350Z horn installation question?
Received my 350Z horns today! My question, though, for those who have these installed on their car....did you remove the front grille to install them? I know the horn is held on with one bolt on each side, but the space seems tight to access to. Also, my factory horn only has one harness going to one horn. Did you guys splice a "Y" connection from the one factory horn wire to both "Z" horns? Or did you run an extra wire from the horn relay? Thanks for your replies!
I didn't remove the grill either, but my hands were all scraped once I finished.
As Slow is pointing out you need to use stock brackets. Oh, and it's not necessary to ground them, but if you do it may help a bit.
Also, when you take the stock ones off your car note which side is high on, and which side is the low one on. They'll have H and L imprinted on the fron next to bunch of numbers.
Thanks for the replies, but there's still one unanswered question I'm stumped on. There's only one wire (power) coming out of my car to the horn.....since I'm installing two (350Z's), do I splice a "Y" connection on the power connection to power both Z horns? Will this connection affect the power in any way from the horn relay?
I dunno what the 350Z horns sound like, but I replaced mine with Q45 horns from a junkyard. Sounds much better! You don't really need to remove the grille. It's tight behind the grille, but not impossible.
ViciousVQ30
08-05-2015 05:40 PM
dutch078
Wheels/Tires
08-03-2015 06:58 PM
