Help No fluid in Clutch reservoir !
Old 10-11-2011, 09:10 PM
maxdis1's Avatar
I went to take a drive this morning and my 01 max had almost a dead clutch pedal! I got the car in gear and was able to drive . Later after work I checked the clutch reservoir and there was no fluid in it.... Drove to Advance Auto and purchase Prestone Brake fluid , poured it in the reservoir and almost immediately the clutch pedal regained pressure . I am worried . Apparently no fluid seems to drop off the "Max mark" on the reservoir as of this evening .
How do I test to see if the Clutch Cylinder is leaking ,ect.
Kindly share your input.
maxdis1 is offline
Old 10-11-2011, 09:12 PM
chrome91's Avatar
check your clutch slave cylinder, if its leaking you will feel loss of clutch pressure and will of course leak fluid. thats where i would start, if the slave cylinder is good see if the cylinder or lines are leaking
chrome91 is offline
Old 10-11-2011, 09:41 PM
maxdis1's Avatar
Thanks for your quick response. I also just found Motovate website and I am looking into the pics . I now know where to start looking and what to look for. I think it may be a line.
thanks again.
maxdis1 is offline
Old 10-11-2011, 10:54 PM
Gram Lights addict
QT1 5MT AE's Avatar
had the same problem with my 01. check for leaks on clutch line. i had to replace mine
QT1 5MT AE is offline
Old 10-14-2011, 03:35 PM
kpgc10's Avatar
yeah usually in general slave cylinder fail causes those symptoms.
kpgc10 is offline
hcarter1112
42
07-18-2022 03:35 PM
03-12-2020 12:06 AM
06-06-2017 02:01 PM
Need help
23
10-02-2015 08:56 AM
carlosvq30
09-26-2015 09:44 AM
Quick Reply: Help No fluid in Clutch reservoir !
