02-25-2005, 11:46 PM
Z
Advance Timing: Step by Step Instructions with Consult 2 Tool
For those of you dealing with clueless dealerships, print this out for them.
Warm up vehicle.
On CONSULT 2 screen choose ENGINE
After communication with Convertor will display a bunch of choices.
Press WORK SUPPORT
See more choices, press TARGET IGN TIMING
Press UP x2 for 2 degrees, correction which you should be able to see.
Press UPDATE.
Now press BACK
On the menu screen find IDLE AIR VOL LEARN.
Press, and perform to correct your idle since you just raised it 75rpm with timing advance.
All credit goes to Nismo_Star.
02-25-2005, 11:54 PM
OU > *
What kind of improvements have you noticed from the re-timing, and do you expect any negative side effects?
02-26-2005, 12:01 AM
Z
Well there's an entire thread about it about 2 pages back, so give that a look. Improvements are pretty massive and noticeable. Basically, for every degree you adjust up, you gain roughly 5HP to the wheels. I felt it, plenty of others here have as well. You're basically setting the car to a setting where it is downright dangerous to fill your car up with anything less than 91. Since I fill my car up with only 93, this doesn't phase me.
Dangerous may be excessive, but under a 17-degree setting (stock is 15, but some Maximas are 13) you must only fill up using 91 or higher. Filling up with anything less will create pinging and you don't want that. So if you treat your Max right and always fill it up with 91 or over, then there will be no problems.
__________________
2006 Daytona/Frost 5AT: MotorDyne 5/16 Plenum Spacer | BTDC@17 | Borla True Dual | Ultimate Racing HFCs | Jim Wolf Popcharger | Weight: 3175lbs - 60LBS Weight Red. | Hotchkis Springs | Eibach 15mm Rear Spacers |Michelin Pilot Sports | Dunlop M3s | 3M Clear Bra | Polished Mini Antenna | 2005 FX35 Graphite/Brick
02-26-2005, 12:06 AM
OU > *
Ya, thanks Arnold - just got done reading all three pages of the earlier thread. My question is this, if it indeed has increased RPMs at 60mph from 1800 to 2100, would this not ill-affect the gas mileage, especially at interstate speeds of about 75-80mph?
Almost 99% of gas stations in Norman and the Oklahoma City metro area carry 91 only for their premium grade, but there is a Sinclair in town that carries 93 -- although I would prefer it be a Top Tier rated station with the 93, but whatever.
I might run over to my Nissan Independent Service Shop next week and see if they have any thoughts on doing this. I need to have them look at my CV axle anyway, so might as well.
02-26-2005, 12:21 AM
Z
Well...I've definitely noticed a slightly higher RPM rev. But I haven't seen any mileage issues, though. 200 miles and the needle is just a little below the half way mark. I'll probably be able to bang out another 100 miles before the gas light comes on -- and I'm in NYC.
__________________
02-26-2005, 12:23 AM
OU > *
Hmm, that's interesting -- the mileage really would seem like the only possible negative effect, granted that the driver will still be using 91+ octane. My mileage sucks anyway, so it probably can't get much worse.
Looks like I will be shooting for more HP next week, lol.
02-26-2005, 12:26 AM
Z
It's actually made my pedal more responsive. If I let go of the pedal and I'm crusing at 60, the needle will idle at around the 1800 mark. Once I put my foot back on the pedal just to maintain speed, it'll jump to 2100. I mean the difference is just apparent. My car pulls nearly as hard as my uncle's 03 GLE -- no joke. This really, really has me curious as to what my car can do on a 1/4 mile.
02-26-2005, 12:31 AM
OU > *
Thanks for all the info Arnold. Now that I will have to wait another couple of weeks to get the whole Y-pipe situation solved, I have the urge to do something to improve pickup on my AE. I am currently running the Budget test pipe/stock ypipe and the car feels more responsive in the mid-rpms and the exhaust sounds 500 times better, so I am happy for now.....BUT, since Thunder Valley day is comin up soon, I've gotta figure out something to get me into the 14's, especially since I don't want to get wasted in the brackets by my sis' WS-6.
Advanced timing it is!
02-26-2005, 07:10 AM
Mauja He Mauja
i am going to have blackbird do it for me, next time i am in chi
__________________
02-26-2005, 07:17 AM
I'm too lazy to look up the old thread, but has anyone done this to the 3.5 yet? If so, were there any gains?
02-26-2005, 09:24 AM
IMBOUTTOBUSTSOMEGHOSTS
this will not adversely affect gas mileage. if the car is driven the same as before then you should get better mileage as the motor is operating more efficiently. as a side note, the timing should not adjust your idle at all. that is unless you change your idle with the consult 2 but simply bumping the timing will not change idle unless you have another issue. i had my timing done a year and a half ago and i decided to bump my idle the day after because my udp was spinning too slow and was making noise.
__________________
02-26-2005, 09:48 AM
Now, is Consult II the one you can use at Autozone, so basically you can do it yourself? ot does this have to be done at the dealer?
Also, when this is done and consiquently rpms change when drving at 60mph (NYPD-Arnold), does that mean you have Automatic tranny?
02-26-2005, 11:03 AM
can someone link to the other thread?
02-26-2005, 12:14 PM
Z
No. This can only be done at a Nissan service department. And perhaps my service tech adjusted something else that caused my RPMs to rev a little higher...but apparently just a regular timing advance will not change your RPM range. And yes, I am an auto.
02-26-2005, 12:34 PM
Hmm, I guess I'll have Hogan do this when I get my damn steering problem fixed.
__________________
2k3 Maxima SE
02-26-2005, 02:07 PM
i just had it done today.. i feel a differance in the mid range.. but the rpm from 5000-6000 just seems like it did before.. maybe my VAIS is shot .. maybe that will be the next Fix.. but my wheels will chrip at anything less than 25 mph if i floor it now.. feels good to me. It was a Good 20$ i handed the man to do it!
02-26-2005, 02:10 PM
Z
Quote:
Midrange is where you're supposed to feel it. Enjoy it!
02-26-2005, 04:26 PM
ditto on the 5.5 question.
__________________
2002 SE - Z rims, Clears FSTB - SOLD
2002 Q45 Sport
2002 I35 Sport - Tokico Illumina's
1996 GLE Too many mods to list.
02-26-2005, 04:30 PM
Z
It's the same process and effect for 5.5s. Nothing different.
__________________
02-26-2005, 09:16 PM
Just want to follow along
02-26-2005, 09:37 PM
I30swimmer: I am in Tampa and would like to know which dealer and who did you speak to in getting your timing done. Can't find a Nissan dealer to do it, so I am willing to try an Infiniti dealer to get this done for me. Thanks.
Pedro
__________________
02-27-2005, 06:45 AM
Infinity dealer
Nissan tech did not want to do it for me, but Infinity tech would by appointment(30 min). What I have found out is that the techs that have been a round awhile know about this. Infinity tend to keep their techs longer.
02-27-2005, 07:45 AM
With such a generic service request, won't the dealership try to charge you a full hour for labor? I just really doubt I can go into a local dealer and have them give me the time of day with a car that isn't broken.
__________________
Quote:
Originally Posted by Donkey®
You guys win.
02-27-2005, 09:19 AM
Quote:
that would be the case unless you knew someone at the dealer or just had someone there that would be willing to break the rules a little. that is the reason i found a nissan/infiniti specific shop that would have to have the tool for their sakes and would be more casual with charging something appropriate. they pulled my car into the bay and just handed me the consult. i changed the timing within a few mintues and continued to mess around for a while just seeing what other operations or functions it was capable of. they only charged me 20 bucks. take a look in the phone book for a service shop that specializes.
02-27-2005, 10:10 AM
I'ts hard finding a shop that will work with me. Their charges are usually ridiculous. Doesn't installing a new MAF, reprogramming, and adjusting timing all sound reasonable for an hr's labor?
02-27-2005, 10:23 AM
Quote:
it depends on what their manuals say. they are given a set amount for every procedure. they might say a maf replacements takes .5 an hour when it could take 5 minutes. it sounds reasonable to me but im not paying for all of the dealer's overhead.
02-27-2005, 10:31 AM
