Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-03-2005, 07:29 AM   #41
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Quote:
Originally Posted by instil
So, ive never had my MAF replaced. Cars power has been slowly but surely decreasing,its very noticable. Poor acceleration,rough idle,all that. I have a 2001, with 49K.
If i buy the $90 part, and swap the sensor from my current MAF, to this new part, that would be it correct? I need this problem resolved because my Max is not what it used to be. I bought it at 20K miles, and it drives like a completely different car now......in a bad way
You have an 01, you can just buy the $90 MAF and use it... no need for swapping the IAT thermistor... only the 02-03s have to do that if they wanna use the 00-01 MAF.
Puppetmaster is offline   Reply With Quote
Old 06-04-2005, 09:02 AM   #42
Send a message via MSN to instil
Quote:
Lovely. Dude,youre of few that actually answer my questions.thanks
instil is offline   Reply With Quote
Old 06-04-2005, 09:05 AM   #43
Send a message via MSN to fishpony
anyone have an extra IAT thermistor they would sell me? I NEED ONE
__________________
Shift_This
Fiberglass boxes
www.fishercustoms.com
fishpony is offline   Reply With Quote
Old 06-04-2005, 10:41 AM   #44
Can I use a 2K1 MAF for a 2K maxima?
If yes, do I have to reprogram my ECU/just disconnect battery for couple of hrs...
Love_00_Max is offline   Reply With Quote
Old 06-04-2005, 06:22 PM   #45
How do you know its MAF? Whats the code it reads.. And when you say stutters? Is it when you step on the gas.. and sounds as if something is stuck, and then you release the gar (goes away) step on it.. stutters again? BEcause I got this problem now.. and it sounds like something is stuck when I step on it at 1500 rpm to 2000 rpm. Got the SES light on, but Autozone says P1130 which is a switl control? Any help.. Thanks.
zaku178 is offline   Reply With Quote
Old 06-09-2005, 08:58 AM   #46
Send a message via AIM to sooner02r1
I can't get the thermistor off my old MAF. Am I an idiot??? Is there some trick to it??
__________________
'02 Max - 6 spd., LSD, S tech/Illumina, Weapon R Intake, HP Autoworks STS, Custom Enterprise FSTB, Warpspeed Y, G35c 18x8s, everything black and shaved, Custom tails painted by xlcrew
sooner02r1 is offline   Reply With Quote
Old 06-09-2005, 11:24 AM   #47
Unsuccesful STL Coordinator
Send a message via AIM to Epacy Send a message via Yahoo to Epacy
If it won't pull out then just cut it under the metal clip. It will shorten the length but still be fine. Or you can try to spread the metal clips apart that hold it in. I had to clip mine.
__________________
Epacy is offline   Reply With Quote
Old 06-09-2005, 11:36 AM   #48
Still Here... IM me for more..
HNDA ETR's Avatar
Send a message via Yahoo to HNDA ETR
Quote:
I used a small eyeglass flathead screwdriver and pried to the two halves apart.
The thermistor wire goes between the two halves and then the halves get squeezed together. You need to pry the two halves apart.
Take a look at the new MAF and you'll see what I'm talking about.
HNDA ETR is offline   Reply With Quote
Old 06-09-2005, 05:14 PM   #49
Okay, next problem. I got the thermistor in, reset the ECU started it up, SES is still on. Anybody else have this problem?
__________________
Old 06-09-2005, 08:46 PM   #50
Is it the same code? Try resetting the ECU after you have ran it at least a little bit.
__________________
Old 06-10-2005, 06:12 AM   #51
Cool deal, no more code. Thanks Eric. Got my headlight cases painted black, I'll post up pics soon.
__________________
Old 12-05-2005, 11:03 AM   #52
Quote:
Originally Posted by Y2K1GLEMAX
Finally something better in a 2k1 than 2k2 or 2k3
I also ear that the 2k1 drivers are better as well. Lol
doublea is offline   Reply With Quote
Old 12-06-2005, 01:06 PM   #53
Send a message via AIM to cpuguy06 Send a message via MSN to cpuguy06
Do the 2k2 have the same problem as the 2000 and 2001 with the MAFs going bad?? Or just if it was manufacured before 11/01?
cpuguy06 is offline   Reply With Quote
Old 12-06-2005, 01:13 PM   #54
Super Moderator
Quote:
The 2002s come with either 22680-6N201 or 22680-AM600 and the 6N201 is supposedly the more problematic MAF while the AM600 is more robust.
The 22680-2Y001 MAF from the 2001s seems to be the best of the lot and is cheap, which is why people are using it in place of the weaker 6N201 and good but expensive AM600.
Read the first page of the thread, this info is all there.
Old 02-15-2006, 02:48 PM   #55
I need an IAT thermistor as well mine broke while taking it off at the thermistor itself. Does anybody know where to get one or the specs on it? there are lots of websites that sell these but i need to know the specs for it. And can i run the car without it, would it run fine?
biggun is offline   Reply With Quote
Old 02-15-2006, 10:34 PM   #56
Super Moderator
Quote:
Have you tried junkyards? Ya might be able to find the entire MAF too...
You can run fine w/o it, but will just throw a CEL.
Old 02-15-2006, 10:36 PM   #57
Need A Light?
steven88's Avatar
Send a message via AIM to steven88
ya no rush...it only throws a CEL and is more of an annoyance than anything
unless emission time is coming soon....
steven88 is offline   Reply With Quote
Old 03-09-2006, 01:15 AM   #58
good info!
but why would the maf blow from just an intake?
Chas
acidbbg is offline   Reply With Quote
Old 03-18-2006, 03:33 PM   #59
vsamoylov
Quote:
Originally Posted by Jime
For the 2k1 there are 2 MAF's available.
22680AD201 $424.73
226802Y001 $90.11 (This is the one that requires the sensor transferred.)
what is the difference between these two maf sensors?
Old 03-18-2006, 05:00 PM   #60
Need A Light?
steven88's Avatar
the expensive one is the early 2k2 MAFs...that one comes stock with an IAT sensor...I believe late 2k2s came with the AM600 MAF
the less expensive one is the 2k1 MAF....this one does not come with an IAT sensor and requires transferring...
Old 03-18-2006, 05:19 PM   #61
vsamoylov
i understand that part but it says for 2k1 maxima. 2k1 also had the IAT sensor?
Old 03-18-2006, 06:29 PM   #62
Need A Light?
steven88's Avatar
2k1 Max has the IAT sensor on the scoop thingy....starting from 2k2-2k3, they put the IAT sensor inside the MAF itself...
the 2y001 and AM600 MAFs are both the strongest from what I heard....the 2y001 is obviously much cheaper as the AM600 cost $400 something like the AD201....both AM600 and AD201 have the IAT built in...
Old 03-18-2006, 06:33 PM   #63
Not a Maxima owner
MaxBoost925's Avatar
Can the 2K-2K1 temp sensor substitue for whatever is missing from the 2K2-2K3 MAF?
MaxBoost925 is offline   Reply With Quote
Old 03-18-2006, 06:37 PM   #64
Need A Light?
steven88's Avatar
I don't think so...I believe the IAT sensor for the 2k2-2k3 is shaped alot differently than the 2k-2k1...
why? did your MAF blow?
Old 03-18-2006, 06:47 PM   #65
vsamoylov
explain this part
22680AD201 $424.73
jime said there are 2 MAF's available for 2001 maxima. what is the difference between those 2 maf sensors? i am not talking about 2002-2003 maf and the IAT sensor. I know about how the 2k2-2k3 have it on the maf itself and the 2k-2k1 have it seperatly. all i am asking is why there is 2 different mafs for the 2k1 and the price difference.
Old 03-18-2006, 07:10 PM   #66
Need A Light?
steven88's Avatar
oops, I thought the AD201 was the early 2k2 MAF sensors...my bad
Old 04-23-2006, 05:06 PM   #67
Send a message via AIM to dfownz
I have a '00 SE. All of the MAF's talked about were 01's or above. Is there anything that I should worry about?
DF
dfownz is offline   Reply With Quote
Old 07-16-2006, 10:18 PM   #68
I've got an 02 SE and a lot of the symptoms indicating a bad MAF. A few questions:
1) After installing the new MAF, does the ECU need only be reset or reset AND reprogrammed?
2) The wire replacement definately isn't a problem, but I have no idea where the MAF is housed and how to get to it. Is there a writeup on how to do this whole install?
TIA
__________________
For sale...
Custom kickpanels - http://forums.maxima.org/5th-generat...ml#post7111061
DLS Iridium 6.3i frontstage
New ride: 2009 Moonlight White G37X
2002 Maxima SE w/ 126k miles... SOLD
02maxxxSE is offline   Reply With Quote
Old 07-17-2006, 02:57 PM   #69
Send a message via AIM to Nomad
Quote:
Originally Posted by vsamoylov
explain this part
22680AD201 $424.73
have exact same Q
Nomad is offline   Reply With Quote
Old 07-17-2006, 03:02 PM   #70
Jime's Avatar
Apparently they were changed part way through the year.
Jime is offline   Reply With Quote
Old 07-17-2006, 03:04 PM   #71
When you purchase the new sensor, it will be the entire unit. Basically, it's the black plastic housing that connects to your air filter box. Has a wire connector on the top of it.
You don't replace just the sensor, but the entire housing.
I replaced my '02 sensor with the '00/'01 sensor due to the price difference and just swapped out the IAT sensor from my old one. Very easy to do.
Only thinig I did not do is get it reprogrammed with the new mappings. I still get sluggish take-off around 2-3k rpms. When time permits, I will let the dealer reprogram it. Hope that helps.
nismopc is offline   Reply With Quote
Old 07-19-2006, 09:21 AM   #72
Does the 2000 SE take the same MAF as in 2001, and which is better, or are they just the same??
bones4u is offline   Reply With Quote
Old 09-23-2006, 02:05 PM   #73
I have a 2000 Maxima. I changed the MAF with part # 22680-2Y001, but my old one is stamped 22680-AD200. Now the car is very hard to start. It appears the new part for 22680-Ad200 is the 22680-AD201, yet i dont have that thermistor on it like it says on the other threads. My car is a Calf. emmissions, I wonder if thats why its different. Before you buy a MAF check the part # on the existing one in your car. Its on the outside of the cylindrical part
TJM339 is offline   Reply With Quote
Old 05-22-2007, 09:10 AM   #74
Guess I Got Screwed
So...i know nothing about cars. I just get in, turn the key and drive. However, i would like to know a little something now.
My 2001 Maxima was acting funny. I bought it at 68K last year June. Its now at 94K. I travel the east coast alot. But about 1 month back i went to Strauss and got a full tune up cost ~700 with 2 new tires. Now, my car was acting funny again. i thought it was my transmission so i took it to lee myles. after testing they said it wasn't and performed a full diag. The guy called and said it was the Mass Air Flow Sensor and quoted me $687.59 w/tax.
I guess i got screwed or the ordered the $400 part and are charging me 200+ for 15min of work?
JoeyJustCuz is offline   Reply With Quote
Old 05-22-2007, 10:01 AM   #75
yes...for a 2k1 that price is very high. Buy it from Dave B and install it yourself.
slickrick is offline   Reply With Quote
Old 05-22-2007, 10:10 PM   #76
joebangaa's Avatar
You got more than screwed
__________________
AEM/Cattman/Energy Suspension/FrankenCar/Motostorm/Place Racing/Progress/SSR
/////Alpine/CDT/Eclipse/KnuKonceptz/Optima/SoundSplinter/US Amps
joebangaa is offline   Reply With Quote
Old 06-06-2007, 07:47 PM   #77
How do you guys replant that little thermo sensor in a 2001 maf???I can imagine how to remove it from my old 2002 maf since it just blew.Had to replace the maf with the 600 one.
Can I put back my berk intake without being afraid of it blowing again in 1 year?
theoutsider is offline   Reply With Quote
Old 06-06-2007, 07:58 PM   #78
I havent done it yet, but plan on doing it. Aparently the 01 MAF does have an area for that sensor to clip onto, it just wasnt incorporated in the 01 model year yet. I've read that it's just two clips, and you transfer the wire. And the berk wasnt the origin of the MAF going bad, 2k2 MAF's bite the big one. 2k1's are the strongest
__________________
Ricer [risse-urr] N.
[Ricer: from the Latin word Ricarius meaning to suck at everything you attempt]
bwinter7 is offline   Reply With Quote
Old 06-06-2007, 08:09 PM   #79
Quote:
What do you mean bite the big?Are you telling me that the maf going bad is totally NOT related to the installation of the berk intake??I thought I simply shortened the life of my old MAF because of it.Btw I checked every clamp fitting and bolts 2 times a week to make sure everything was fine.
Can you confirm 100% that my new 600 maf wont go bad faster because of the berk intake???
Old 06-06-2007, 08:18 PM   #80
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Have any of you even looked, read, and/or comprehended the first page of this thread? Come on now
April HID Group Buy!
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
