Foglight Rewire Instructions??
Originally Posted by Mkang513
The how-to in the FAQS don't work and the search is disabled. Anyone have a how-to? I just need to rewire them so they go on with my clearance lights.
all done
Originally Posted by Igor911
open the relay box under the hood, cut the blu/yellow wire under the fog relay, connect the end comming from the relay to the green wire on the parking light.
all done
all done
Originally Posted by kcowden
I have the corners wired to blink with the turn signals.... any problem with rewiring the fogs??? Thanks!
You are powering corners off of turn signal. He will power his fogs from parking light.
nope, those are 2 diff sources of power.
all done
all done
Originally Posted by gtbigup
Hey guys with the fog light rewire, do you still have the option to not turn it on or does it come on automatically with the parking lights?
You still can't get them on with the high beams, though... upon initial inspection of the schematics I think it's possible, but would require removing the lighting/turn signal switch arm from the steering column, taking it apart and doing some internal rewiring... not sure how hard that'll be. This is so you can use the stock foglight switch to keep the foglights on with the highbeams on... if you don't want to go through all that trouble, you could install a new foglight switch instead... but it wouldn't be as nice
yes, the green wire that is directly behind the bulb.
I just re-wired my fogs and I love the look. Should have done this months ago! One weird thing tho - i hooked the green wire up to the wrong end of the fog relay wire at first and I got 1 (yes 1) HID low beam to go on along with the corner lights, but of course no fogs. It was strange. Hooked it up right immediatly after and everyhting was fine, HIDs worked, High beams, corners, everything all set so I was happy no fuses blew or worse.
all done
all done
all done
all done
Heat0212
10-24-2020 12:36 AM
ricky7780
11-03-2015 03:22 PM
