Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 09-30-2004, 07:15 PM   #1
Send a message via AIM to lildeigo31
Location Of O2 Sensor
I have a 2000 maxima SE. Can anyone tell me where the location of Bank 1 sensor 1. The 3 O2 sensors are color coded with Red, blue, and White. Does anyone know which one bank 1 sensor 1 is. Please help me out I need to pass my emmissions so I need to fix the sensor. Thanks.
lildeigo31 is offline   Reply With Quote
Old 09-30-2004, 10:12 PM   #2
Send a message via ICQ to billyman Send a message via AIM to billyman Send a message via MSN to billyman Send a message via Yahoo to billyman
I'd like to know this too.
__________________
2000 SE Sterling Mist: "I prefer to hang out with two of them, it's better for conversation. See, if there winds up being any, I don't have to be involved."
billyman is offline   Reply With Quote
Old 10-01-2004, 10:12 AM   #3
HO2 Sensor location
The HO2 sensor, B1S1 connector is located between the fire wall and the engine on the passenger side, near the wiper motor. The sensor itself is located in the exhaust manifold between the engine and the fire wall. Not easy to see.
You have 4 sensor on this engine:
Sensor 1 bank 1 (on the cylinder one side, exhaust manifold)
Sensor 2 bank 1 (on the cylinder one side, exhaust pipe)
Sensor 1 bank 2 (on the cylinder two side, exhaust manifold)
Sensor 2 bank 2 (on the cylinder two side, exhaust pipe)
Techman is offline   Reply With Quote
Old 10-01-2004, 11:36 AM   #4
Thanks, but I only see 3 O2 sensors. Also do you know the color of the bank 1 sensor 1. I see red, white, and blue. Can you help me anymore.
Mike
Old 10-01-2004, 12:42 PM   #5
I believe that the 2000 year has 3 and the 2001 has 4 o2 sensors. There is a TSB which outlines the entire system and shows where the harnesses attach. With color codes, RED WHITE BLUE, etc.
emhc1999 is offline   Reply With Quote
Old 10-01-2004, 08:09 PM   #6
What is a TSB?
Old 10-04-2004, 04:59 AM   #7
On 5th Generation MAX, chassis A33 you have "4" Oxigen sensors. 2 on each side off the engine. One before de cat. converter and one after de cat.
The sensors before de cat. converter are the sensors "1". The sensor after de cat. converter are the sensors "2".
The sensors on the number 1 piston side are sensors "bank 1". The sensors on the number 2 piston side are sesnsors "bank 2".
The two S1 sensors are identicals. The two S2 sensors are identical except for the wire jacket color.
So you have four sensors:
S1B1 3 wires, normally blue jacket
S1B2 3 wires, normally blue jacket
S2B1 4 wires, normally white or gray jacket
S2B2 4 wires, normally red or red/brown jacket
I how this will help.
Old 10-04-2004, 08:06 PM   #8
Points: 6,285, Level: 51
Points: 6,285, Level: 51 Points: 6,285, Level: 51 Points: 6,285, Level: 51
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
The 2000 SE in question is a Federal and Canada configuration. Only three O2 sensors are used. The one under/in the front manifold is the B2 sensor...coded BLUE, the one under/in the rear manifold is the B1 sensor .....coded BLACK, and the sensor right behind the cat. (rear B1) is coded WHITE. The TSB is NTB02-051a. July 03.
P. Samson is offline   Reply With Quote
Old 10-04-2004, 08:18 PM   #9
Send a message via AIM to Gennady7
the cali emissions has 4 O2 sensors.
the fed has 2
and the can has 3 (i think)
Gennady7 is offline   Reply With Quote
Old 10-04-2004, 09:31 PM   #10
Activity: 0.4%
Let's not confuse lildiego31. I own a Federal/Canada 00 Maxi and have previously located all the O2 sensors on this vehicle and I have a copy of the TSB in front of me. If it is a 2000 and not a Calif. spec. car it has the above mentioned three sensors. There will be NO red harness.
Old 10-06-2004, 04:49 PM   #11
I have a 2000 Maxima SE with California emmissions. I only see 3 O2 sensors. I see one in the front by the radiator with a blue jacket, and two underneath with a red and white jacket. The red jacket is in the manifold and the white one is right before the cat converter. So in this case would bank one sensor one be the one with the red jacket covering. I talked to nissan and they are just confused with the whole thing. Sorry guys I am really having trouble with this. It is really confusing but I really apprecitate it greatly. If you have an instant messanger name please feel free to IM me. I am located in the pittsburgh area. "LilDeigo31" is my screen name.
Thanks,
Mike
Old 10-06-2004, 06:59 PM   #12
Activity: 0.4%
lildeigo31: You have it figured out except you have not yet located the Bank 1 (rear cylinder bank, B1) (Black) 02 sensor. It is located at the back end of the pre-cat just below and on the right side of the connection of the rear exhaust manifold and the pre-cat. It is confusing because Nissan labels it as the H02S1-B1 Front O2 sensor. The connector is located inboard of the RH strut tower about a foot just in front of the firewall.
Old 10-06-2004, 07:33 PM   #13
Okay thanks Samson I found it from the top I am going to check it out and find it from the bottom tomorrow. Thanks to all of you guys you have been a big help.
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
