Replacing 15 inch wheels with larger wheels
Old 04-30-2001, 04:24 PM
robbyn
I want to replace the crappy 15 inch wheels on my 2000 Maxima with 16 or 17 inch wheels. 4 Questions: 1) The owner's manual says not to change wheel sizes when replacing the wheels, if I change the wheel size would that hurt my warranty? 2) The 15 and 16 inch wheels have the same offset (according to the owner's manual) but the 17 inch is different, what would I need to do to put 17 inch wheels on? 3) Would changing the wheel size negatively effect handling? and 4) Is there anything I can do to make the speedometer/odometer accurate after changing wheel sizes? Thanks for any guidance anyone can provide me.
Old 04-30-2001, 04:38 PM
Sonic's Avatar
Are you replacing the stock size with the 17" SE rims or another? All recent (89+) Maxima wheels are interchangable, so if you are going to use those, they are a direct swap. As for tire sizes, use 235/45-17 tires, they put the odo and speedo within 1% of stock, less than 1 MPH off at 60 MPH. If you go larger, than in general, handling is improved. I know that my car feels better with the larger wheels, but others have stated that the car feels wobbily. A FSTB and RSB will take care of that. I couldn't tell you about the warranty, try calling Nissan at 1-800-nissan1 and ask them.
Sonic is offline
Old 04-30-2001, 05:25 PM
Got Bent?
UMD_MaxSE's Avatar
1. Changing to a tire size that is properly plus-sized will not affect the warranty. If a dealer gives you trouble over it, I would suggest you find another dealer. No one should give you trouble about aftermarket tires.
2. You can get rims with the correct offset. If you want the stock 17" SE rims, then nothing is needed to make them fit. They are redily interchangeble with all other Maxima wheels.
3. Going to larger diameter tires will help increase your handling performance and cornering ability.
4. Properly plus-sized tires will not need any speedo recalibration since they should be within 1 or 2% of the stock size.
I made this spreadsheet a while back in which you can enter your stock tire size and tire size you want to install. It will then give you overall error and tell you how much your speedo will be off at different speeds:
http://www.glue.umd.edu/~nauman/tire.xls
UMD_MaxSE is offline
Old 04-30-2001, 07:06 PM
robbyn
Thanks Medic and UMD, your replies were very helpful. BTW UMD, your tire spread sheet is pretty cool.
Old 04-30-2001, 07:16 PM
Got Bent?
UMD_MaxSE's Avatar
thanks
Old 04-30-2001, 07:21 PM
robbyn
Old 04-30-2001, 07:37 PM
AznWontonboy's Avatar
hey umd, i was just using ur spreadsheet, and the numbers i put in for stock were 215/50/17, and the closest speed ratin was 235/45/17 if i wanted to lower the profile of my tires... why does the width have nething ta do with the wheel speed???
AznWontonboy is offline
Old 04-30-2001, 07:43 PM
y2kse's Avatar
Heads up !!!
Be careful when installing 235/45 tires on the stock OEM 17" rims. The OEM rims are only 7" wide. Most 235/45's require AT LEAST 7.5" wide rims. And while your auto warranty may not be affected if you install oversize tires on your OEM rims, your tire warranty may be.
y2kse is offline
Old 04-30-2001, 07:57 PM
damn, that sucks. 3 miles off at 90mph... hmm... 225/45/17.. but again, how does width affect speed?
Old 04-30-2001, 10:15 PM
mbcp_tdogg's Avatar
Something interesting...in case you guys didn't know, the 17 inch se stocks actually throws the speedometer off by +2% compared to the 16 in se stocks. However, after upgrading to my 18's (235/40-18), they're back to the 16 inch speedo specs again, partially why I decided to upgrade.
Definitely make sure you weigh all the factors before deciding on which rims to go for. Have fun.
mbcp_tdogg is offline
Old 05-01-2001, 04:54 AM
Got Bent?
UMD_MaxSE's Avatar
to get a larger width tire, you need to get a smaller sidewall. The second number in tire sizing is a percentage that determines the sidewall height. So, width does not affect the speed, it is the overall tire diameter.
Old 05-01-2001, 06:50 AM
robbyn
One additional question
Thanks for all the advice. I hate to show my ignorance, but I have one additional question. Assuming I go to the 17 inch wheels, can I use one of my fifteen inch wheels as a spare, and would it make a difference if I used it on the front--power driven--axle or on the back?
Old 05-01-2001, 06:53 AM
Got Bent?
UMD_MaxSE's Avatar
Re: One additional question
I don't see why not.....it can be used anywhere as a spare....it will work better than the donut you have for a spare now
trasmadean
02-01-2017 08:20 PM
morteljc
Wheels/Tires
10-22-2015 08:43 PM
MichMaxFan
Garage and Workshop
09-02-2015 06:35 AM
MaximaDrvr
08-19-2015 08:20 PM
Quick Reply: Replacing 15 inch wheels with larger wheels
