Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Thread Tools Display Modes
Old 12-09-2004, 04:43 PM   #1
code P0171
Any one have a code P0171? Lean condition bank 1. Could it be caused by the MAF sensor?
turkey72 is offline   Reply With Quote
Old 12-09-2004, 05:38 PM   #2
Send a message via AIM to Matt_01SE_20th
could be maf, could be: injector, fuel pressure regulator, fuel pump (not very likely). it could be a number of other things too.
__________________
I cant remember what happened last night, all I can remember is a song that goes like this.
Matt_01SE_20th is offline   Reply With Quote
Old 12-09-2004, 07:28 PM   #3
MAF.
I had P0171 and 0174, bank 1&2 lean....took it to the dealer and had it fixed with a new MAF and an ECU update/reprogram under my x-tended warrantee...cost me $100 and its all set now.
jmal is offline   Reply With Quote
Old 12-09-2004, 08:08 PM   #4
see i am leaning toward an injector because it is only on one bank
__________________
Old 12-10-2004, 05:06 AM   #5
When the light came on I had it scanned...and only had the P0171 code. I reset it just to pass inspection and it came back on the next day (of course). By the time I took it in to be fixed (about 3 months later) I had both codes...by then I had the rough idle/cold starts/loss of power thing. All due to the MAF.
I too was thinking injector, fuel pump, fuel filter, etc... but was very glad to hear it was only the MAF.
Did ya get it checked out yet, Turkey?
__________________
Owned and Operated by...
Old 12-10-2004, 05:55 AM   #6
I have the rough idle/cold starts/loss of power thing, from all the previous posts it looks like the MAF could be the problem. The car runs better when the cel is on but still not very good.
Old 12-10-2004, 09:18 AM   #7
Send a message via AIM to WVmax
Quote:
Originally Posted by jmal
MAF.
Well, in another thread, I've said that I've pulled P0174 (Too lean bank 2). I've had the hesitation, etc. I stopped by the dealer and they said it would be $75 to troubleshoot the problem, and then after that, see if the problem is covered under my extended warranty (I have the top warranty, elite). So, what exactly was your $100 toward? Deductible? Are you saying the MAF is covered under warranty? Thanks.
Trent
WVmax is offline   Reply With Quote
Old 12-11-2004, 05:11 AM   #8
Yes, I paid my $100 deductible from my extended warrantee and they replaced the MAF, and reprogrammed the ECU afterwards. At the time I had 71258 miles on the car, so the x-tended warrantee came in handy. I had the CEL scanned at my Dad's shop...got the P0171. I don't think I told the dealer that though, I just said that I had rough idle at cold starts, and less power in the mid/upper RPMs....also had some pinging which is what worried me most....now its all gone due to the MAF replacement. By the time I brought it to the dealer, I had P0174 as well and the cold starts/rough idle turned into stalling, and the power loss and pinging became worse...my MAF wasn't reading correctly, so I wasn't getting enough fuel (I think) to the motor. $100, all set now.
__________________
Old 12-11-2004, 02:28 PM   #9
Thanks for the great info, jmal. My car has just over 75,000 miles on it, so it sounds like it's the exact same problem. I'll take it to the dealer, make sure that's the problem, and, hopefully, it should be covered under my warranty (5-yr/100,000 mile).
Old 12-12-2004, 02:19 PM   #10
I would think so, but if they give you some hassles call around to different dealers and see what they have to say.
__________________
Old 11-18-2008, 09:07 AM   #11
I had the same problem in my wifey's 2k Max with 130k miles for a few months now with Bank2 running lean. Starts and surges until warmed up, then runs okay, but not great. Reading through all comments in the forums, I just couldn't start throwing part$ at it hoping for a fix.
I discovered that when the coil packs get weak, the car will ping and clatter even with high octane fuel and octane boost, so I replaced them. Fixed the pinging, but still hesitates and surges in the mornings and now will not exceed 4500 RPM willfully. No codes now and I'm frustrated as heck after dropping $509 on new coil packs.
I then swapped the MAF sensor for a known good working sensor from a friends tool drawer and VOILA... it ran like a rocketship compared to before.
After that, I had the computer fuel map reset to default by a Nissan mechanic buddy of mine. The fuel was at 108% before and this resets it to 100% to learn driving habits all over again. We took it for a test drive and got those new Bridgstone Potenza Pole Position front tires nice and toasty. WOW, my power is back.
It would have cost me $260 labor and $940 parts to fix at the stealership and I still think it would have been worth it. If you don't want to drop $400 on a MAF, get one from a salvage yard, try it in a good working car, hnag on to it or keep it for one of your friends that has the same year Max. $20 is better than paying $400 for a MAF. I got mine for free and will get to return the favor to someone the same way some day.
Now I just need to fix that clunking sound in the front passenger area. Next Thread.
__________________
2K Max Black
maxgen5 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
