What kind of battery is in YOUR Max? (Optima, Die Hard, etc...?)
Old 12-13-2003, 05:41 PM
turbomolar's Avatar
Just wondering...
Does anyone happen to have an Optima Red Top battery in their
02 Maxima? If so, which one did you use, and was there any problem
with "shoe-horning" it in there?
Thanks for the input!
turbomolar is offline
Old 12-13-2003, 05:43 PM
92 SE-R 02 SE
when mine goes, im going to get the yellow top.
Old 12-13-2003, 05:48 PM
† ErV †
same here. i am sure my oem one will go soon enough..
Old 12-13-2003, 06:10 PM
Maxman2000's Avatar
My dad's is still running on the same one from when we bought the car surprisingly.
Maxman2000 is offline
Old 12-13-2003, 06:14 PM
L33t BMW Drivah
KLOOGY's Avatar
Yellowtop Here !
KLOOGY is offline
Old 12-13-2003, 06:36 PM
2k3TitaniumSe's Avatar
whats the ndifference with the optima yellow top and die hard gold? Everyone's making a big deal about the optima yellow top.
2k3TitaniumSe is offline
Old 12-13-2003, 07:59 PM
FanaticMadMax's Avatar
None of those, still with my original OEM battery. Hasn't given any trouble with 27k miles logged on it.
FanaticMadMax is offline
Old 12-13-2003, 08:02 PM
L33t BMW Drivah
KLOOGY's Avatar
Youre not running 2- 800 Watt Rockford Fosgate amps.....
KLOOGY is offline
Old 12-13-2003, 08:42 PM
MrGone's Avatar
Dads 5th gen: Interstate (Dont know if thats factory or not)
My 3rd gen: my trusty Kirkland signature big-un. You'll never take it from me
MrGone is offline
Old 12-13-2003, 10:00 PM
HitManSE's Avatar
I got the optima yellow top... ...two of them
HitManSE is offline
Old 12-13-2003, 10:59 PM
turbomolar's Avatar
Does anyone know what the difference is between the Optima Yellow and Red tops? Looks like the Red tops are a bit more expensive than the Yellow. Why is that?
ps
For you Yellow toppers out there...
do you remember what size you got?
(35? 24f?)
Old 12-13-2003, 11:26 PM
HitManSE's Avatar
Yellow top is a deep cycle battery. The yellow top is more expensive from what I remember. Deep cycle means its gonna take a little while for it to drain. Basically I can park my car & bump in a parking lot for a while & still be alright while normal batteries will drain after a short while.
The model # is 34 last I checked. The only weird thing is the posts are reveresed. You can obviously work your way around that.
HitManSE is offline
Old 12-13-2003, 11:37 PM
MaxVader's Avatar
Yellow Top Here
MaxVader is offline
Old 12-13-2003, 11:51 PM
L33t BMW Drivah
KLOOGY's Avatar
I can bump mine for almost an hour at full blast, and when I drain it, just give it 10 minutes and it fires itself back up ! I run one set of posts for the car, and the other set goes to amps...
I wish I had two like you !
KLOOGY is offline
Old 12-14-2003, 12:01 AM
cyclecrazy55's Avatar
Optima Red Top
I have 80K on my 2000 Maxima and decided the old battery needed to be retired. I've done my share of leaving the lights on overnight. Surprisingly the stock battery still ran pretty well but I saw the Optima red top was a good performer. I had to buy a 5 inch battery terminal extender and hook it up to the positve post. The stock Max terminal has this housing thats forms a right angle that won't fit easily on the Red top. This was an easy fix and the Optima runs Beautiful. Do the Red top. You won't regret it.
Originally Posted by turbomolar
Just wondering...
cyclecrazy55 is offline
Old 12-14-2003, 12:06 AM
HitManSE's Avatar
If you have a system or are planning on it YT is the best choice. If you want just a basic upgrade then RT. Plain & simple.
HitManSE is offline
Old 12-14-2003, 12:11 AM
L33t BMW Drivah
KLOOGY's Avatar
Like Hitman said, if you dont ever want to worry about a dead battery , since you have no system.... get a yellowtop....its worth the peace of mind. You can leave all the lights on and walk away for a week.... and it still wont be completely dead !
KLOOGY is offline
Old 12-14-2003, 12:18 AM
Clay Aiken has fancy genitals
asu174's Avatar
Night and day......
asu174 is offline
Old 12-14-2003, 01:21 AM
Future Camaro SS owner
MyownNismo's Avatar
I am getting a yellow top once I get my 1000 watt amp. I might as well get a cap too.
MyownNismo is offline
Old 12-14-2003, 01:50 AM
HitManSE's Avatar
Ahh, screw the cap. I had two...then I returned them and got another YT for $10less more bang for the buck IMO. If you dont care about weight though.
HitManSE is offline
Old 12-14-2003, 04:37 AM
Doctorate in Detailing
Bluesbrekr's Avatar
Just wondering...
with "shoe-horning" it in there?Thanks for the input!
I got the smaller sized Red Top. Still plenty of power and CCA and the posts are closer to the edge so I didn't have to bend the + connector or add an extender.
Bluesbrekr is offline
Old 12-14-2003, 05:41 PM
Jackboot's Avatar
OT
I really love how the injen looks
Jackboot is offline
Old 12-14-2003, 07:56 PM
Pointy Elbows
00MaxSE's Avatar
48K and I'm still on the OEM battery.
00MaxSE is offline
Old 12-14-2003, 07:59 PM
shonufmax's Avatar
Optima Yellow top
I purchesed the yellow top battery and put it in, from the jump I noticed:
1. It's not the same height as my stock battery, so the stock battery tiedowns were no good
2. The post was to far from the edge, so my positive connection would have to be modified, by either cutting the wires and using one of the aftermarket terminals for car audio or bend that stupid stock L bracket some kind of way to make it fit ...Does any one know off hand what that stupid fuse is for anyway on the positive bracket?
3. I diddn't want to deal with all that! So after all that I bought A= Energizer form Pep Boys it works
shonufmax is offline
Old 12-14-2003, 08:03 PM
NYC2SD's Avatar
I had my stock battery replaced under warranty 2 months after I bought the car. The b&tch was leaking acid all over the place.
NYC2SD is offline
Still Here... IM me for more..
HNDA ETR's Avatar
Die Hard Gold!
HNDA ETR is offline
Old 12-14-2003, 08:16 PM
MyownNismo's Avatar
I had a yellow top with a cap on my last system with my 2 400 watt amps and had no problems. I am sure Kloogy isn't have a problem.
Old 12-14-2003, 09:06 PM
twotone's Avatar
isn't yellow top a replacment for stereo batteries?
I'll probably go with red top...
twotone is offline
Old 12-14-2003, 09:59 PM
scmaxima2k's Avatar
Im using a yellow top too.
-Steve
scmaxima2k is offline
Old 12-18-2003, 09:05 PM
Pointy Elbows
00MaxSE's Avatar
Bluesbrekr,
what's the part # of the Red top that you have in your car? The battery in my truck just died, so I'm gonna buy an Optima for the max and put the OEM battery from my max into the truck.
00MaxSE is offline
Old 12-19-2003, 08:57 AM
woreyah's Avatar
I'm runnin' RF bd1000 at 2ohms and 851x at 4ohms, 1 cap on OEM battery and no blinking lights(except the interior).
woreyah is offline
Old 12-19-2003, 10:15 AM
frencjas's Avatar
OEM battery, and 75K on the odometer.
frencjas is offline
sctludwig
09-01-2022 01:32 PM
The Frye
09-02-2021 11:03 AM
captchaos
03-15-2016 12:18 PM
markevans999
09-10-2015 04:29 PM
MaxLife17
09-08-2015 02:36 PM
Quick Reply: What kind of battery is in YOUR Max? (Optima, Die Hard, etc...?)
