The ultimate maintenance service?
Dealers maintenance services (such as the 60,000 mile service) do a lot of "checks" but don't end up replacing many things unless they are already broken. So the question is: If money wasn't much of an issue, what would your ideal maintenance service include? Keep it within reason.
To start things off:
what would you add?
- new front wheel bearings
- new spark plugs
- transmission fluid; oil change; radiator flush
- brake bleed; new pads
- new coil packs
- new strut mounts
- alignment/rotate/balance
- VIAS fix/check
- new o2 sensors
what would you add?
actually just bought a ton of parts for tune-up also replacing some suspension parts as follows: for the tune-up: oil change and filter (mobil 1), tranny fluid change (oem) , anti freeze flush and fill (toyota red), new plugs, new belts, pcv valve.. for suspension: new front and rear mounts (kyb), inner and outer, left and right tie rod ends, and stabilizer links (moog) .. also the illuminas and h-techs goin on.... my car has 56,600 miles on it right now but the city kills suspenion
what i did before leaving my car with my family for a year while im in korea -
65K miles on car
plugs
coils
brake fliud
clutch fluid
tranny fluid (redline MT90)
oil
brake pads (hawk HPS)
belts
coolant flush
2 oldest 02 sensors
65K miles on car
plugs
coils
brake fliud
clutch fluid
oil
belts
coolant flush
2 oldest 02 sensors
sooner - thanks for adding something helpful. I agree that most people know what needs to be done, but I'm also looking for things that might not need to be done but would be helpful preventative maintenance. Plus it is nice to have a list in one thread, especially for noobs that don't know what to search for (if you don't know what coils are, it will be hard to search for it)
I was thinking of adding MAF sensor but I'm not sure whether that degrades over time, or only if you mess with it while putting on an intake or something.
While we're on the subject, I was actually wondering what kind of maintenance I need to do on my VQ35 that just rolled over 25k.
I'm sure this has been discussed thousands of times, and I thought there was a maintenance sticky, but I couldn't find it and the free search feature isn't that helpful.
Is there anything that needs to be done before 65k? Or is the major maintenance done in 65k intervals?
I'd add checking the alternator and power steering belts and I assume you've visited our detailing forum for proper finish maintenance too.
my03maxima
04-29-2020 12:48 AM
TKHanson
11-24-2018 01:39 AM
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
RealityCheck
10-02-2015 06:34 PM
