Drop Resistor Mod?
Originally Posted by 30585
What In Tarnation Is It?
In a 2k it's mounted to the front of the right hand side strut tower. You will probably pull an SES if you try it out.
All it does is make EVERY shift at full line pressure. IT can alledgedly drop a tenth or two in a quarter. You WILL get a SES light if you unplug. Not suitable for everyday driving, i'm a 20 y.o. and I ended up plugging it back in cuz the banging shifts were annoying.
Originally Posted by PearlWhtMaX2000
i have an auto how would i do this?
It will light the SES light. This light is resettable by unplugging your ground wire to the battery for 30 minutes.
I will say it's pretty cool to feel how this shifts, just annoying at slow speeds.
Originally Posted by RBa
Def not worth it since you'll be damaging your tranny everytime you shift..
This is almost equal to doing neutral drops.
Nope... You are not damaging your tranny. As I posted, it actually creates longer life for the wearable clutches/discs in your transmission. The gears in the tranny are plenty capable of withstanding shock. It saves wear on the parts replaced during an overhaul, like brake band / disc+clutch packs etc...
Originally Posted by EvilRoadsVictim
and you couldn't be further away from what really happens when you mess with the line pressure/sensor.
Q: Recently on Maxima.org someone posted about a 'drop resistor mod'. When a sensor is disconnected, it allows the full line pressure in the auto tranny which makes shifts faster and more abrupt. I tried this myself and it makes an enormous difference in shift times. Is it harmful to the transmission?
A: Full line pressure will be slightly easier on the transmission because it reduces slippage (typically 2-8% for autos) and shift overlap (being in two gears at once when upshifting) due to stronger application forces being directed via the servos to the bands and clutches. This locks up the bands and clutches harder and gives firmer shifts. By reducing slippage, it also decreases the amount of heat produced by the clutches and bands and locks the clutch in the torque converter up harder in the higher gears to increase fuel economy. The heat produced by slippage contributes to wearing out the seals, bands and clutches in an automatic more quickly. However, since the transmission controller is programmed to give full line pressure at wide open throttle, this mod just gives rough shifts at part throttle. It's similar to using an HKS ALC (Automatic Line Controller) box. Other ideas to improve shifting with an auto tranny could be to shim the PL solenoid regulator springs to increase peak pressure or to shim the shift accumulator springs to firm up and speed up the shifts. Or you can just swap in a manual!
It is one and the same...
Originally Posted by richspidizzy
OK, then I'm confused. I always though that white thing (im assuming the resistor) had to do with the power steering. Can someone post some pics of the drop resistor so I can be sure I know what we are talking about?
I will say again, even though I argue this doesn't hurt the transmission, I do not use this mod because it really produces annoying shifts (for my liking) at low speed. That, and you will always have a SES light.
Originally Posted by KCMichaelM (partial quote)
...It is just behind the battery about a foot. Out of curiousity, where did you hear this had something to do with steering?...
This is the thread and specific post that made me think you were talking about the power steering thing: http://forums.maxima.org/showthread....76#post2570237
Quoted from Nissanperformancemag.com... I have an extensive automotive background (though I can't say I rebuild auto trannys) and this makes perfect sense to me. I have also asked several transmission experts about this, guys that I trust very well. Please tell me what part of this explanation you feel is incorrect, I always keep an open mind:
ok there was a whole thread around that article. search for it if you want it, i didn't find it neccessary to bring it up. yes there is no denying it does good by reducing slippage, however, this is an *uncontrolled* shift. ever thought about just how much force is being put down with every shift and at what point it actually becomes harmfull? but proclaiming that it is completely harmless or is the right thing to do is not proper, considering data on its effectiveness and safety of use is incomplete to say the best.
also please keep in mind that your transmission is linked directly to some very expensive components called driveshafts/cvs and linked to an engine connected to rubber mounts. every vibration is felt by these parts as well.
making sense in theory is one thing, letting it loose is another. i am acceptive of the wot switch approach, but driving with it unplugged all the time... apprehensive.
I will agree with that... I think it is very useful for racing but unnecessary for daily driving. I too know some members here have installed a switch that temporarily removes it from the circuit, I like that approach as well. Thanks
knight_yyz
11-01-2015 01:34 PM
maxima-junky
10-07-2015 06:13 PM
