Need help replacing interior bulbs(Climate Control and Heated Seats)
My left side of my automatic climate control on my 2000 Max is out. Anyone have a write up or how to for replacing this bulb?
Also, my heated seat button isnt lighting up. The bulb is burnt up, so I took it out. I haven't seen a bulb like this before. Is Nissan the only place I can buy this bulb from?
Yeah, the way you access the A/C unit is like taking out the radio. They are all mounted on the same bracket. Once removed, take off the rear panel of the A/C unit and there you will find about three bulbs, I believe. As a matter of fact, my right side is burned out. I need to change mine. To get to the whole unit, start from the shifter trim and pull it out. Remove cigarette lighter plug and hazard plug, Pull/remove top of A/C vents trim. Remove 4 bolts holding the bracket and you're done.
