6 Speed Oddity
Old 11-09-2003, 05:41 AM
Darth Vader's Avatar
6 Speed Oddity
I live in the Northeast and the last two mornings it has been cold. I was running a little late for Church this morning and hopped in the Max and just took off.
For the first 5 minutes the 6 Speed shifted the smoothest it has ever shifted. It felt like it fell into gear with absolutely no resistance whatsoever.
However, about 5 minutes later she was back to normal, you know, notchy and resistant. Oh well, do you think it has something to do with the expansion and contraction due to temperature ??
Darth Vader is offline
Old 11-09-2003, 07:31 AM
Doctorate in Detailing
Bluesbrekr's Avatar
When it's cold, my 6 speed is very stiff. It gets smoother as it warms up. Have you replaced the factory gear oil? I still have the stock oil in mine.
Bluesbrekr is offline
Old 11-09-2003, 07:57 AM
Yes, I have replaced it with MT-90.
Old 11-09-2003, 08:07 AM
Bluesbrekr's Avatar
I want to do that before it gets really cold here. I have 13,000 miles and figured it wouldn't hurt to change it. For the first 2500 miles it was a bit nochy but it has smoothed out nicely since then. I was hoping the MT-90 would help smooth it out even more.
Does your 6 speed shift hard in the warm weather, too? Did you notice any change when you went to the MT-90?
Old 11-09-2003, 08:16 AM
I did notice a small change from 2nd to 3rd. The Max shifts strangely. Sometimes it is smooth and other times I almost have to force it into gear.
Old 11-09-2003, 09:49 AM
Bluesbrekr's Avatar
About once a month or so it will not want to go into 1st. I have to hit the clutch again, and then it slides in.
I'm still baffled that yours shifted smoother when it was cold, tho
Old 11-09-2003, 10:09 AM
Dyno plot says I have the most area under the Administrator curve
SteVTEC's Avatar
yeah that's odd.
My 99 5spd is a little stiff and notchy when cold too, but after it gets warmed up it's smooth again.
SteVTEC is offline
Old 11-09-2003, 11:20 AM
kevc5's Avatar
That is what puzzles me about this transmission. Sometimes it works great but most of the time it shifts like crap. There is no ryhme or reason as to what conditions it performs best under.
kevc5 is offline
Old 11-09-2003, 04:56 PM
GuZo's Avatar
When mine is cold it's not very easy to shift, with a bit of resistance from the shifter, not after warm though.
GuZo is offline
Old 11-09-2003, 05:43 PM
tampamax's Avatar
not the same car, but my celica will shift horribly when the temp in the tranny is warmed up and shifts like butta when cold. I noticed this started happening after about 50K hard shifting miles. Before my syncro's started to wear, the tranny would behave the opposite of what it does now. Huh, go figure i don't know why?
tampamax is offline
Miket2006
03-01-2021 03:55 AM
knight_yyz
11-01-2015 01:34 PM
uttadms31
09-30-2015 05:24 AM
Marc2theMax
09-28-2015 08:13 AM
Quick Reply: 6 Speed Oddity
