Angel Eyes/Projector Headlights for $258...
#82
Originally Posted by taino787
I think we are looking at these lights like they are porr quality because we got used to see the Nissan prices on headlights..if you see the other models of projector lights on ebay they sell for less...dont get me wrong if a had the 2k2 or 2k3 lights i wouldnt change them i think they look better...the good thing about these projector lights are the halo rings..
just my opinion fellas!
#87
i think the I30 version looks a whole mess cleaner. But there is nothing black high temp spray paint won't solve when it comes to these new maxima headlights. im curious about projectors and using the stock 2k and 2k1 housing so that is my next project. Here is what I thought of doing since i saw it on a prelude:
http://faq.auto.light.tripod.com/images/PreludeTT8.jpg
These are from an audi TT
#91
Originally Posted by PearlWhtMaX2000
ok so lets see some responses on these first, if they are good, ill start a GD
AA
#94
ill be in a for a set to, but i need goo dinformation on them, the ebay link sucks, will definitly have to wait till someone with a 2k gets them, and installs. i mean i have HID too, i want to know if the bulb will fit or what, and what about the 2 side bulbs that the 2k doesnt come with stock unlike the 2k2...well see, i like the way they look though
#98
Originally Posted by ManualMaxima
what would happen fi you used hid with a halogen projector?
That said, it wouldn't be too hard of a job to switch those projectors with a set of real D2R projectors, most likely running you about another $200 for real HID.
-James
#106
Ok. One of the guys here in Phx got the lights in. I snapped a few pics to show to you guys. These are definately a halogen setup, but the build quality seems to be very good and they look real sweet in person. HID guys will need to do some modding on these.
#112
That looks like an H3, no? Umnitza I'm not questioning you on this one cause you def know a lot more about lighting than I do. But if it IS an H3 bulb I def would not put a D2R bulb in there! A retro with a HID projector looks easy enough to work with there though...
-James
-James
#114
Originally Posted by adub_pearlmax
Received my tracking info, arriving friday. So I will take pics then and post and then install and everything and post pics after that.
If this means anything to anyone or helps anyone out, the package weighs 16 pounds.
#116
What type of bulb is used in the projector...looks to be H3. How in the world could that be? And if that is the case, ahhh don't put a D2R/S bulb anywhere near that hole. Anyhow best case they are H7, thats because H7 and D2S are nearly the same all you need to do is buy a cheap adapter and they will fit in with a perfect cut off.
#117
H3 55 1450 ECE. Transverse filament. Fog and drive lamps.
The H3 bulb, while not all that common is likely to ge the one that is pictured there.
If you are going to do an HID retrofit, which is not a bad idea, you can look into H3C, but those are usually reserved for Fog lights.
Hmmmm....very strange.
Can't imagine the halos looking all that good however, but the light looks promising overall.
#118
But I believe the way that H3 bulb is mounted the filalment is vertical, so theoretically the optics of the projector are designed to bounce the light from that source. A D2R bulb has a horizontal arc, not vertical. From everything I've ever read on HID fitment, don't put an hid bulb in an H3 socket, optics are completely different.
I know a civic that has cheep aftermarket projectors with ghetto dim halo's and H3's go into the projectors. I honestly don't think I've ever seen a more horrible beam pattern.
#119
Originally Posted by Sizzo718
Did they send you a tracking number? I received an e-mail stating that tracking numbers aren't provided to ensure security and to avoid fraud from taking place .
Yeah I emailed the guy like only one time and he said a tracking number would be the day after it was shipped. It was shipped out on monday and sure enough on tuesday I received a tracking number on tuesday. Is the email something like vitbcde???
