Metal grinding? *HELP PLZ*
Old 09-07-2003, 01:34 PM
BLaZin 2k MaX's Avatar
Its coming from the front right wheel well. It sounds like metal is grinding on metal but its not constant. It will do it for about 10-15 seconds then stop for about 10-15 minutes then start again. My guess is that my rotors are gone but I could be wrong. Does anyone have any suggestions as to what is going wrong and the best way to get the problem solved? I'm kinda dreading going to the dealer. All suggestions are welcomed.
BLaZin 2k MaX is offline
Old 09-07-2003, 01:39 PM
IMBOUTTOBUSTSOMEGHOSTS
sloppymax's Avatar
does it only do it when you are not on the brakes?
sloppymax is offline
Old 09-07-2003, 03:30 PM
Most of the time when I apply the breaks it stops, but not always right away.
Old 09-07-2003, 03:33 PM
mad_maxx03's Avatar
It really does sound likes it time for new rotors
mad_maxx03 is offline
Old 09-07-2003, 06:16 PM
sloppymax's Avatar
if it sounds similar to a cd skipping but still metal on metal it might be the pad wear indicator for the brake pads. i would have them replaced as soon as you can if this is the case to keep possible rotor damage from occuring. im not suggesting it is going to occur immediately but obviously it needs to be looked at.
Old 09-08-2003, 10:52 AM
I have 86,000 miles and I never changed my rotors.
Old 09-08-2003, 11:08 AM
CVicVogel's Avatar
Could it be the feeler gauge on the brake pads rubbing against the rotor telling you the brake pads are shot????
How old are the pads? Were they put on properly??
CVicVogel is offline
Old 09-08-2003, 03:03 PM
steelymatt's Avatar
It could be a bad wheel bearing. That happened to me.
steelymatt is offline
Fbana41
08-29-2016 12:18 PM
02PearlSE
02-01-2016 12:37 AM
carlosvq30
09-26-2015 09:44 AM
Quick Reply: Metal grinding? *HELP PLZ*
