Clunk when first moving from a stop
Old 09-03-2003, 04:08 PM
Jaws's Avatar
Car has been with the dealer all day and I phoned them to ask what's going on since they are usually good at getting back to me. Anyway they haven't been able to diagnose the problem.
Symptoms: Slight "clunk" when first moving from a dead stop. If I take off slowly, no clunk. My opinion is that it is an engine mount. The service advisor said they looked into it and a blown engine mount doesn't appear to be the problem. Any ideas?
BTW, the noise is coming from the front end and is definitely drivetrain related. It doesn't matter if i am driving straight or turning, and the clutch engages/releases smoothly.
Jaws is offline
Old 09-03-2003, 05:16 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
I get that too...still don't know what it is.
Feels like I have an auto that's ready to die. Almost like it slips for a second and then *BANGS* into gear.
My guess is it's tranny related.
IceY2K1 is offline
Old 09-03-2003, 06:10 PM
WANNA RUN IT?
tonylittell's Avatar
nail the gas and get it spinning....got wheel hop or clunks?if so its the control arm hitting the frame...mine does it and nobody knows how to fix it
tonylittell is offline
Old 09-03-2003, 09:29 PM
Jaws's Avatar
Yup, I get the wheel hop and a clunk. I'll bet the reason the control arm is hitting the frame is that a mount is shot which allows the whole engine to move under hard acceleration. Have they tried replacing any of your mounts?
Jaws is offline
Old 09-04-2003, 05:24 AM
WANNA RUN IT?
no ...so far i have been getting the "can not duplicate under normal driving conditions" the bab part is i work for the fockers.......i shoud know something next weel though
Old 09-05-2003, 06:06 AM
WANNA RUN IT?
good news nissan is admitting there is a problem w my car....they are fixing it now...let you know what it was
Old 09-07-2003, 06:15 AM
WANNA RUN IT?
right front strut and strut assembly gone....ordered parts and will be fixed by wednesday!!!!!!!!!!
Old 09-07-2003, 06:44 PM
Jaws's Avatar
Dealer confirmed that trouble with my car is rear engine mount and sway bar link (?). Will be fixed by tomorrow.
Jaws is offline
Old 09-08-2003, 01:57 AM
HitManSE's Avatar
Motor mounts are busted. Give it enough gas and it will do it every time. Pop the hood, have some1 put the car it gear and hold the brake with their left footm and give it a little gas (1200-1300rpms) with the other and you'll notice the engine moving quite a bit...this is the cause most of the time.
It is also possible for the suspension to cause a cluck to happen, ive even seen the b-pipe slam the into the underbody of the car causing a cluck be4.
Check it out that that order from most commen to barely ever the case.
HitManSE is offline
tarun900
19
12-20-2021 06:57 PM
06-06-2017 02:01 PM
Unclejunebug
04-02-2016 05:42 AM
BobTX10
10-07-2015 08:43 AM
Quick Reply: Clunk when first moving from a stop
