my car understeered into a curb...
Old 10-06-2004, 06:48 PM
Teufelhunden's Avatar
my car understeered in the rain going about 40, i was going into a turn, not a 90 degree, but merging into traffic, and my car just kept going straight, i couldnt slow down in time and i hit the curb pretty hard, my front drivers side wheel is sitting at an angle now, its bent inwards. now what does a front axle look like? and a lower control arm?
is its easy to fix?
should i take it to the dealers?
any suggestions?
Teufelhunden is offline
Old 10-06-2004, 06:52 PM
Maxima addiction cured w/ the GS pill
aliti19's Avatar
Don't take it to the stealer. Just go to a good mechanic. Save yourself some money. Were you riding on the OEM Potenzas?
aliti19 is offline
Old 10-06-2004, 06:54 PM
my rear view mirrors flap like a f-ing bird
Tek-Niq's Avatar
is its easy to fix?
any suggestions?
yea, these tires suck in the rain. go to the dealer might cover it. if your under 36000 miles. you probably messed up the camber hopefully
Tek-Niq is offline
yes, ive heard that stock tires suck, i thought these were suppose to be good,
i guess i better get new tires...
Old 10-06-2004, 06:57 PM
I live life on the edge
skalberti's Avatar
RE 92 Potenza's "for the serious driver in you"
skalberti is offline
Tek-Niq's Avatar
they are good tires its just r too low profile for the rain
Tek-Niq is offline
Old 10-06-2004, 07:02 PM
skalberti's Avatar
HMMMM, I have an inch wider tire than the stock craptenza's and a lower profile. I sail through the rain @ 70-80 mph with no problems. With the craptenza's I was hydroplaning at 50mph. I think Nissan just put those tires on the car to get it to the dealership, Then your car outgrows them on the way home and you have to go buy new ones.
Old 10-06-2004, 07:07 PM
im not talking about the tires though..... i just want to know what i can do,
is it fixable?
Old 10-06-2004, 07:10 PM
aliti19's Avatar
It's hard to know exactly what you screwed up until a mechanic gets in there and takes a good look at it. If you were able to drive it home, it couldn't be that bad.
aliti19 is offline
Old 10-06-2004, 07:11 PM
skalberti's Avatar
is it fixable?
Chances are you bent the wheel. If the impact was severe enough you may have damaged the strut or at least knocked it out of alignment. First I'd pull off the wheel and look at that. If that is fine then I would have the alignment checked. Thats still cheaper than going to the stealer.
Old 10-06-2004, 07:13 PM
i was able to drive it pretty fastabout 45,but my tire is not straight, the treads are facing outwards, so it was squealing like crazy, the steering wheel is loose too, and btw why doesnt my signature show up?
Old 10-06-2004, 07:15 PM
Tek-Niq's Avatar
put [img] [/img] on the beg and end
Tek-Niq is offline
Old 10-06-2004, 07:16 PM
aliti19's Avatar
Is shows up only once per page. Go edit one of your posts above and make sure SHOW YOUR SIGNATURE is checked.
aliti19 is offline
Old 10-06-2004, 07:18 PM
Tek-Niq's Avatar
here
try this with [img] [/img]
http://images.cardomain.com/member_i...19_22_full.jpg
Tek-Niq is offline
Old 10-06-2004, 07:20 PM
Tek-Niq's Avatar
its too big tough
Tek-Niq is offline
Old 10-06-2004, 07:21 PM
Tek-Niq's Avatar
heres mine
Tek-Niq is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
MikesChevelle
09-28-2015 08:14 PM
Balkins
08-12-2015 06:39 AM
altome15
08-10-2015 07:05 PM
Quick Reply: my car understeered into a curb...
