Car wont start... help
Ok i know its late but heres whats up. I helped my girl install her CAI today. WHen i was taking out the battery i noticed alot of the white corrosion powder on the terminals. I cleaned out some of it when i was putting it back on. SHe called me about 5 minutes ago saying that it wont start and has no power at all.... she turns the key and nothing no lights etc. I asked her if both battery terminals were one she "said" yes. COuld the corrosion be causing this or what should i look for. Thanks!
Maybe you drain the battery, swap them or check for lights or turn your system on, if that works, make sure the terminals are there nice and tight, other than that i dont know what to tell you.
or you could mix some water with backinf soda and that will take it right off...but make sure that the terminals are tight... i had this happen to me except it started and i drove to the gas station then it wouldn't start so i moved and tighted the terminals and all was goog
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
altome15
08-10-2015 07:05 PM
