codes pulled and pulled and pulled
Old 01-21-2005, 08:54 PM
6yrs old=36,500 miles :)
harmbone2k2's Avatar
First time it was p0158,p1147,p0139...then 2 weeks later it was p1147,p0139...and today it was only the p0158. Now I have one of my 2 rear O2sensors installed on my b-pipe and the other installed on the y-pipe. Could this be a reason for these codes? I would attempt to fix the problem if the codes were the same everytime. What the he!! do I do?
harmbone2k2 is offline
Old 01-22-2005, 12:27 AM
Wat
E55AMG2's Avatar
You have to have the rear 02s mouted behind the cat. Also, if you have an exhaust leak....that doesnt help
E55AMG2 is offline
Old 01-22-2005, 07:31 AM
thanks amg...
Old 01-22-2005, 07:20 PM
studman's Avatar
The P1147 and P1167 codes mean that the sensor is bad. If you get either of those codes, you need to replace the sensor. The P0138 and P0139 codes can be fixed using several methods, but because of the P1147 code, you need to replace the sensor.
Trust me on this one, as I spent alot of money and time figuring it out on my car. E55AMG2 can back me up on this one, as he was there as it happened.
studman is offline
Old 01-22-2005, 08:20 PM
NisMo-Max's Avatar
reset the ecu and wait until the ses light comes back on then rescan it again maybe that will narrow it down...
NisMo-Max is offline
Old 01-23-2005, 12:34 AM
Wat
E55AMG2's Avatar
indeed, O2 sims came to save the day.
E55AMG2 is offline
Old 01-23-2005, 06:45 AM
So you ended up changing a sensor and adding the simulator?
Old 01-23-2005, 10:26 AM
Wat
E55AMG2's Avatar
seonsor(s) and adding a sim
E55AMG2 is offline
Old 01-23-2005, 07:38 PM
studman's Avatar
You can cure the P0138 and P0139 codes with a sim, but for P1147 or P1167, you'll have to replace the sensor.
studman is offline
03-12-2020 12:06 AM
06-06-2017 02:01 PM
hayne
10-05-2015 11:53 AM
Quick Reply: codes pulled and pulled and pulled
