My impressions of the Hotshot Headers
Old 03-22-2006, 01:17 PM
  #121
DUKEE's Avatar
gotcha. yah that one. what about getting a stock gasket for between the cat and y pipe. are those okay?
DUKEE is offline
Old 03-22-2006, 01:21 PM
  #122
Puppetmaster's Avatar
The stock gasket is made for a 2.25" pipe so you'd have to cut out a little bit so that it doesn't restrict any flow. I'm pretty sure the ID of the gasket was smaller than that of my Cattman y-pipe when I compared the 2.
Puppetmaster is offline
Old 03-22-2006, 01:24 PM
  #123
DUKEE's Avatar
okay cool. so ill go and get a new 2.5 gasket for the y-pipe to cat. what about the top portion of the headers. what gaskets should i get for those? thanks
DUKEE is offline
Old 03-22-2006, 01:29 PM
  #124
I reused my stock ones... whatever is currently on there.
Old 03-22-2006, 03:38 PM
  #125
HotshotVQ35's Avatar
are they copper puppet?
HotshotVQ35 is offline
Old 03-23-2006, 06:02 AM
  #126
DUKEE's Avatar
when installing the headers did you guys end up using the o2 simulator? or did you simply extend the 02 sensor to fit? if you did, i read it was in the way of the ac comppressor line. am i correct?
DUKEE is offline
Old 03-23-2006, 06:09 AM
  #127
upstatemax's Avatar
The sensor thats in the way of the compressor is a primary that cannot be simulated. I moved that sensor to the front manifold collector (do not have to extended the wire on an 00-01), the rear stays in place, then I simulated the two secondary o2 sensors.
So there are four sensors in all, two primary and two secondary.
You can only simulate the secondary sensors.
Edit: you are a Cali spec car?
upstatemax is offline
Old 03-23-2006, 06:31 AM
  #128
VQ Wizard
SR20DEN's Avatar
I just make them fit. Eliminate the clearance problem.
SR20DEN is offline
Old 04-12-2006, 07:45 PM
  #129
DUKEE's Avatar
upstatemax: i am fed spec
DUKEE is offline
Old 04-12-2006, 07:58 PM
  #130
I'm pretty sure all 2001s are CALI spec.
Old 04-13-2006, 11:33 AM
  #131
upstatemax's Avatar
I thought some EARLY ones are fed spec, best way to tell is to look at the front of your motor and look at how many o2 sensor harnesses you have...
If you have four, you are a Cali spec.
I thought that they did not start making them all Cali till 02+.
Old 04-13-2006, 11:45 AM
  #132
According to the 2001 FSM and the information found in the following TSB, it is pretty much implied that all 2001s are CALI spec.
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Regardless, people need to learn how to pop the hood and do some looking around on their own before posting questions.
Old 04-15-2006, 05:31 AM
  #133
DUKEE's Avatar
i just noticed that i did not get in the box, the harnesses to extend the O2 sensors. is it mandatory that i have these? should i request them from hotshot?
DUKEE is offline
Old 09-21-2009, 05:28 PM
  #134
[Dustin]'s Avatar
polyurethane motor mounts by energy suspension amazing... must have!!!
[Dustin] is offline
Old 09-21-2009, 05:53 PM
  #135
nice bump noob!
mclasser
22
11-12-2020 01:58 PM
Socalstillen
09-26-2015 12:01 PM
Dasmith
09-23-2015 08:28 PM
Quick Reply: My impressions of the Hotshot Headers
