cost for advancing the timing? I think I am going to do it soon.
whazzzzuup is offline
Old 04-12-2005, 11:47 AM
dot dot dot ...
NmexMAX's Avatar
0-$95 I've heard. Some charge an hr, some charge .25 hour, and hr rates are different so Depends where you're at and how you ask them I guess.
NmexMAX is offline
Old 04-12-2005, 11:51 AM
skeetch's Avatar
Originally Posted by NmexMAX
....Or just buy a consult II, probably be worth it in the long run.
One just sold on ebay for $3,500. That's some serious coin. I think they list for $5000. I rather spend it on an SC.
skeetch is offline
Old 04-12-2005, 11:54 AM
dot dot dot ...
NmexMAX's Avatar
Wow, nevermind, didn't know they were that pricey seen some for 500... Just drop by the dealer and ask them.
NmexMAX is offline
Old 04-12-2005, 12:07 PM
Z
My boy, fellow Org member, who is a Service Tech at a dealership. =)
Old 04-12-2005, 12:08 PM
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 04-12-2005, 12:18 PM
GreenSeMax's Avatar
lucky.......i'm gunna look into that i gotta get in soon to stealer cuz my driver's window shorted, and keeps blowing the fuse.......which is the same curcuit as the sunroof, power seats, locks, etc, so right now i can't do anything except drive it........well my heated seats still work, i'd be more motivated to get it in if they didn't lol
Old 04-12-2005, 12:23 PM
unrealii's Avatar
Have you guys seen any increase in mpg? Maybe not since the fun pedal becomes more fun, but just curious if anyone has tracked fuel consumption.
unrealii is offline
Old 04-12-2005, 12:25 PM
dot dot dot ...
NmexMAX's Avatar
I just got it on Friday and have yet to kill a full tank. Good thought though, will check.
NmexMAX is offline
Old 04-12-2005, 12:32 PM
takkar's Avatar
I'm curious to know this too about the mileage
takkar is offline
Old 04-12-2005, 12:57 PM
Unsuccesful STL Coordinator
Epacy's Avatar
I wish I could find a dealer around here who would do this. I might even be willing to drive to Chicago or Kansas City for this.
Epacy is offline
Old 04-12-2005, 12:59 PM
dextterity's Avatar
i literally just had my timing advanced from stock 15 degrees to 17. I had this done with my oil change and i also had them check my throttle position while it was on the machine, came to 42.50 for the timing and throttle...here is what it said on the reciept
customer request
re-set ignition timing to 17 degrees. verify operation of throttle-position sensor.
re-set base ignition timing with "consult". checked specifications on T.P.S. switch. (with normal range)
(note: ecu will alter all engine specifications in accordance with sensor inputs. (including "detonation" sensor which is affected by fuel octane.)
and i knew about the "note" the ecu will know if i start to put ****ty gas in/not 93 and alter the specs.
and looking at the "re-set base ignition timing" i'm hoping they forgot to say 17 degrees, because that's what i asked them to do...anyway my car felt much smoother at idle and felt more responsive especially when i was getting on the highway heading home.
dextterity is offline
Old 04-12-2005, 01:30 PM
OU > *
S00NR1's Avatar
Bob Moore here in Norman wanted 80 bucks to do it. Needlesss to say I told them they were nuts and that it only takes literally 3 minutes to do. So I have decided I am going to give my connection in the service dept at Sewell Infiniti in Dallas a call and see if he will do it for me for cheaper the next time I am down in DFW.
S00NR1 is offline
Old 04-12-2005, 02:45 PM
vsamoylov
man i want to do this but its going to be tricky for me trying to tell them about my car. did you guys just go to the service depratment and ask them to advance your timing to 17 degrees or what?
Old 04-12-2005, 02:54 PM
dot dot dot ...
NmexMAX's Avatar
Yes that's correct. What ECU are you using?
NmexMAX is offline
Old 04-12-2005, 02:55 PM
dextterity's Avatar
well first off the service guy there is pretty nice he remembers me from speaking with him about my car and coming in for oil changes. When i mensioned this to him he said i was the first person to ever ask to have that done, atleast to him. He isn't the mechanic of course, but said he'd put it through and see if they can do it and get it done today, and they did end up doing it. I'm pretty sure someone said that nissan allows dealerships to adjust the settings by -/+ 5 degrees from the stock 15 degrees. if the service guy is unsure tell him to pass it by with one of the mechanics who'd acctually be working on your car, i'm sure he'd have a much better idea of why you want this done and will say ok
Old 04-12-2005, 02:58 PM
vsamoylov
yeah i really want to get this done to my max. i am using the 2k2 ecu. basically everything is 2k2 except the body. i just need to find a dealer that will do this. how much do they usually charge?
Old 04-12-2005, 03:08 PM
dot dot dot ...
NmexMAX's Avatar
NmexMAX is offline
Old 04-12-2005, 03:09 PM
dextterity's Avatar
look up a couple posts to post 25 you'll see my post about the price
Old 04-12-2005, 03:27 PM
Epacy's Avatar
Most service people have no idea what I am talking about. Local Nissan dealer says "we are not allowed to make any unauthorized modification to the car without factory approval". Did he just read that **** out of some book while I was on the phone with him? F@cking ignorant weaklings.
Epacy is offline
Old 04-12-2005, 03:28 PM
Lytheum's Avatar
would there be a downside to going beyond 2 degree advance? or is that just the most consult will allow? I always run 93 octane fuel.
Lytheum is offline
Old 04-12-2005, 03:32 PM
The Definitive AE Master
Larrio's Avatar
i have a hard time believing 1 degree of advance equals 5 hp to the wheels.
i have the ts ecu haven't felt a difference nor have I seen a significant difference between my dynos vs. other de-k's
Larrio is offline
Old 04-12-2005, 03:35 PM
Epacy's Avatar
It is amazing how little Nissan service departments know. Most of them act like I just spoke a line of Hindu to them.
Epacy is offline
dot dot dot ...
NmexMAX's Avatar
We will see this on Saturday, as I am planning on dynoing but i have a 3.5. 2 degrees is usually the max they recommend. It's hard to swallow the whole 5hp/degree deal, I've read 2 hp/degree but still. Iw ant to see what it does for myslef and ahsre resutls.
Larrio. you're back
NmexMAX is offline
Old 04-12-2005, 03:49 PM
Kevlo for President
Kevlo911's Avatar
2Degrees prob equals 4-6hp
Kevlo911 is offline
Old 04-12-2005, 05:25 PM
vsamoylov
yeah i am going to call up some local delarship today and see what they say. infiniti dealers should be able to do it also right? just convincing them about the swap and making them work on it is going to be the hard part.
Old 04-12-2005, 05:50 PM
frankd121's Avatar
bump...i'm curious too..
frankd121 is offline
Quick Reply: 17 Degree timing adv. Question
