Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Sponsored by: Simple Tire
Click Here
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-06-2003, 12:41 PM   #1
ECM Location?
Just wondering where the ECM on a 2003 is located, so that I could get the part # off of mine.
-Jesse
jessefrank is offline   Reply With Quote
Old 12-06-2003, 01:23 PM   #2
Points: 6,384, Level: 52
Points: 6,384, Level: 52 Points: 6,384, Level: 52 Points: 6,384, Level: 52
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
What is ECM?
jaco is offline   Reply With Quote
Old 12-06-2003, 02:25 PM   #3
Points: 9,184, Level: 64
Points: 9,184, Level: 64 Points: 9,184, Level: 64 Points: 9,184, Level: 64
Activity: 0%
I believe he means ECU (Electronic Control Unit). It is the main computer that controls the engine and electronics in the car. I believe its under the passenger side kick panel?
Uconn411 is offline   Reply With Quote
Old 12-06-2003, 02:26 PM   #4
The part number is not on the ECM. I took my ECM out when the hestitation TSB was issued and there is nothing on it except for a serial number. You have to use a Consult II to pull down the part number. The dealer showed me how this is done when I brought the car in for the TSB.
jvitale is offline   Reply With Quote
Old 12-06-2003, 02:26 PM   #5
Points: 10,066, Level: 67
Points: 10,066, Level: 67 Points: 10,066, Level: 67 Points: 10,066, Level: 67
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
Quote:
-Jesse
The FSm says that it is located "behind the instrument lower cover." You might be able to see it if you remove the glove box.
Zero Deuce SE is offline   Reply With Quote
Old 12-07-2003, 07:50 AM   #6
Points: 15,309, Level: 79
Points: 15,309, Level: 79 Points: 15,309, Level: 79 Points: 15,309, Level: 79
Activity: 0%
Send a message via AIM to studman
The ECU is located on the floor directly behind the radio. You do NOT need to remove any glove box, dash, or vents to access it. There is a black plastic cover with 2 round plastic snaps that cover the ECU. From the driver's side, the cover is directly beside the gas pedal. Pull on the cover to remove it, and there is the ECU. The ECU has (4) 8mm screws that hold it to the mounting bracket. Then it slides out towards the passenger's side.
As for the part number, you need the Consult-II to get it. But you also need a code that is written on top of the ECU if you are looking for a junkyard spare. You can see this code from the passenger's side without removing the ECU from the mounting bracket (You will need a flashlight). The number should be A56-***-** or something like that.
studman is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
