Tire Pressure: Nissan or Tire Spec?
Originally Posted by maxcosity
Is it better to follow Nissan's PSI rating (32) or the tire's indicated rating (in my case, 44) ?
Maybe I dont know much about tire pressures, but isnt 32 to 44 psi a big difference? IMO, if the heavier the car, the more air I would put in the tires(sound right?). Lastly, it would matter more on the type of tire you are using(17-18's)...
Yeah, my Michelin Pilot Sport A/S's claim a maximum pressure of 51psi, Nissan recommends 32... I use 35-38 and the car rides great. The car feels a little "squirmish" in its handling sometimes at <32psi.
Note that I'm also using 235/45-17 on 17x7 wheels, where the wheel width (7") is supposed to be just a little too narrow for these tires...
44psi is maximum COLD pressure...NEVER use that!
I used to run 40-41psi and it was HARSH. I felt every little pebble, crack, hell even ant I ran over.
Then a couple tire gurus on here showed me the extreme science/testing behind those pressures and how running out of spec is DANGEROUS, so I run within 2-3psi of Nissans' recommended 32psi. It made a dramatic difference in ride quality and handling, however tire wear increased somewhat.
Once you vary from OEM brand/size tires, I'd do some research on the "best" pressures to run.
I second Alex's suggestions. I run 34 psi front and 31 in the rear; no need to run same tire pressure on rear if 63% of the weight is carried by the front wheels, eh?
Try some moderate differential pressure...you'll like it
What rate do you guys lose pressure? I notice that I lose a couple PSI every couple months, but I'm wondering if that is just because of the weather (it's been colder here lately)...
I run 35 F/ 32 R
should never inflate to the max labeled psi. says MAX for a reason, not maxima har har... I think i read 32 was ideal all around but since they say you lose on average 1 psi/month, i just do 35 and be lazy..
Originally Posted by MaximaPolak
I run 36-38 F / 33-35 ROff course that now it is snowing and raining, I don't care too much. That reminds me, I better check the pressure today.
02nissmax
09-05-2015 01:50 PM
Team STILLEN
08-10-2015 04:29 PM
