Door Panel Removal
The Trim around the door open release handle pops off, then there is a large clip on the inner door edge that needs to be poped out- there is a screw under that clip. Remove the small cover inside the door grab handle by the power window controlls. There will be a screw under that little cover. Remove the screw and then pull out the black door pull handle. Then stick ur hand under the bottom part of the door panel and tug on it. Its installed on plastic clips that just pop out when tugged on. Remove the wire harness connectors from the power window master switch, the door courtessy light. And then put the panel away and U are set ready to remove the OEM crappy speakers.
95naSTA
09-21-2015 06:50 PM
lkiller123
09-21-2015 03:00 AM
carid
09-17-2015 05:00 AM
