Ignition Coil Recall Petition - Letter Sent To Nissan With 601 Signatures
Old 08-31-2004, 01:01 PM
ohcello's Avatar
Dear Maxima Owners,
I mailed out a written complaint to Nissan North America on 8/31/04. The letter included all 601 current Petitioners' signatures. I will keep you all posted if I hear anything. Thanks for your participation!
If you haven't signed the petition yet, here is the URL:
http://www.PetitionOnline.com/NIS_IGN/petition.html
Thanks again,
Chris
ohcello is offline
Old 08-31-2004, 02:58 PM
retired moderator
irish44j's Avatar
Though I doubt anything will happen, nice job on at least trying! Who knows, maybe Nissan will actually do something (stranger things have happened)....
irish44j is offline
Old 03-28-2011, 05:05 PM
nissanmaxima2000's Avatar
so how many signatures does one need to get the goverment or the company to do something because this petition now has 4,633 signatures?
nissanmaxima2000 is offline
Old 03-28-2011, 05:12 PM
Slick_54's Avatar
its been almost 7 years....I dont think they are going to do anything
Slick_54 is offline
Old 03-28-2011, 05:26 PM
That's Mr. Detail to you
Scottwax's Avatar
4634 Signatures Total
Scottwax is offline
Old 03-29-2011, 09:35 AM
Love_00_Max's Avatar
F..ck Nissan. If a company can get ignition system (heart of an engine) wrong, who cares what comes of this notice. Seriously if one can get basics wrong why will anyone care to buy a Nissan. I have replace 7 coils since buying my nissan in 2000. Not right, if the ignition is messed up everything downstream is messed up too like O2, pre-cats, cats, #x of $120 for diagnosis for P0420/P0430, perenial scare if we will fail emissions.. I don't need this nonsense headache... I need a reliable car even if drives like a old Caddy...
As I said earlier this is my last Nissan / Infinity. I am very happy with my other vehicle being a Highlander and will go with Lexus when I am up for a refresh.
Love_00_Max is offline
Old 03-29-2011, 09:42 AM
phatboislim's Avatar
only thing that needs a recall is the fukin fail transmissions from teh 4th gen and up
phatboislim is offline
Old 03-29-2011, 09:57 AM
2000_MAXIMA_KING's Avatar
Every maxima I had when the trans started to feel like it was slipping and it slammed into gears it turned out to the maf sensor, 3 maximas same prob all fixed after maf sensor replaced. Also a simple drain/fill on these trans makes them last for a good amount of time. The real recall should be on these POS maf sensors.
2000_MAXIMA_KING is offline
Old 03-29-2011, 09:59 AM
4633.Tyler Davis 2000 Nissan Maxima GXE is my first and last nissan. Hope you clowns go bankrupt
This has to be Love_00_Max
Old 03-29-2011, 10:00 AM
trans are ****.
Old 03-29-2011, 10:05 AM
"I'm just sayin'..."
nelledge's Avatar
Uhhh... Have you looked at the recalls and service bulletins for the Lexus and Toyota models? Or any other manufacturer for that matter? Fuel leaks, incorrect seals in brake master cylinder, weak valve springs, etc. These Toyota/Lexus items sound pretty basic, also. No manufacturer is immune. If it's not coils, it's something else. 7 coils over the length of a decade isn't bad for maintenance on a vehicle. Cheap, actually. I'd also bet money that the anecdotal evidence of failing coils exaggerates the "issue" because no one takes the time to make a thread about how long theirs have lasted. My 4th gen had 182,000 miles on it with factory coils. I replaced a coil on my 3rd gen at 175,000 miles, but only because I tore the boot and decided to change the coil assembly. I understand people are upset that cars break down, but they do. There are worse reasons to get agitated.
nelledge is offline
Old 03-29-2011, 10:08 AM
thats what i'm thinking as well. i really dont see a need to get pissed about coilpacks...other cars you have to do tune ups more often (including plug wires) but you can get away w/ coilpacks for a while.
like i said..i'd worry about the transmission more than anything
Old 03-29-2011, 10:17 AM
Other then the maf sensors being crap, I don't see anything wrong with these vehicles
Old 03-29-2011, 10:21 AM
Old 03-29-2011, 02:30 PM
Scottwax's Avatar
trans are ****.
194,595 on the original 4AT in my first 5.5 gen and it was shifting great. In the 81k miles I drove the car, no coils failed either. As far as I could tell the MAF was the original too. Maybe I just lucked out because according to my VIN and 06/01 build date, I had the 91st 2002 Maxima to roll off the assembly line.
The only reason I replaced two coils (bought a used set a while back because of all the threads about coils going bad) when I changed my plugs on Saturday on my 6MT 5.5 gen was because #3 had a P0303 code that was flashing the SES light and the culprit seemed to always be either the plug or the coil. Even though the plugs looked to be the originals (150k miles) and I was 95% sure that was the cause of the misfire, I still changed it to be on the safe side. I changed #5 as a preventive measure since that spark plug tube had oil in it.
Scottwax is offline
Old 03-29-2011, 02:53 PM
dot dot dot ...
NmexMAX's Avatar
So, we bump 7 year old threads and complain about everything else on the car?
www.autotrader.com
NmexMAX is offline
MAXSE5SPD
09-17-2022 04:00 AM
kmitchel
10-30-2015 10:12 AM
Justin Kroll
09-02-2015 11:06 AM
maximusrising
09-02-2015 09:55 AM
coasterswim
09-02-2015 07:43 AM
Quick Reply: Ignition Coil Recall Petition - Letter Sent To Nissan With 601 Signatures
