5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I cleaned the trottle on my 2000 max VQ20DE engine using carb cleaner. When I put everything back together the engine would repeatedly race to 2k then drop to 1.5k over and over again. There is proper accelleration but I do not need to use the accellerator to drive within the city, the idle speed is so fast.
Not being able to go past 2k RPM is one of the symptoms of a blown MAF. Besides, I between a fragile MAF and butterfly, I'd say there is much more of a chance that his MAF sensor is the problem.
no i highly doubt its the maf sensor.......maximapolak cleaned his TB as well and his idle went up to 900
somehow you messed up the butterfly in teh TB
-J
My light finally turned off (after taking it off and cleaning it totally) and now all i have to do is reset my idlle....sorry the 2k3 is defferent from yours...
__________________ Newest Maxima mod: Pioneer AVIC-D3 Next Maxima mod: Stop dumping money into the car. For real this time. Newest Yamaha R6 mod: Euro R6 Left Switch (Pass button and Hazzards) Next Yamaha R6 mod: Dunno...plenty of things to go.
My Maxi ran a 14.5 @ 95 on 4/10/05 (no weight reduction). MADE IN POLSKA
You're not supposed to use carb cleaners on our cars. The appropriate cleaner would be air intake and manifold cleaner that is not caustic to the intake. Carb cleaner is for cars with carbs and it may have eaten away at the lining of your TB or maybe messed up a sensor.
also unplug the mafs wire clip from the MAFS itself, make sure they are making good contact, and that the wires going to the pulg are all intact and not cut/damaged. this has happened to me before.
I highly doubt it would be the butterfly, puting much more trust that it is the mafs. good luck.
does your maxima have a carb? then why would you use carb cleaner. Like ABDomega said, carb cleaner can eat away at certain components of FI (fuel injected) engines...seals, sensors, etc....
I'm holding a bottle of Gumout Carb/Choke cleaner (that I use on my lawn mower) and the back of the can specifically says "not recommended for fuel injected vehicles"
I use CRC or Gumout Air-Intake and throttle body cleaner.
lesson to all: always read the can carefully before spraying any sh1t on/in your car!
reminds me of my Honda, which took a special power-steering fluid (made for all hondas) because regular power steering fluid that ALL other cars use will eat away at the valves in the PS system. I learned the hard way about this after having to replace my steering rack.....now I always read the can and shop manual for fluids/cleaners...
__________________ Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
Emissions. More than half of this world has restrictions on engines over 2.2 liters. Israel just started to introduce cars with 3 liter engines and some countries don't allow anything more than 1.7 liters for example.
Thanks for all the responses. I was able to eventually find the problem. I bought the car doing 37K kilometers. Apparently the last person to attend to it simply turned up the trottle stop screw instead of cleaning the trottle.
After I got rid of all the gunk in the trottle I needed to turn the stop screw back.
Do you have any codes?
i agree with abd, you made a big booboo. check if you tb is still smooth on the inside. push the butterfly plate and run your finger on the inside of the tb. for future notice your supposed to use intake manifold cleaner. Good luck
__________________
********OFFICIALLY THE 1ST 5TH GEN WITH NWP ENGINEERING IM SPACERS INSTALLED!!!!********
PR CAI / Exedy Stage 1 / Pacesetter STS / Larrio's Shifter Bushing / Fidanza / Cattman Headers & Exhaust / Custom Enterprise Test Pipe / All ES Bushings / SS Brake and Clutch / S-techs with Illuminas / Blehmco 300zx Brake Upgrade / FSTB / RSTB / RSB / Walbro / Autometer / Emanage Ultimate / Innovative Motorsports LM-1 Wideband / AE VLSD Tranny / Rev-up Oil Pump / Scan Gauge II / Home Depot Catch Can / JB Welded VI / KOYO Rad./ 350Z Thermostat / 19" Forged G35 Rims
a big reason why alot of foreign cars are so big on turbo....just look at Audi and VW using the 1.8T because it gives power but still is good for emissions because it's ONLY 1.8 l......go to Italy and everything's a turbo it seems, and all the engines are 1.5-1.8 liters...Fiat, Alfa Romeo, Citroen, Seat, etc....
Audi 1.8L turbos suck... K03 Turbo by KKK will go out on ya at around 50K miles no matter how well U maintain the car. The engine is pretty much maxed out with built bottom end and all the tricks at 350WHP. My G20 has stock internals good for 450WHP. Nissan don't build motors like they used to. Back in the day they had kick *** motors like CA18DETs, FJ20, RB20DET, SR20DET, or even a 320HP SR20VET. Now all we got is VQ this VQ that... not that its a bad motor but I'm getting sick of seeing mini vans with what used to be a Maxima exclussive motor.
EDIT- I used to own a 00 S4 with all the bolt ons before my Maxima, and I'm a certified Audi Technician with years of experience on german crap.
__________________
Mike Jez
2004 Volkswagen R32.
OZ wheels, tons of suspension mods, brakes, go fast & light goodies.
my maxina 2001, MAF fail so just changed a new one.
But the engine always try the lower idle speed, it get 750 rpm first, and then try to 600 and even 550. So, the car is shaked and then return a bit high.
I have no equipement to measure it. I've runned about 100 KM, but it is still same.
Can someone help to tell how to let ECM remember the proper idle speed?
-94 toyota pickup 4cyl 4x4 daily work truck
-97 camaro z28 [ sold]
-06 -g35 sedan 6MT [sold]
-02 merlot red 6mt full bolt ons [sold]
-97 - maxima 5MT [ hit bambi at 75mph]
Ya I was looking at getting new S4, but heard audi had alot of problems.
tho guys on the forum seem to say they are fine, i stayed ith the VQ
my parents have 2 audis... they always are calling me to find someone who can fix them lol.. ones a 01 the other is an 05 i think... theyre nice cars... if you have the time and money to keep up with them
uhhhhh disconnect the negative cable for a generous amount of time and then warm up the car for a little....like you should most the time you work on a car
__________________
2K2 SE 6 speed Grey Lustre SE Every option minus navi, black leather, HLSD, Hotshot headers, Cattman Catback, Frankencar WAI, HP autoworks STS, ES motor mount inserts, ES shifter bushings, FSTB, RSB. JIC FLA-1 coilovers, A34 Brakes Hawk HPS pads, TR Motorsports MT1's, Toyo 4s, 64,000 original owner miles.
I have to agree. I sold VW for 2 years and those 1.8 liter cars suck. I've dealt with a lot of used Audis as well and have never been impressed with one. Good luck on even making it to the timing belt change before the plastic water pump fails.
They're over enginered with overly complex and fragile electronics. All without much benefit.
__________________
2K2 SE 6 speed w/leather, sunroof and Bose : HLSD tranny from 2004 car, Fidanza 15lb flywheel, 350Z clutch, Hotshot headers, Warpspeed B-pipe, PR CAI, homemade VAIS blockoff plate, Apexi S-AFC2, 17 degree timing advance, HP autoworks STS, PR solid motor mounts, PR shifter bushings, FSTB, RSB. Eibach springs with Ilumina 5-way adjustable struts, 16.5 pound Enkei Wheels. Over 145,000 miles. I turn my own wrenches.
Audis are not kickass aside from an RS4 and that's only cause it has a V8. My 2000 VQ30DE-K Max w/4-speed auto and 2-12" subs in the trunk ran a .83 seconds faster in the quarter-mile than my buddys 2003 1.8T Passat (VW but same power as Audi) w/5-speed manual
