Reverse Camera in trunk key hole------->
Old 06-10-2004, 06:48 AM
K Pazzo 6's Avatar
Anybody have this done?
I just got my camera in mail & wondering if theres any pointers from those who have done this on how to take out current keyhole mechanism? (i'll probably figure it out weekend when i have time if nobody knows.)
p.s. i got this camera http://cgi.ebay.com/ebaymotors/ws/eB...tem=7904241070
K Pazzo 6 is offline
Old 06-10-2004, 07:15 AM
4x4Max's Avatar
I would do that if i had a monitor in my car...sounds like a good idea
4x4Max is offline
Old 06-10-2004, 07:48 AM
MiniRX7's Avatar
How are you going to make ur screen switch automatically to the reverse cam when you shift your car to reverse?
I had an idea on how to do this, but i am not sure you wanna hack your deck up.
See, on my 7"screen, its just the screen, there is a button which switches between Video 1 and Video 2.
What i was planning on doing was hacking the screen. When a reverse signal is engaged, it will pulse the video screen signal switch to Video TWO, and when the reverse light is off, it will pulse again, swithcing the screen back to video 1.
But many headunits like yours already come with a wire that taps into the revesre light and switches it.. Which is sweet.
ED
MiniRX7 is offline
Old 06-10-2004, 07:49 AM
scopium
thats usually for bigger cars.. that cant really see behind them...
although it would look pretty unique
Old 06-10-2004, 07:56 AM
tEh Hope
Maxxxed's Avatar
I think this is an awesome device especially for someone with dark tints... it would be cool if the camera has nightshot...
Maxxxed is offline
Old 06-10-2004, 08:10 AM
MacAlert's Avatar
I believe the AVIC-N1 has an option for reverse camera.
MacAlert is offline
Old 06-10-2004, 09:02 AM
SMX
SMX's Avatar
Yep, it does
SMX is offline
Old 06-10-2004, 09:24 AM
pablosal's Avatar
Sounds like a plan, if only I had a screen
pablosal is offline
Old 06-10-2004, 09:38 AM
BLaZin 2k MaX's Avatar
You should be able to push it out from the back of the lid.
BLaZin 2k MaX is offline
Old 06-10-2004, 02:17 PM
K Pazzo 6's Avatar
i'll play around with it sat. or sun.
Old 06-10-2004, 02:19 PM
K Pazzo 6's Avatar
Old 06-10-2004, 03:21 PM
MiniRX7's Avatar
Lucky bastard!!
MiniRX7 is offline
Old 06-10-2004, 03:36 PM
Nismo98's Avatar
I think Max4Speed has or had one of those, but it wasn't the one for the key hole.
Andrei
Nismo98 is offline
Old 06-13-2004, 09:38 PM
thomasd cook's Avatar
I just installed my video system last week. It cost me $200 for a 7.2" in-dash monitor. I kept my headunit and am using that as my head source. I also put an X-Box under the seat for DVD's. I also have a 3 input TV tuner which accepts 3 inputs and a rear view camera. I just so happened to install my camera today. I love it. I hooked it up so I can always flip it on whenever I want. I have the same camera as the one shown.
It was not an exact fitment. I had to use a dremel to widen the hole slightly. The lock came out pretty easily. There's one big clip holding it tight against the trunk lid. Then you need to release the yellow tabs from around the little arm that extends to the latch. Remove the other end from the latch. There's also a little harness which attaches to the lock. Just unclip it. The cylinder can slide out and needs to be tilted so arm clears the hole.
I'm going to take some pics tomorrow of my new setup and put them on my homepage. Whole install on camera took me an hour. But most of that time was spent with the Dremel.
I install home and business camera's and security systems for a living, so this is pretty simple to me. Ask ?'s if you need to know how to wire it up.
thomasd cook is offline
Old 06-13-2004, 09:49 PM
FanaticMadMax's Avatar
geez, you guys can't get enough wtih the electronics. Sound like a bunch of germans here trying to cram a lot of electronic crap inot the car. I wouldn't mess with it cuz it's unnecessary.
FanaticMadMax is offline
Old 06-14-2004, 07:02 AM
maseo77's Avatar
could u post pics or do a write up on this installation, where did you run th epower wire to?
maseo77 is offline
Old 06-14-2004, 07:14 AM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Sounds cool...what camera did you use and how much?
IceY2K1 is offline
Old 06-14-2004, 01:48 PM
K Pazzo 6's Avatar
alright cool....well i get my car back tomorrow or wed....so i'll start on this install over the weekend probably....if any questions i'll send you an email
thanks
Old 06-14-2004, 01:49 PM
K Pazzo 6's Avatar
whos this question directed to?
Old 07-04-2004, 11:16 AM
K Pazzo 6's Avatar
heres pics for those who wanted pics....
Old 07-04-2004, 11:17 AM
K Pazzo 6's Avatar
i just ran power wire to rear cig lighter & taped into that wire
Old 07-04-2004, 11:39 AM
WildmanAL's Avatar
Awesome install
WildmanAL is offline
Old 07-04-2004, 02:53 PM
BLKMAX005SPD's Avatar
Thast awesome...
i just placed a bid on one too!!!
BLKMAX005SPD is offline
Old 07-04-2004, 06:38 PM
Hooooooonda.....
DAVE Sz's Avatar
If I was going to do it I would angle the Camera a bit to have a better view of the other cars front bumper. Then again the camera probably has a wide viewing angle so that might not be needed.
DAVE Sz is offline
06-06-2017 02:01 PM
gigabyte
01-06-2017 06:05 PM
Fbana41
08-29-2016 12:18 PM
Quick Reply: Reverse Camera in trunk key hole------->
