Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 06-17-2005, 07:45 PM   #81
Wat
E55AMG2's Avatar
Quote:
Originally Posted by ighettoboyi
don't they say they adjust the ignition? that's actually what they told me when I emailed......so much for researching huh?
They adjust the timing map, fuel map, and TPS mapping, rev limiter, top speed, etc...
Base timing is not part of the timing maps, nor does it matter (right after you press the gas, base timing is out the window) thats why people feel the "power" when they get the timing bumped up...it just takes fractionally less time to jump to the correct point on the timing map.
E55AMG2 is offline   Reply With Quote
Old 06-19-2005, 09:29 AM   #82
joebangaa's Avatar
yea mike's told me a hundred times he was the test car. i'm just reiterating what TS said, i mean before anyone plops down money shouldn't we all know what they claim about their own products?
__________________
AEM/Cattman/Energy Suspension/FrankenCar/Motostorm/Place Racing/SSR
/////Alpine/CDT/Eclipse/KnuKonceptz/Optima/SoundSplinter/US Amps
joebangaa is offline   Reply With Quote
Old 06-20-2005, 12:33 PM   #83
Quote:
Originally Posted by NYPD-Arnold
Midrange is where you're supposed to feel it. Enjoy it!
Hey Arnold,
Which dealership in NY you went to. I am very interested in getting this done. Thanks!
kam1luv is offline   Reply With Quote
Old 06-25-2005, 06:01 PM   #84
CFOLEY442's Avatar
i went by the dealership today and talked with the service manage and he said he would do it but it would knock pretty bad, then he said the knock sensor would retad it back futher then it was, he said, 02-03 maxima customers complain all the time, about how they hear a knock and recommended not to do it, opinions please.
__________________
02 Sterling Mist SE: 35% tint, Frankencar Intake, cleared side markers, all red tails, shaved trunk, 18x8 RPM2'S, toyo proxy 4's, h-tech/tokico blues, progress rear sway bar, stillen exhaust, otto fstb, laminx yellow fogs
ICE: alpine cda 9811, boston acoustic 6.5 pro series components, boston acoustic 6.5 nx series, alpine amp, bazooka bta10200'ipod interface, steering wheel control adaptor, sirius
CFOLEY442 is offline   Reply With Quote
Old 06-25-2005, 07:37 PM   #85
Quote:
Most people don't change their oil or use the correct octane or change their plugs.
I would not do this mod unless your car is in excellent running shape.
__________________
2001 Sterling Mist Maxima SE/AE
theMax is offline   Reply With Quote
Old 03-07-2006, 08:37 AM   #86
Had my..........
Had my timing advanced to 17 degrees yesterday. Wow the throttle response is so much better. I went in to Nissan at 4:30 pm went to the sales desk to buy a gallon of OEM coolant to do a flush & figured while I was there I would ask one of the guys to do it. He was done for the day & walking out Asked him to do it I slipped him $20 he looked down said I will be right back & did it in less then 5 min right at the curb in front of the place . I told him while he was doing it that others said they were having a hard time getting the dealership to do it & he said hey $20 bucks is $20 bucks. I recommend this to any one. Best $20 bucks spent in a long time. P.S Gallon of OEM coolant was $19.95 what a rip off.
__________________
"Life is what you make it. Or how you Mod it".
Kevon1 is offline   Reply With Quote
Old 03-07-2006, 10:08 AM   #87
The Definitive AE Master
Larrio's Avatar
Is there any speculation that advancing the base timing with the consult-II will erase the programming from Technosquare?
This is my only concern as of now since it wouldn't be feasible for me to lose the TS programming in exchange for a bump in base timing
Larrio is offline   Reply With Quote
Old 03-08-2006, 11:18 AM   #88
Good info!
Will try my next time i am at the stealership
acidbbg is offline   Reply With Quote
Old 03-10-2006, 08:04 PM   #89
I doubt it will change the info from technosquare..
I work for Mitsbishi/Porsche. Today I went into the Nissan bulding and had a chance to observe how the consult works. First I had my ecu/tcm updated then I had the timing bumped. It's got to be one of the most user friendly user tools I've ever seen. She hooked the consult up to the computer uploaded the update info onto the program card. Reflashed my ecu/tcm, then she bumped my timing. She wasn't sure how, so I jumped online and copy/pasted the first thread into notepad and printed it for her. The reflash card isn't even in the consult while timing is bumped so in theory it would be impossible for it to change any other rom settings. The ecu/tcm reflash takes about 20-25 minutes to completely upload into the rom once the process is started. So a full hour or 8/10 isn't to bad. The timing change automatically saves in seconds.. $5 + if her friends need Mitsu reflash I owe her one for the whole thing. I did defiently notice a drastic difference in throttle response. Power gain is very minimal, but the split second it used to take to downshift and take off after you floor it has all but disappeared. Thanks for the write up.
EDIT: since I did the ecu update and timing both at the same time, I can't say for sure that the timing bump was fully responsible for the throttle response.
5thgenmaxima is offline   Reply With Quote
Old 03-14-2006, 04:02 PM   #90
nissan tech. told me because my my car's throwing a code (haven't welded in my o2 bung after header install) he was unable to advance my timing. I think he's full of sh*t, throwing a code and advancing my timing is two seperate issues am i right or wrong?
02se225 is offline   Reply With Quote
Old 03-15-2006, 05:45 AM   #91
bump.......
Old 03-15-2006, 07:23 AM   #92
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
Some are picky and wont because of the SES light.
My dealer did though, even with it on.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 03-15-2006, 11:55 AM   #93
Send a message via AIM to SGriffin960
Advancing your timing more than a degree or two and you're asking for trouble. It's more of a throttle response thing than anything else, I personally wouldn't do it.
Obviously advancing/retarding your timing has it's merits with a lot of NA goodies/forced induction, but for simple bolt ons I think it's a waste.
SGriffin960 is offline   Reply With Quote
Old 04-28-2006, 09:02 PM   #94
Send a message via AIM to shift_2kmaxima
i woder how will a guy look at me when a 17yr old kid asks him to do this....lol.....He'll prbly be like "kid, go home and watch disney chanell lol" hahahhahaha
but yeah i'll slip him some money, I hope they do it, i'll visit my Nissan dealer 2morrow.....
huso
__________________
shift_2kmaxima is offline   Reply With Quote
Old 04-28-2006, 09:11 PM   #95
Send a message via AIM to Hoooper
Quote:
Originally Posted by S00NR1
Ya, thanks Arnold - just got done reading all three pages of the earlier thread. My question is this, if it indeed has increased RPMs at 60mph from 1800 to 2100, would this not ill-affect the gas mileage, especially at interstate speeds of about 75-80mph?
no, youre still in gear so you still do the same rpm after idle as you would before the timing was advanced.
Hoooper is offline   Reply With Quote
Old 04-29-2006, 05:06 AM   #96
goin to Z town
doc2278's Avatar
how much did it run you at the dealership to get it done?
__________________
he's afraid of Ducks.......
doc2278 is offline   Reply With Quote
Old 09-07-2008, 05:43 PM   #97
don't ask the "dealer" to do it....go find a tech out back of the dealership smoking a cigarette and slip him some cash to do it. The service managers will NOT do it for you....find a tech, bring him the instructions at the beginnning of this thread, and he'll be happy to make $30-40 cash for 5 minutes of work.[/quote]
I'm with Irish. Why do ya'll go to the desk and ask for it to be done? The tech out back smoking-wants your 20 bucks. That is either more, or really close to their flat-rate pay...the dealer/manager doesn't want that kinda crap on the books. TROUBLE. Work smarter, not harder people. Save them duckets! The 60 bucks you just saved will fill your tank with super.
flatcat19 is offline   Reply With Quote
Old 09-07-2008, 07:03 PM   #98
Got mines done by a fellow TMEC/ORG member It was put to 16 I noticed improvements like:
Throttle response
Gas mileage
__________________
2001 Infiniti I30 Luxury
Stock/Elegantly Kept /35% SolarGuard Tints / KYB Struts/Mounts / Megan Racing Springs 1.75 drop / Eurorotor F1 Pads
WTB: [I35 Grille] [I35 17' Alloys]or[18' G35 Coupe Alloys]
Toronto, Canada
PM PLEASE
Quote:
Originally Posted by BadBlackMaxSL View Post
Nissan already has Honda's upscale brand, Acura, and its TL covered. Its called the Infiniti G35x. 306 hp and AWD. Ok, discussion now over.
ShippedOut is offline   Reply With Quote
Old 09-07-2008, 10:41 PM   #99
Send a message via AIM to choiiiiiiiiiii
Quote:
I'm with Irish. Why do ya'll go to the desk and ask for it to be done? The tech out back smoking-wants your 20 bucks. That is either more, or really close to their flat-rate pay...the dealer/manager doesn't want that kinda crap on the books. TROUBLE. Work smarter, not harder people. Save them duckets! The 60 bucks you just saved will fill your tank with super.[/quote]
check the last post date before yours boss..
__________________
AMD
Atlanta Maxima Drivers
choiiiiiiiiiii is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
