How much oil does your VQ35 use?
Originally Posted by t56gen3
10W30 Summer and 5W30 Winter
I noticed that you are using Mobil 1---how much break in time did you allow for before you switched to full synthetic?
I allow at least 5k miles before going synthetic.
Originally Posted by Pearltt
I get the same out as I put in and the viscosity is the same also. Using AMSOIL 5w 30
Unless you happen to analyze the oil after you remove it from then engine, how can you say that the viscosity is the same as when you put it in?
Originally Posted by KL99SEA
Mine eats it....every time I ck it I need some. I may have the dealer do some kind of consumtion test. Never had a car use so much. I would guess 1.5 qts in 3k miles.
What filter do you use?
How many miles on the car?
You drive it like you stole it?
On my VQ30 (not the question, I know), around 1 quart 5w-30 mobil 1 every 4-5k miles. However, recently I noticed a small leak around I think the oil sending unit. I am going to have it checked out when I bring the thing in for damn rattling tomorow. Ohterwise the car never drips oil or burns it from what I can tell.
Almost none between changes averaging 4k-6k miles. I've had about 5 vehicles with the VQ35 or VQ30 engine and same with all of them. Quite unusual for this engine to use so much oil regardless of what the dealer says. Perhaps you have some carbon build-up that has either resticted the EGR system, PCV valve or made the ring pack unflexible alowing more blow-by. Any of these would increase oil consumption materially. Would suggest replacing the pcv valve, inspecting the EGR system and running a good carbon cleaner like Techron, Neutra #131 or BG44 through the fuel system. Can't hurt even if this doesn't solve your problem.
How much oil you put in the car?
Well......25k miles
usually synthetic various brands
usually fram filter. (yeah yeah)
and 3/4 of the miles are wife driven easy ones
I drive it hard, it does not smoke any, I think the one mis-shift from 3rd to 2nd (wanted 4th) took its toll. Saw like 8000 rpm's that night. Who knows.
Well......25k miles
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
