powerslot and noise????
Old 12-18-2003, 02:07 PM
GreekMaxima's Avatar
I have a terrible noise from powerslot rotors... when stoping, noise all the time when i use the brake pedal!! this is normal guys? i had them for a week now...
let me know guys...
thanks!
GreekMaxima is offline
Old 12-18-2003, 02:17 PM
2kGLE's Avatar
what kind of noise?
2kGLE is offline
Old 12-18-2003, 02:19 PM
VMosser323's Avatar
I just had my Powerslots installed last weekend. I have Hawk HPS on the fronts and Raybestos on the rears. I remember seeing the Powerslot instruction/guidance form that came with the rotors. It said that there will be a slight/mild grinding noise which is acceptable. When I got my car back form the install, I drove it about 100 miles breaking them in. They still make a slight noise, but nothing that sounds awkward.
VMosser323 is offline
Old 12-18-2003, 02:52 PM
2001SE's Avatar
what kind of a slight noise, when braking hard or slow speeds?
i think i heard before that the Hawk pads are not good for consistent hard braking and if they are used a lot, they start to screech and make noises...but i am not sure
2001SE is offline
Old 12-18-2003, 03:39 PM
scopium
i got the same awful noise but i have Brembo slotted with PBR brakes
Old 12-18-2003, 08:00 PM
Originally Posted by 2kGLE
what kind of noise?
hmm... how can i explain? when i stop "sssss" when i let off the gas pedal "krrrr"
i was try to explain you...
I dont think this noise come from the pads...
Old 12-19-2003, 06:29 AM
2k2nyc's Avatar
It's from the Hawk pads. I have Hawks on stock rotors, and mine do that also.
2k2nyc is offline
Old 12-19-2003, 06:59 AM
Quidproquo's Avatar
My brakes make a slight noise when I tap them lightly, but no noise at all when I apply normal stopping pressure. I think the noise, in my case, is attributable to the slotted rotors.
I had an awful noise last week, but it turned out to be my hub bearings. Luckily that is under the 60k warranty and NNA fixed it for free.
Quidproquo is offline
Old 12-19-2003, 07:30 AM
but i heard HAWK is the best...
Old 12-19-2003, 08:50 AM
I live life on the edge
skalberti's Avatar
I have drilled and slotted rotors and its a "hum" noise that you'll here under hard braking, especially going down hill. Which way are your slosts facing? If standing in fron of your wheel, are the slots swept back or are they pointing to the front of the car? They should be pointing to the front , that is where you'll get the best cooling and its also the way they were designed to work. The noise is common though. Hope this helps
skalberti is offline
Old 12-19-2003, 08:51 AM
2k2nyc's Avatar
HAWK is good. The material used to make HAWK pads can produce noise, but it should reduce once the pads have heated up. Also, braking ability increases when they heat up.
2k2nyc is offline
Old 12-19-2003, 09:15 AM
VMosser323's Avatar
You mean you can choose which way the slots point?? I thought this was not possible considering the rotors are labeled L & R.
The noises I mentioned earlier are not anything I would consider loud, awkward, obnxious, or concerning. To me , it sounds like a "sssssss" and I can only hear it when I turn off the heater & radio and listen for it.
Old 12-19-2003, 09:18 AM
ghostrider17's Avatar
Oxymoron
Definition of Irony:
The words Nissan of North American used in conjuction with the terms of WARRANTY and FIXED for FREE.
everyone repent -- the end of the world is near!
gr
ghostrider17 is offline
hcarter1112
42
07-18-2022 03:35 PM
aw11power
10-10-2021 04:57 AM
D Mason
06-21-2016 04:43 AM
uttadms31
09-30-2015 05:24 AM
Quick Reply: powerslot and noise????
