Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-22-2004, 09:46 AM   #1
Code help needed: P0110 and P0105
Hi,
I replaced my spark plugs, ignition coils, radiator fan motor and thermostat last weekend. When I started the car back up, the SES light was on. The codes thrown were
P0110 IAT Mal
P0105 Map Cir Mal
The IAT=Intake Air Temperature but not sure what that means. I had the codes cleared by a mechanic and they haven't come back yet. Can anyone explain what the codes mean? And is this just due to replacing too much stuff at once and it temporarily trippped a code but doesnt indicate a long term problem?
Any advice is appreciated.
Compton is offline   Reply With Quote
Old 06-22-2004, 10:16 AM   #2
Send a message via AIM to Igor911 Send a message via MSN to Igor911
Check out this thread:
http://forums.maxima.org/showpost.ph...11&postcount=2
Igor911 is offline   Reply With Quote
Old 06-22-2004, 10:19 AM   #3
Thanks for the link.
But what do they mean?
P0105 Absolute pressure sensor
P0110 Intake air temperature sensor
Old 06-22-2004, 10:37 AM   #4
detects ambient barometric pressure and sends the voltage signal to the ecm. as the pressure increases the voltage rises.
problem could be the harness or connectors (sensor is open or shorted) or it could be the sensor itself.
you could try to loosen and retighten your engine ground screws.
disconnect the abs. pressure sensor harness and cehck it for water.
there are other things to check too, but you need tools to do it.
this is mounted to the air duct housing. it detects air temp and sends a signal to the ecm. this problem could also be caused by the harness, or the sensor itself. try wiggling it, or disconnect and reconnecting it. if that doesn't work, again you need tools.
ihavea5spd is offline   Reply With Quote
Old 06-22-2004, 11:34 AM   #5
My mechanic might have disconnected some of these things temporarily when installing everything. Hopefully that is all it is
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
